Win7 x64 Media Center and the IR remote
Postby MrPix » Sun Jul 24, 2011 12:17 am
I recently purchased a TBS 6981. The card works great in Media Cenetrm but i can't get the remote to work at all. I notice the driver supports HID, so I would assume that this is the remote/sensor.
I can find no intstructions with the product on how I get the remote working with Media Center, please can you help me :oops:
MrPix
Re: Win7 x64 Media Center and the IR remote
Postby steven » Sun Jul 24, 2011 9:34 am
In human input device ,do you have seen TBS6981 VHID device?
if you have not seen the device,just reinstall tbs6981's driver use setup.exe file.
Postby MrPix » Sun Jul 24, 2011 2:45 pm
Hi steven,
Yes I have that, but the remote does not seem to work at all in Win7 x64 media center. How can I make it work please?
MrPix
Postby steven » Tue Jul 26, 2011 4:58 pm
MrPix Wrote:Hi steven,
is it ok with dvbdream?
if it not,i think maybe the remote is broken.
Postby MrPix » Fri Jul 29, 2011 10:08 pm
steven Wrote:Hi
It doesn't work with dvbdream either, I just spent an hour installing/scanning etc.
The sensor is plugged in to the back of the card and in full view of the remote.
I have tried all the remote options in dvbdream ... Native etc.
What should I do, I have owned it less than a week?
MrPix
Postby steven » Sun Jul 31, 2011 6:28 pm
Hi MrPix
I think maybe your remote is broken,Would you mind send an email to our support@tbsdtv.com,we will give you a solution.
Postby MrPix » Sun Jul 31, 2011 9:57 pm
steven Wrote:Hi MrPix
Hi Steven,
Email sent, thanks.
MrPix
