TBSviewer v20120816
TBSviewer v20120816
Postby warumnix » Fri Nov 02, 2012 6:05 pm
TBSviewer is updated to v20120816, with new OSD design added, more user-friendly. ;)
DOWNLOAD
warumnix
Re: TBSviewer v20120816
Postby SquareEyes » Tue Nov 06, 2012 8:51 am
Thanks warumnix, nice design!
I have noticed a few anomalies though so wanted to leave feedback:
I notice the new version OSD mini EPG only shows the programme name, it would have been better to also include the programme start and end times which previous version v20120607 did.
It was useful to know quickly what time current programme was ending and next programme starting without needing to look at full TV guide. The programme guide from the OSD Menu Bar also does not show start and end times of each programme slot, I can only get an estimate from the timeline. I still have to right click and access the TV Guide to get exact timings.
I also notice that the channel list in the Programme Guide is not in the same channel name sort order that I have in the channel scanlist on the right hand side.
Keep up the good work and design! :)
SquareEyes
Postby steven » Tue Nov 06, 2012 9:11 am
Hi SquareEyes
Thanks for your feedback ,we will contact this with DVBViewer, if any update about this,we will contact you
as soon as possible.
Postby SquareEyes » Tue Nov 06, 2012 7:11 pm
Thanks Steven. I know they're only cosmetic changes and opinion differs from person to person so I don't expect any changes until the next release. ;)
SquareEyes
Postby steven » Wed Nov 07, 2012 9:46 am
Hi SquareEyes
We will discuss this with DVBViewer ,as you said that maybe different people have different opinion.
In a short any update we will release it as soon as possible.
Thanks again for your advise. :)
Postby SquareEyes » Fri Nov 16, 2012 3:06 am
I also noticed in this current version v20120816 that Picture In Picture is no longer in the context menu.
Picture In Picture was in v20120607 even though it PIP did not have aspect ratio settings.
It would be useful if you could get DVBViewer to include the option of Picture In Picture and also be able to have a context menu in the Picture In Picture window so that it is possible to record programme and control size and aspect ratio too. After all - TBS do sell dual and quad tuner so it should make sense to allow the supplied software to use the features of the hardware?
SquareEyes
Postby far » Fri Nov 16, 2012 8:17 am
Remote doesn't work either by the way - option is there but no way to configure it or use it :(
far
Postby SquareEyes » Fri Nov 16, 2012 7:21 pm
Thanks Far.
I have decided to revert back to v20120607 as the auto OSD bar that keeps coming on over the picture is becoming really annoying along the bottom of the screen and over the programme.
Can't see any improvement in v20120816 other than just the OSD and cosmetic font changes in config screens. It's hard to believe there's actually less features in the latest version.
SquareEyes
