Solution for Mediaportal Sleep problem
Postby steven » Fri Aug 24, 2012 2:02 pm
Hi All
Some users have reported that after suspend the mediaportal server config says
no card available, but with other DVB software it is ok, such as media center.
Two ways to solve it:
1st:
Please read this topic:
http://wiki.team-mediaportal.com/1_MEDI ... _detection
This is because MediaPortal TV Server only detects tuners on startup, not while it is running. So if the MediaPortal TV Server service starts before the driver/hardware is initialised by the OS, then the tuners will not be detected.
So you need to increase the delay time.
2nd:
Stop Windows adjusting the power level for PCI Express devices, switch the power saving off.
If you are experiencing such problem, just have a try with either solution.
Any problem or feedback are welcome to post here.
Re: Solution for Mediaportal Sleep problem
Postby te3hpurp » Tue Apr 28, 2015 10:43 am
Hi.
I've tried all these solutions and some from MediaPortal forums also(including 1.0.5... tbscicapi.dll). The thing is that
after resume tuner tries to to tune and tune command is succes, but there is no data incoming, meaning that pmt cannot be parsed from stream, or no stream is coming in. Do you have newer beta driver available that is not in official download section ?
te3hpurp
Postby te3hpurp » Wed Apr 29, 2015 10:49 am
Sorry.
I was using an old driver. With 1.0.0.5 resume works okay. It just takes awhile before tuner is ready. 30sec or so.
te3hpurp
