TBS Linux driver is updated to V121119
DOWNLOAD
* Add support for dBm reporting with TBS 6922.
* Improve performance of TBS 6922 and TBS 6985 in case lock can't be acquired.
Try and enjoy!
TBS support team
jumbleoak Wrote:Hello,
I see this release contains updates for the TBS6992 specifically.
However, there is no build README for the TBS6992.
Which README should I use for the TBS6992 ?
(My OS = ArchLinux 3.6.10)
Thanks.
orekhovav Wrote:Thanks, waiting for support MultiPLP in Linux
(they already validated implementation but from labs test only)euro_support@tbsdtv.com Wrote: [...] no matter of anything else it's best to just get 5880, test in Windows with the live signal and if it works then we will add the same support in the Linux drivers.
