If we talking about signal meters - i got small bug here: if I watch TV for longer time (few hours) - Level will jump suddenly to 99%, Quality will fall to 0%, but despite that - receiving is still ok. If I will switch to other frequency - Level & Quality will be back to normal values, but after some time they again switch to 99% & 0% (always the same values, no matter what frequency I will watch longer).
Reading OK:
- signal_1.png (1.15 KiB) Viewed 11907 times
Reading after few hours of watching (despite values - channel still wotking, signal is present, but not reported anymore):
- signal_2.png (1.01 KiB) Viewed 11907 times
About signal bars efectiveness: if You will use CrazyScan - You will see that TBS6925 RF Level values got small differences. At Hot Bird I got correct signal at RF Level 40,6 dB and no signal at 41,6 dB - just 1 dB difference. When You scan the same band from the same satellite at Prof7301 You will see, that RF Level defferences are bigger. As Level & Quality meters are based on RF Level and C/N - IMHO small differences on RF Level are reason for that. I don't know why, but I got some clue... STB6100 got some special register called BBGain. It can be changed in StreamReader.ini of CrazyScan. Changing this to -10 or 14 give bigger differences between highest and lowest RF Level, but I do not recommend to use this setting as I don't know are there any drawbacks of playing with BBGain. Of course also this will work just for CrazyScan.
EDIT: After some tests STB6100 default BBGain for TBS6925 is probably "8". Prof7301 does not react for BBGain changes - scan with default BBGain, BBGain -10 and BBGain +14 looks the same. For TBS6925 I can get highest possible RF Level on Hot Bird at ~38,5dB (BBGain 14, no signal got ~41 dB with this setting). At the same time Prof7301 got value ~33 dB (the same dish, pointed at the same satellite with the same LNB, no signal at ~37 dB)
Locking speed: yes, TBS6925 lock higher SR fast, lower SR - slow (slower than Prof7301). But well - TBS6925 can 16APSK/32APSK and correctly work with MIS on 8PSK, Prof7301 cannot. More possibilities = more combinations of FEC, modulation etc. It would be nice to see some improvements in here, but IMHO this is impossible (third generation of STV090x demod is known as slower, Prof7301 use older, second generation, which got MIS bug). Prof7301 is faster, but no MIS, no 16APSK/32APSK, and BSOD's can be seen from time to time - I haven't seen BSOD with TBS6925.
TBS6925 use STB6100 tuner. There was STV6110 tuner, but there are opinions on the web that it's efectiveness was not as good as STB6100. Now STMicroelectronics put on market STV6120 tuner. Maybe DVB card with STV6120 + STV0900AAC demod + NXP SAA7160 bridge like TBS6925 would bring new light on speed case... Some TBS6926 or something
