TBS 5880 Sweden(Solved)
Postby seglarvatten » Wed Nov 14, 2012 1:27 am
I have testet driver 1.0.0.4 for tbs 5880 with win 7 MCE i can't get signal on any of the t2 HD channels in Sweden is it hardware or software relatet problem?
seglarvatten
Re: TBS 5880 Sweden
Postby steven » Fri Nov 16, 2012 9:55 am
Would you mind having a test with this new beta driver:
https://hotfile.com/dl/179529730/ed2b34 ... 5.zip.html
Which should be ok now. You can have a test with our latest DVBdream or TBSViewer.
Re: TBS 5880 Sweden
Postby seglarvatten » Fri Nov 16, 2012 6:12 pm
Hello
Thank you for your work!
Now I find Hd-channels on MUX 6 but no signal, find nothing on MUX 7.
Is it ok if I post the beta driver on swedish Forums?
seglarvatten
Re: TBS 5880 Sweden
Postby seglarvatten » Tue Nov 20, 2012 11:36 pm
I have now tried driver dated 2012-11-16 but i get bluescreen in windows
I am using win7x86 with two tbs5880 and smartwi.
seglarvatten
Re: TBS 5880 Sweden
Postby steven » Wed Nov 21, 2012 4:51 pm
Do you have tested our latest driver release the day before yesterday.
http://www.tbsdtv.com/download/document ... .0.0.4.zip
Re: TBS 5880 Sweden
Postby seglarvatten » Wed Nov 21, 2012 7:49 pm
Thank´s
With the driver dated 2012-11-19 I find all of the HD-channels and no bluescreeens.
Thank you for the good and hard work you ar doing!
RGDS
Seglarvatten
seglarvatten
Re: TBS 5880 Sweden
Postby steven » Thu Nov 22, 2012 4:43 pm
Hi seglarvatten
Thanks for your update. :)
