TBS 6984 - DOA Product
Postby pluto30306 » Fri Dec 07, 2012 8:44 pm
Question - the instructions for the card are at best GARBAGE!
Their are no instructions on installing the card..ie. the card came with one power plug with a 3 way spliters....are we suppose to use all three or none..or is one oK.
Either case, how does one test to see if the card is working....my card gets no signal during scans.
Using windows 7 32bit with the latest drivers...and DVBDream.
pluto30306
Re: TBS 6984 - DOA Product
Postby steven » Mon Dec 10, 2012 10:38 am
Hi pluto30306
Would you mind telling us that which satellite you are using and what's your LNB type.
And can you give us your DVBDream LNB setting picture?
