cx23885 driver
cx23885 driver
Postby montenis » Wed Aug 01, 2012 1:42 pm
Good day,
recently i installed TBS6981 on my debian linux machine, and it works good. The situation is as follows - i've allso got "terratec cinergy t pcie dual" dvb-t/c card installed. When i install TBS driver, support for cubergy gets broken. As i looked into v4l sources provided by tbs, there is no support for the cinergy board, but recent v4l releases do have support for it. I have tryed to patch cx23885 module, but drxk and some other things allso needs to be pached. Maybe someone has the same situation ? I'm on kernel 3.4 btw.
Thanks !
montenis
Re: cx23885 driver
Postby abondu » Thu Oct 11, 2012 4:58 pm
Did you get any solution to this problem?
I am having similar issues with a TBS 6922 DVB-S/S2 card. I have a CINERGY PCIe DUAL DVB-T card that worked perfectly with a 3.5.0-17-generic 64 bits kernel in an ubuntu 12.04.1 server. When I built TBS drivers and intalled them, they overwrited module cx23885.ko that was the one that controled CINERGY and TBS cards. I am thinking about modifying cx2388* sources and rename them in order to create a new module that only manages TBS card. I dont know if it would work but it is an idea...
abondu
Re: cx23885 driver
Postby SergioDanielG » Sat Oct 13, 2012 9:23 am
Hi abondu
cx23885 driver is part of linux kernel. Try reinstalling debian's kernel and use your TBS6981 card. If all is ok, try installing your "terratec cinergy t pcie dual" dvb-t/c card and drivers for it.
Hi montenis, try the same.
Best regards.
SergioDanielG
Re: cx23885 driver
Postby montenis » Thu Jan 24, 2013 12:46 am
SergioDanielG , i gave up, tbs drivers owerwrite v4l drivers. TBS should use new v4l sources , then it would work, but as i see they update only tbs part of the driver, and keep old v4l base. Kind of sad, this card ir really good...
montenis
