TS and W7,64Bit
TS and W7,64Bit
Postby t6922 » Mon Aug 06, 2012 4:21 pm
hi,i have q-6922
my windows 7-64 bit.
i,m using latest driver for this card and tsreader 2.8.46b and latest bdasource 1.0.8.4,but ay time i,m perform tsreader,can,t loched on my frq,so for solve it i,m want perform another prgram for locked on my frq but atall no let me beacuse get unable start run graph or tbs 6922 no start and other error,i,m testet with progfinder,tbsipdata,transedit and ,,, but atall no locked on my frq and no let perform other program for locked on that frq,but my friend have 5922 and w7,atall have not this problem,he perform tsreader so perform progfinder and locked on frw and using very good from tareader!!
i,m contact with company of qbox but only tell me use form tsbdasource 1.0.8.3,imn do it,but atall no get any reply?!!! :geek:
so i,m must what are doing?please help to me.
thanks.
t6922
Re: TS and W7,64Bit
Postby t6922 » Thu Aug 09, 2012 4:26 am
nothing?!!!
i,m atall can,t perform to program togeter but i,m tested in 5922 atall no problem,first run tsreader so perform progfinder for lock on signal and all things is ok?!!!!!but in 6922 no!!!!!
t6922
Re: TS and W7,64Bit
Postby t6922 » Fri Aug 10, 2012 3:09 am
hi
yes master,i,m tested them befor.but have same problem.
t6922
Re: TS and W7,64Bit
Postby t6922 » Sun Aug 12, 2012 9:58 pm
Master team please help to me.
t6922
Re: TS and W7,64Bit
Postby steven » Tue Aug 14, 2012 11:46 am
Hi t6922
Can we connect to your PC to have a check about this problem?
If ok,you can direct send your problem and your TeamViewer ID and password.
or remote IP and user name ,password to our support@tbsdtv.com
Re: TS and W7,64Bit
Postby t6922 » Wed Aug 15, 2012 4:15 am
steven Wrote:Hi t6922
hi
thanks master,mean this problem from my system no from drivers of card?
t6922
Re: TS and W7,64Bit
Postby steven » Thu Aug 16, 2012 10:45 am
Hi t6922
This is why we want to connect to your PC to have a check
about this problem. :)
Wish you can understand us.
