Solution for Mediaportal Sleep problem
Postby steven » Fri Aug 24, 2012 2:02 pm
Hi All
Some users have reported that after suspend the mediaportal server config says
no card available, but with other DVB software it is ok, such as media center.
Two ways to solve it:
1st:
Please read this topic:
http://wiki.team-mediaportal.com/1_MEDI ... _detection
This is because MediaPortal TV Server only detects tuners on startup, not while it is running. So if the MediaPortal TV Server service starts before the driver/hardware is initialised by the OS, then the tuners will not be detected.
So you need to increase the delay time.
2nd:
Stop Windows adjusting the power level for PCI Express devices, switch the power saving off.
If you are experiencing such problem, just have a try with either solution.
Any problem or feedback are welcome to post here.
Re: Solution for Mediaportal Sleep problem
Postby Bonzey » Thu Nov 22, 2012 5:13 pm
Hello
Its a problem with a other software too.
I use DVBVIEWER and DVBDREAM when i start my pc than the software knows the DVB card.
After a reboot/standby the software cannot find the card but in the hardware overview from windows the card is detectet without errors.
When i do a shudown and a restart the software knows the card.
i use the latest driver 1.0.1.16 under win7 x64
br
Bonzey
Postby steven » Thu Nov 29, 2012 4:14 pm
Hi Bonzey
Would you mind giving us more detail information ,such as which operation you are using.
Which card? Do you have used SSD(solid state disk)?
Postby Bonzey » Thu Dec 20, 2012 10:53 pm
Hello
I use Windows7x64 Ultimate, Hardware: Samsung SSD 830 ,CPU Phenom IIx6 1055T, Mainboard Asus M5A88-M EVO , 8GB RAM 1866 Gskill. and the TBS card 6925.
Tried all drivers its always the same problem Hardware is correctly detectet when i do a shudown and a restart the software knows the card.
Br Bonzey
Bonzey
Postby PetoBB » Thu Jun 05, 2014 6:08 pm
Any solutions for Bonzey problem with detect card via software DVBViewer, DVBDream,TSReader etc.... i have same problem. TBS 6925 normal install and detect on Windows device without errors, i use the latest driver 1.0.1.22 under win7 ULTIMATE x64 SP1
My PC: Intel i7 3770k, 16GB DDR Kingston, MB Gigabyte Sniper M3, SSD Samsung PRO 128GB, power 550W and use TBS 6925 card.
I try this card on two PC with WIN 7 ULTIMATE 64bit and one PC with WIN XP PRO 32bit and always same problem (TBS software no detect HW TBS 6925).
Bad TBS 6925 card?
PetoBB
Postby MorrisLow » Wed Oct 24, 2018 10:04 pm
PetoBB Wrote:Any great hosting solutions like Bluehost for Bonzey problem with detect card via software DVBViewer, DVBDream,TSReader etc.... i have same problem. TBS 6925 normal install and detect on Windows device without errors, i use the latest driver 1.0.1.22 under win7 ULTIMATE x64 SP1
Bad TBS 6925 card?
Did you try this card with Windows 10, PetoBB?
MorrisLow
