DOWNLOAD:
DVBDream
Progdvb
VE2HRJ Wrote:Hi all, I bought the 6925 and received it last week. Today I build a new PC with winXP and install the card. All fine and working.
I look at the CD that come with the card and verified the version and dnload the latest one and installed.
All seem to be ok, but when I try to use DVBDream from this site, I cannot scan unless I buy the full version from DVBDream site... that have only the v22b not v22d.
Since your saying that version is modified for TBS cards.... So I don’t understand why I have to buy a version that might not have the proper setting for my card or options.
For me that is useless and since I cannot even try to get any signal... I guess you're working for nothing.
TBSViewer is not better either, it was working just before I install DVBDream … now it say that the card is not active... another one to delete …
I tried Crazyscan and it work great, got to test it and found 28 transponders on horizontal …
That is the only thing working but I cannot see any channel that is just for testing.
Is here any version that I can really see and buy a version that I like instead of tries that don’t work?
The card works for that I’m happy, but no software to use, that is bad.
Hope that help someone.
Richard.
crazycat Wrote:Usual modern PC DVB devices shipped with drivers and some OEM DTV soft with restricted features. Often shipped some OEM DVBViewer (without plugins support and work only with vendor hardware). Last time available 'restricted' OEM DVBViewer - http://www.dvbdream.org/oem.php
Now ProgDVB TBS OEM is usual standard build ProgDVB - http://www.progdvb.com/download_progdvb.html (no diseqc, PIP, record support).
P.S. Better buy modern PC DVB hardware with stable drivers and wide soft support. And next install more suitable soft (linux/windows, free- or payware).
P.P.S. If you want hardware+soft from box - buy STB
