No vertical polarization channels at high frequencies
Postby ccristal » Sun Jul 29, 2012 8:39 pm
Hi!
I have a QBOX CI with the latest drivers installed (1.0.2.7), connected to a Win7-64 box.
I use DVBViewer 4.9.6.20.
I am experiencing problems viewing all the channels with vertical polarization at frequencies higher than 12000 MHz. One example is BBC Olympic 2 HD, on Astra 28.2E, which, according to http://www.bbc.co.uk/reception/info/bbc_olympics_channels.shtml, should be located at 12129MHz, 29500 symbol rate, Vertical polarization.
My LNB skew is OK, since I have also double checked with a standard Sky+ HD box, and I am able to receive those channels.
Any idea?
Thank you!
ccristal
ccristal
Re: No vertical polarization channels at high frequencies
Postby ccristal » Thu Aug 02, 2012 8:55 pm
Any news? Is anyone able to reproduce the problem?
Thank you!
ccristal
ccristal
Postby steven » Thu Aug 09, 2012 2:43 pm
Hi ccristal
Do you mean that vertical polarization at frequencies higher than 12000 MHz all have problem?
So what about the Horizontal ,is it ok?
And can you give us your DVBViewer LNB's setting picture?
Postby ccristal » Sun Aug 26, 2012 10:49 pm
steven Wrote:Hi ccristal
Yes, horizontal is ok.
Is the one attached the picture you asked for? If not, can you please explain how do I navigate to the screen you need?
Thanks!
ccristal
Postby steven » Tue Aug 28, 2012 11:43 am
Hi ccristal
What about the low band vertical? Is it ok?
Postby ccristal » Mon Sep 03, 2012 12:46 am
Yep, low frequency vertical is perfect.
ccristal
ccristal
Postby steven » Mon Sep 03, 2012 9:59 am
Hi ccristal
It is so strange, Would you mind using our latest OEM-DVBDream to have a test:
http://www.tbsdtv.com/download/document ... _oem_3.zip
and send your test report here. :)
Postby steven » Tue Sep 04, 2012 2:51 pm
Hi ccristal
Would you mind using our latest IPTOOL
http://www.tbsdtv.com/download/document ... .0.3.5.zip
to have a lock about the high frequencies vertical polarization
Transponder.
Postby ccristal » Fri Oct 05, 2012 4:16 am
Hi, Steven, sorry for the delay!
What exactly am I supposed to do with the IPTool you gave me to check for high frequency vertical polarization channels?
Thank you!
ccristal
Postby ccristal » Fri Oct 05, 2012 4:39 am
Hi Steven!
Here attached is the scan log collected from the OEM DVBDream.
As you can see, all the vertical transponders starting from 11740KHz came back as "No signal".
OEM_DVBDream_Scan.zip
(4.26 KiB) Downloaded 298 times
ccristal
