TBS6981 scan-s2
TBS6981 scan-s2
Postby xunil2003 » Wed Sep 26, 2012 11:09 pm
Excuse me if I have trouble to speak your language, I'm French.
I'm on Kubuntu 4.10 x86_64
I would like to do a search of the channels satellite.
Apès read the readme.txt file I can not run a scan-s2 for /dev/dvb/adapter0/frontend0 and /dev/dvb/adapter0/frontend1.
Can you explain how it works.
laurent@PC-ubuntu:~$ ls /dev/dvb
adapter0  adapter1
laurent@PC-ubuntu:~$ sudo scan-s2 -5 -o vdr -x 0 -s 2 -S 0 -v -U -O S19.2E dvb-s/Astra-19.2E > channels.conf
API major 5, minor 4
ERROR: Cannot open rotor configuration file 'rotor.conf'.
scanning dvb-s/Astra-19.2E
ERROR: cannot open 'dvb-s/Astra-19.2E': 2 No such file or directory
ERROR: initial tuning failed
dumping lists (0 services)
Done.
laurent@PC-ubuntu:~$ scan S1 11778000 V 27500000 3/4 35 QPSK
scanning S1
ERROR: cannot open 'S1': 2 No such file or directory
Done.
Thank you.
xunil2003
Re: TBS6981 scan-s2
Postby SergioDanielG » Thu Sep 27, 2012 6:19 am
Hi xunil2003.
See that all errors is about no such file, the file not founded are needed and it's content list of transponders to scan.
Try moving to TBS drivers folder, for example for mi /usr/src/tbsDrivers
then try to scan
sudo scan-s2 -5 -o vdr -x 0 -s 2 -S 0 -v -U -O S19.2E astra_scan-s2.conf > channels.conf
In this case you are using adapter 0. To use second adapter you must to add "-a 1" parameter.
Best regards.
SergioDanielG
Re: TBS6981 scan-s2
Postby xunil2003 » Thu Sep 27, 2012 3:01 pm
I do not understand how the scanner adapter 1 and 2?
Can you show me an example for the adapter 1 and 2.
There are two cards TBS (TBS 6220 adapter 0 and TBS 6981 adapter 1 / 2) scan-s2 on the adapter must be 1 or 2 and not on adapter 0.
See below the numbers of adapters cards TBS.
laurent@PC-ubuntu:~$ dmesg | grep DVB
[   12.015733] DVB: registering new adapter (SAA716x dvb adapter)
[   12.204928] DVB: registering adapter 0 frontend 0 (TurboSight TBS 62x0 DVBT/T2 frontend)...
[   14.565536] DVB: registering new adapter (cx23885[0])
[   14.565540] DVB: registering adapter 1 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[   14.597644] TurboSight TBS698x Dual DVB-S2 card port0 MAC=00:22:ab:f0:2b:de
[   14.682158] DVB: registering new adapter (cx23885[0])
[   14.682164] DVB: registering adapter 2 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
[   14.715251] TurboSight TBS698x Dual DVB-S2 card port1 MAC=00:22:ab:f0:2b:df
adapter0  adapter1  adapter2
Cordially.
xunil2003
Re: TBS6981 scan-s2
Postby SergioDanielG » Fri Sep 28, 2012 12:18 am
Hi xunil2003.
Ok, you have two TBS cards and TBS6981 have adapters 1 and 2.
In this case you must to indicate wich adapter are you using to scan. For example:
scan-s2 -a 1 ... Indicate to use first adapter of your TBS6981
scan-s2 -a 2 ... Indicate to use second adapter of your TBS6981
Best regards.
SergioDanielG
Re: TBS6981 scan-s2
Postby xunil2003 » Fri Sep 28, 2012 4:59 am
Hello
I do not understand why it does not work
laurent@PC-ubuntu:~/deb/Ubuntu-12-04/Brothers-MFC-6490CW/printer$ scan-s2 -a 1 -5 -o vdr -x 0 -s 2 -S 0 -v -U -O S19.2E astra_scan-s2.conf > channels.conf
scanning astra_scan-s2.conf
using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0'
ERROR: cannot open 'astra_scan-s2.conf': 2 No such file or directory
Done.
Thank you.
xunil2003
Re: TBS6981 scan-s2
Postby SergioDanielG » Fri Sep 28, 2012 9:32 am
Hi xunil2003
That not works because the file astra_scan-s2.conf doesn't exist or you are not in same path of this file.
Use full path to astra_scan-s2.conf and try againg.
Best regards
SergioDanielG
Re: TBS6981 scan-s2
Postby xunil2003 » Sat Sep 29, 2012 4:19 am
I placed in the directory
laurent@PC-ubuntu:~$ cd /home/laurent/pilotes/TBS6981-linux-drivers_v120827/scan-s2
laurent@PC-ubuntu:~/pilotes/TBS6981-linux-drivers_v120827/scan-s2$
Then I created the file astra_scan-s2.conf because there is no
laurent@PC-ubuntu:~/pilotes/TBS6981-linux-drivers_v120827/scan-s2$ touch astra_scan-s2.conf
laurent@PC-ubuntu:~/pilotes/TBS6981-linux-drivers_v120827/scan-s2$$
Then I rerun the command
laurent@PC-ubuntu:~/pilotes/TBS6981-linux-drivers_v120827/scan-s2$ scan-s2 -a 1 -5 -o vdr -x 0 -s 2 -S 0 -v -U -O S19.2E astra_scan-s2.conf > channels.conf
Done.
It responds fault
Cordially.
xunil2003
Re: TBS6981 scan-s2
Postby SergioDanielG » Sat Sep 29, 2012 6:33 am
Hi xunil2003.
To scan with szap-s2 you need a file with transponder list, not an empty file. When you do "touch astra_scan-s2.conf", your are making an empty file and this is not useful.
A file with transponders look like this:
S 10500000 H 27500000 AUTO AUTO AUTO
S 10550000 V 30000000 AUTO AUTO AUTO
One line per transponder to scan. Seen in tbs driver, download it again and use and use astra_scan-s2.conf from there.
Best regars.
PS. Do you speak spanish?
SergioDanielG
Re: TBS6981 scan-s2
Postby xunil2003 » Sat Sep 29, 2012 8:07 am
Hola,
Sí Hablo un poco español.
Hice una prueba, pero dice que
FE_SET_PROPERTY TUNE failed: Invalid argument
He buscado en google "Astra tranponder" No he encontrado nada, aparte de esta
http://www.pirmasoft.com/astra/e_indivi.htm
Nada que ver con esto, cómo ajustar
Sobre todo necesitamos saber todo lo que hay en el satélite (TV / radio / Internet)
Sabe usted que el software "Skynet-Linux"
Yo uso KDE "Kaffeine" para ver la televisión por satélite
Por internet "Skynet-Linux"
prueba
initial transponder DVB-S  10550000 H 27500000 AUTO AUTO AUTO
initial transponder DVB-S2 10550000 H 27500000 AUTO AUTO AUTO
initial transponder DVB-S  10550000 V 30000000 AUTO AUTO AUTO
initial transponder DVB-S2 10550000 V 30000000 AUTO AUTO AUTO
>>> tune to: 10550:hS0:S19.2E:27500:
DiSEqC: uncommitted switch pos 0
DiSEqC: switch pos 2, 18V, loband (index 9)
DVB-S IF freq is 800000
----------------------------------> Using DVB-S2
>>> tune to: 10550:hS1:S19.2E:27500:
>>> tune to: 10550:vS0:S19.2E:30000:
DiSEqC: switch pos 2, 13V, loband (index 8)
>>> tune to: 10550:vS1:S19.2E:30000:
Done.
Gracias
xunil2003
Re: TBS6981 scan-s2
Postby SergioDanielG » Sat Sep 29, 2012 9:27 am
Hola xunil2003.
Tal vez en español nos entendamos mejor.
Yo solía utilizar los datos de http://www.fastsatfinder.com/bin/Transponders.zip
Ahí un un gran listado de archivos según la numeración de satélites con un formato distinto al requerido por sza-s2, pero con un script en python (adjunto) lo transformo y guardo para escanear con szap-s2.
Bien. Szap-s2 va a servir para obtener los pids de TV y Radio, pero no de internet.
Para internet yo uso "dvbsnoop -adapter 0 -s pidscan"
Espero esto le sea útil.
Saludos cordiales
modScanConf.py.tar.gz
(547 Bytes) Downloaded 590 times
SergioDanielG
