Can get signal but no channels
Postby aseke » Sun Jan 20, 2013 6:58 am
I have bought TBS 6928 recently. I installed the drivers successfully but on DVBDream when I scan for channels I have very high signal in most TPs but at the end of the scan no channels are found. Similarly in DVBViewer I could see the signal on the bottom when I click on an existing channel but there is no picture or sound. When I use the blind scan tool however I could find many channels.
I contacted the technical support and they replaced my device but I still have exactly the same problem. I have read a similar problem here:
viewtopic.php?f=55&t=2136
Different from here I don't have another card installed on my system right now. But I also run Windows 7 x64, I also get signal but no channels, I also get channels with blind scan.
Any suggestions would be appreciated.
Thanks.
aseke
Re: Can get signal but no channels
Postby steven » Mon Jan 21, 2013 10:06 am
Hi aseke
Would you mind telling us that do you have used TBS6928 with CAM inserted?
If it is ,Can you remove the CAM and have a test again.
