TBS6928, tvheadend and oscam
Postby demax » Sun Nov 04, 2012 7:04 am
Has anyone been able to make the cardreader in TBS6928 wo work with OSCAM or any other software cam compatible with tvheadend?
I do not want to share channels, just watch them. I've got an paid subscription and was planning to use the the 6928 and tvheadend on a linux box with my xbmc-based media center. Problem is that tvheadend does not support hardware CAMs so I thought I'd work around it with OSCAM or anything else that might work with the card reader on the 6928.
Anyone got any suggestions on how to proceed? No success with OSCAM so far.
demax
Re: TBS6928, tvheadend and oscam
Postby steven » Thu Dec 13, 2012 7:17 pm
Hi demax
We have tested OSCAM with TVHeadend ,and it works ok, but it is not very easy,the configuration is very complex.
more information i have send to your PM message box,Please have a check.
Postby schmichri » Tue Jan 15, 2013 2:49 am
Hello steven,
I have the same issues: a tbs 6928, xbmc with tvheadend. Could you please send me this infos per PM about OSCAM too? My SKY Channels do not want to work (I think they hate me :mrgreen: )
Thanks a lot.
Kind regards,
Christian
schmichri
Postby mathias » Wed Jan 16, 2013 5:16 am
Hi TBS Team.
I'm using your card TBS6928 with yaVDR 0.5 and a standard Telenor Conax CAM. The distribution is based on Ubuntu 12.04. VDR implements the upper layers of a CAM and relies on the SW drivers to access the CAMs.
My VDR konfiguration will read access a VIACESS CAM but not my the Telenor CAM.
The Telenor CAM with my Canal Digital Nordic Card is working with the Windows Drivers of the TBS6829.
Motivated through this thread, I have compiled und installed OSCAM on my Ubuntu 12.04.
1. Could you please provide me the OSCAM.SERVER reader settings. I have compiled OSCAM with webif and USB Reader support. To access the TBS6928, which additional compiler settings for OSCAM do I need ?
2. If the Telenor Conax CAM is not support with your current LinuxDriver, which CONAX CAM is ? Please provide vendor and card details.
Mathias
mathias
Postby steven » Thu Jan 31, 2013 5:18 pm
Hi Mathias
Would you mind sending your detail information to our euro_support#tbsdtv.com, writing the The Telenor CAM detail information.
If possible. we will have a test with this CAM.
Postby jtrefil » Fri Mar 22, 2013 9:42 pm
Hello Steven,
I have the same issues: a tbs 6928, xbmc with tvheadend + Skylink provider.
Thanks a lot.
Kind regards,
Honza
jtrefil
Postby FredOger » Fri May 24, 2013 2:46 pm
Dear Steven,
I'm in the exact same situation : xbmc + tvheadend and would like to watch encrypted channels through my official Telesat (canaal digital) subscription. Could you send me the info per PM about configuration of OSCAM with CI reader of the 6928 ?
Thanks a lot,
Fred.
FredOger
Postby phattyassid » Fri May 24, 2013 4:01 pm
Hi all,
Same for me, so if someone can send me the oscam configuration too it would be greatly appreciated
thanks
Bob
phattyassid
Postby jeroen » Fri May 24, 2013 11:06 pm
And me too.
Would help a lot in my testing if I can clear out the CI interface
jeroen
Postby bkipper » Tue Jun 18, 2013 8:28 pm
I have exactly the same question. Getting the cam to work in tvheadend through oscam so we can use xbmc for live tv would be awesome. Could you please provide the working oscam config?
bkipper
