LOW Symbol Rate
LOW Symbol Rate
Postby Cabbanis » Sun Dec 30, 2012 3:17 am
I've got problems with low symbol rate transponders. Some of them 6981 doesn't see at all, and some just stutter. With 27500 etc. everything is fine. I'm using dvbdream 2.2b.
Can somebody help fixing this issue?
Cabbanis
Re: LOW Symbol Rate
Postby SergioDanielG » Sun Dec 30, 2012 5:20 am
Hi Cabbanis.
Can you tell us wich transponder is problematic for you.
From TBS6981 specification
Symbol Rate:
DVB-S QPSK 1~45Msps
DVB-S2 QPSK/8PSK 2~36Msps
Verify if it there the problem.
Best regards.
SergioDanielG
Re: LOW Symbol Rate
Postby Cabbanis » Sun Dec 30, 2012 5:51 pm
12637 H 14468 at 4.9E Astra 4A. While 12608 H 27500 shows ok, and they're on the same beam.
Cabbanis
