How to Use Vlc as a Broadcast Server in Linux
Postby miyop » Fri Dec 28, 2012 3:47 pm
I have TBS6981 DVB-S/S2 card and two computers connected to the same network. One works with linux using only command line. The other is win7. Now;
1. I will get dvb-s signal with vlc player (in linux machine)
2. Transcode -maybe it is not necessray- it into a stream. (in linux machine)
3. Send this stream to the other computer(win7) and play it again in vlc player.
Meanly I will use linux machine as a server and win7 will be a client. I would be very appreciated if anyone could help.
miyop
Re: How to Use Vlc as a Broadcast Server in Linux
Postby updatelee » Sat Dec 29, 2012 1:03 am
probably best to use an app designed for that, dvbstream or mumudvb Im told work well.
Postby SergioDanielG » Sat Dec 29, 2012 3:17 am
Hi miyop.
If you are using a desktop enviroment in linux, you can start VLC and use "Emit" option on "Media" menu. There select "Capture Device" and "DVB-S or "DVB-S2".
Complete Frequency and Symbol Rate.
Click on "Emit"
In "Emit" dialog click on Next, in Destinations select HTTP (for example) and click on Add. There, deactivate (if you want or delect opitons) "Active transconding". Click on Next and to finish, click on "Emit"
Go to w7 machine, open VLC and open the stream, for example http://192.168.1.1:8080/ (being 192.168.1.1 the ip of linux machine)
If it util for you, in my blog you can find an Step by Step tutorial to do this with pictures, but only in spanish.
Best regards.
SergioDanielG
Postby miyop » Mon Dec 31, 2012 8:25 pm
It is necessary for me to do it on vlc.
And I have no user interface. I have to work on command line.
miyop
Postby SergioDanielG » Tue Jan 01, 2013 1:45 am
Hi miyop.
From command line use cvlc, and some like this.
cvlc -vvv --color --ttl 12  --ts-es-id-pid --programs=161 dvb:///dev/dvb/adapter0 \
    --dvb-adapter=0 --dvb-frequency=11603000 --dvb-srate=8500000 --dvb-voltage=13 \
    --sout-standard-access=udp --sout-standard-mux=ts --sout \    '#duplicate{dst=rtp{dst=address1,mux=ts},select="program=161",dst=rtp{dst=10.0.0.2,port=5004,mux=ts},select="program=161"}'
Additionally, you can find more details about vlc stream in http://www.videolan.org/doc/streaming-h ... /ch09.html
Best regards.
SergioDanielG
Postby updatelee » Tue Jan 01, 2013 7:41 am
dvbstream or mumudvb are both command line applications
Postby miyop » Wed Jan 16, 2013 6:52 pm
SergioDanielG Wrote:Hi miyop.
Best regards.
When I enter your input I get that output:
main stream out warning: missing value for option mux
[0x7ff3ec0015a8] main stream out warning: missing value for option access
[0x7ff3ec0015a8] main stream out debug: set config option: sout-standard-dst to
[0x7ff3ec002aa8] main access out debug: looking for sout access module: 1 candidate
[0x7ff3ec002aa8] main access out debug: net: connecting to [ ]:1234
[0x7ff3ec002aa8] main access out error: cannot resolve [ ]:1234 : Name or service not known
[0x7ff3ec002aa8] access_output_udp access out error: failed to create raw UDP socket
[0x7ff3ec002aa8] main access out debug: no sout access module matching "udp" could be loaded
[0x7ff3ec002aa8] main access out debug: TIMER module_need() : 200.693 ms - Total 200.693 ms / 1 intvls (Avg 200.693 ms)
[0x7ff3ec0015a8] stream_out_standard stream out error: no suitable sout access module for `udp/ts:// '
[0x7ff3ec0015a8] main stream out debug: no sout stream module matching "standard" could be loaded
[0x7ff3ec0015a8] main stream out debug: TIMER module_need() : 201.063 ms - Total 201.063 ms / 1 intvls (Avg 201.063 ms)
[0x7ff3ec0015a8] main stream out debug: destroying chain... (name=(null))
[0x7ff3ec0015a8] main stream out debug: destroying chain done
[0x7ff3ec004178] main stream output error: stream chain failed for `standard{mux="",access="",dst=" "}'
[0x7ff3f4000b28] main input error: cannot start stream output instance, aborting
[0x1e8ae08] main playlist debug: finished input
[0x1e8ae08] main playlist debug: dead input
[0x7ff3f4000b28] main input debug: TIMER input launching for 'dvb:///dev/dvb/adapter0' : 201.645 ms - Total 201.645 ms / 1 intvls (Avg 201.645 ms)
[0x1e8ae08] main playlist debug: changing item without a request (current 0/2)
[0x1e8ae08] main playlist debug: using item 1
[0x1e8ae08] main playlist debug: starting playback of the new playlist item
[0x1e8ae08] main playlist debug: resyncing on #duplicate{dst=rtp{dst=address1,mux=ts},select="program=161",dst=rtp{dst=10.0.0.2,port=5004,mux=ts},select="program=161"}
[0x1e8ae08] main playlist debug: #duplicate{dst=rtp{dst=address1,mux=ts},select="program=161",dst=rtp{dst=10.0.0.2,port=5004,mux=ts},select="program=161"} is at 1
[0x1e8ae08] main playlist debug: creating new input thread
[0x7ff3f4000b28] main input debug: Creating an input for '#duplicate{dst=rtp{dst=address1,mux=ts},select="program=161",dst=rtp{dst=10.0.0.2,port=5004,mux=ts},select="program=161"}'
[0x7ff3ec003f38] main stream output debug: using sout chain=`standard{mux="",access="",dst=" "}'
[0x7ff3ec003f38] main stream output debug: stream=`standard'
[0x7ff3ec003d58] main stream out debug: looking for sout stream module: 1 candidate
[0x7ff3ec003d58] main stream out warning: missing value for option mux
[0x7ff3ec003d58] main stream out warning: missing value for option access
[0x7ff3ec003d58] main stream out debug: set config option: sout-standard-dst to
[0x7ff3ec003b58] main access out debug: looking for sout access module: 1 candidate
[0x7ff3ec003b58] main access out debug: net: connecting to [ ]:1234
[0x7ff3ec003b58] main access out error: cannot resolve [ ]:1234 : Name or service not known
[0x7ff3ec003b58] access_output_udp access out error: failed to create raw UDP socket
[0x7ff3ec003b58] main access out debug: no sout access module matching "udp" could be loaded
[0x7ff3ec003b58] main access out debug: TIMER module_need() : 47.235 ms - Total 47.235 ms / 1 intvls (Avg 47.235 ms)
[0x7ff3ec003d58] stream_out_standard stream out error: no suitable sout access module for `udp/ts:// '
[0x7ff3ec003d58] main stream out debug: no sout stream module matching "standard" could be loaded
[0x7ff3ec003d58] main stream out debug: TIMER module_need() : 47.599 ms - Total 47.599 ms / 1 intvls (Avg 47.599 ms)
[0x7ff3ec003d58] main stream out debug: destroying chain... (name=(null))
[0x7ff3ec003d58] main stream out debug: destroying chain done
[0x7ff3ec003f38] main stream output error: stream chain failed for `standard{mux="",access="",dst=" "}'
[0x7ff3f4000b28] main input debug: TIMER input launching for '#duplicate{dst=rtp{dst=address1,mux=ts},select="program=161",dst=rtp{dst=10.0.0.2,port=5004,mux=ts},select="program=161"}' : 48.135 ms - Total 48.135 ms / 1 intvls (Avg 48.135 ms)
[0x1e8ae08] main playlist debug: changing item without a request (current 1/2)
[0x1e8ae08] main playlist debug: nothing to play
If it won't confuse you, I'm going to give another input example:
vlc -vvv dvb:// :dvb-adapter=1 : dvb-polarization=H : dvb-srate=2800000 :dvb-fec=3/4 :dvb-frequency=12569000000 --sout '#standard{access=http,mux=ts,dst=server_ip:server_port}'
which gives in return:
main access debug: looking for access module: 2 candidates
[0x7f2cf0002d38] filesystem access debug: opening file `/home/user/dvb-srate=2800000'
[0x7f2cf0002d38] filesystem access error: cannot open file /home/user/dvb-srate=2800000 (No such file or directory)
[0x7f2cf0002d38] main access error: File reading failed
[0x7f2cf0002d38] main access error: VLC could not open the file "/home/user/dvb-srate=2800000". (No such file or directory)
[0x7f2cf0002d38] main access debug: no access module matching "file" could be loaded
[0x7f2cf0002d38] main access debug: TIMER module_need() : 0.274 ms - Total 0.274 ms / 1 intvls (Avg 0.274 ms)
[0x7f2cf4000b28] main input error: open of `file:///home/user/dvb-srate%3D2800000' failed
[0x7f2cf4000b28] main input error: Your input can't be opened
[0x7f2cf4000b28] main input error: VLC is unable to open the MRL 'file:///home/user/dvb-srate%3D2800000'. Check the log for details.
[0x1173b98] main playlist debug: dead input
[0x7f2cf0005538] main stream output debug: destroying useless sout
[0x7f2cf0004fc8] main stream out debug: destroying chain... (name=standard)
[0x7f2cf0004fc8] main stream out debug: removing module "stream_out_standard"
[0x7f2cf0000db8] main mux debug: removing module "mux_ts"
[0x7f2cf0001048] main access out debug: removing module "access_output_http"
[0x7f2cf0000a98] main http host debug: waitpipe: object killed
[0x7f2cf0000a98] main http host debug: HTTP host removed
[0x7f2cf0001048] access_output_http access out debug: Close
[0x7f2cf0004fc8] main stream out debug: destroying chain done
[0x7f2cf4000b28] main input debug: TIMER input launching for 'dvb-srate=2800000' : 2.366 ms - Total 2.366 ms / 1 intvls (Avg 2.366 ms)
[0x1173b98] main playlist debug: changing item without a request (current 2/3)
[0x1173b98] main playlist debug: nothing to play
For an input like below I get a different error:
vlc -vvv dvb-s:// :dvb-adapter=1 :dvb-frequency=11096000000 :dvb-srate=30000000 :dvb-polarization=H :dvb-fec=5/6 --sout '#standard{access=http,mux=ts,dst=:port_number}'
The error is:
main access debug: looking for access module: 1 candidate
[0x7f9978006d58] dtv access error: cannot access DVR: Permission denied
[0x7f9978006d58] main access debug: no access module matching "dvb-s" could be loaded
[0x7f9978006d58] main access debug: TIMER module_need() : 0.447 ms - Total 0.447 ms / 1 intvls (Avg 0.447 ms)
[0x7f997c000b28] main input error: open of `dvb-s://' failed
[0x7f997c000b28] main input error: Your input can't be opened
[0x7f997c000b28] main input error: VLC is unable to open the MRL 'dvb-s://'. Check the log for details.
[0x18d3b88] main playlist debug: dead input
[0x7f9978000e18] main stream output debug: destroying useless sout
[0x7f99780011f8] main stream out debug: destroying chain... (name=standard)
[0x7f99780011f8] main stream out debug: removing module "stream_out_standard"
[0x7f9978005438] main mux debug: removing module "mux_ts"
[0x7f9978003ff8] main access out debug: removing module "access_output_http"
[0x7f9978004f88] main http host debug: waitpipe: object killed
[0x7f9978004f88] main http host debug: HTTP host removed
[0x7f9978003ff8] access_output_http access out debug: Close
[0x7f99780011f8] main stream out debug: destroying chain done
[0x7f997c000b28] main input debug: TIMER input launching for 'dvb-s://' : 3.619 ms - Total 3.619 ms / 1 intvls (Avg 3.619 ms)
[0x18d3b88] main playlist debug: changing item without a request (current 0/1)
[0x18d3b88] main playlist debug: nothing to play
Could you understand what the problem is? I think sending the stream is ok. Because when I send a video found on my home directory over the network I can take it from another computer. So I think that the problem is to open the dvb-s signals with vlc.
miyop
