Card Has Worked Fine For 6Mths Now Playing Up
Postby ArferDaley » Fri Oct 26, 2012 11:22 am
hi
i have been useing this card from last christmas but now i am geting alot of record corruption
when i transcode win7 wtv files to dvrms it takes a long time
and then once i import into video redo quite a few times i get the message to run quick stream fix
i never used too get these problems just on the odd accasion any idead anyone please ???
ArferDaley
Re: Card Has Worked Fine For 6Mths Now Playing Up
Postby CyberSimian » Fri Oct 26, 2012 5:41 pm
ArferDaley Wrote:I have been using this card from last Christmas but now i am getting a lot of record corruption; when I transcode win7 wtv files to dvrms it takes a long time
Have you been affected by the recent retune(s) that were necessary in the UK due to "the powers that be" shuffling the channels around the broadcast spectrum? You might now be receiving from a different transmitter that has a much weaker signal. See this thread:
http://www.thegreenbutton.tv/forums/viewtopic.php?f=5&t=3031
-- from CyberSimian in the UK
CyberSimian
Postby ArferDaley » Sat Oct 27, 2012 5:10 am
thanks for the info i know this week have had to retune twice only seems to be BBC thats causing the problem
will have a read of that link will get back to ya if i have any info
cheers for now
ArferDaley
Postby ArferDaley » Sun Oct 28, 2012 10:09 am
hi
i deleted chan listt in win7 + disabled media centre then reinabled and run clean setup MCE again all now seems too be working so was poss corrupt or maybe
just bogged down
ArferDaley
