Problem with 8920 card
Postby hno2005 » Sat Oct 20, 2012 3:27 pm
HI,
I have been using TBS 8920 for almost 2 years . This week Strange problem has happened. Everytime I open DVB Dream it doesn’t download display and sound but I have signal .
I have this problem with downloading from satellite .
I have updated to the letterset driver and I have tested it in another computer but the problem does not solve .
This is the picture of dvbdream
What’s the problem and how can I solve this?
hno2005
Re: Problem with 8920 card
Postby hno2005 » Sun Oct 21, 2012 3:08 pm
I need some support please
hno2005
Postby steven » Mon Oct 22, 2012 9:21 am
Hi hno2005
From the picture you give to us, it is like that your device have not received the TS stream,
In your Device manage , can you see the TS capture Device?
Postby hno2005 » Mon Oct 22, 2012 2:23 pm
Thanks for your reply
Yes ,I can see that and I have attached an image .
hno2005
Postby hno2005 » Tue Oct 23, 2012 1:05 pm
There is a problem with the TBS 8920 TV capture . When I open the properties of that in Computer management ,the driver status is this "No drivers are installed for this device. " .
Why is that?I have tried 1.04 and 1.06 drivers but the problem is stil exists.
And there was no problem with other 8920 parts.
What should I do ?
hno2005
Postby crazycat » Wed Oct 24, 2012 12:16 am
hno2005 Wrote: When I open the properties of that in Computer management ,the driver status is this "No drivers are installed for this device. " .
This correct - no drivers for second device entry (TS capture). Maybe you install before some another CX23880-3 or BT878 device (Analog or Digital TV tuner card ) ?
Postby hno2005 » Wed Oct 24, 2012 1:25 pm
Nope ,
I think there is a hardware problem with my card . What do you think may be cause the problem and Is there any way to fix it ?
hno2005
Postby steven » Fri Oct 26, 2012 9:59 am
Hi hno2005
if TBS 8920 TV capture's driver have not installed ,you will can not get the TS stream,So Can you have a test
just delete all the TBS8920 driver in C:\Windows\System32\drivers folder,and install TBS8920's driver again.
Or simple way reinstall your windows then install TBS8920's driver.
