Current status with DVB Viewer Recording service
Postby atef » Thu Jul 12, 2012 11:43 pm
I just ordered this card and just found here that there is a problem with DVBviewer Recording Service :cry:
that's sad , because tbs cards are the best DVB-s Cards i've used .
I hope if this problem was solved , please post an update here
thanks
atef
Re: Current status with DVB Viewer Recording service
Postby steven » Fri Jul 13, 2012 11:09 am
Hi atef
DVBViewer have updated a new version,would you mind using the new version
to have a test.
Postby herrbasan » Wed Jul 18, 2012 7:14 am
The latest version of the DVBViewer Recording Service has some workaround, but it introduced even more serious problems, at least for me. The RS now frequently crashes completely when the CI is involved. I've personally lost hope that there will be a solution, since the people at DVBViewer seem very reluctant to even acknowledge the problem, as it seems to them as something that is more a TBS problem. Altough the support by TBS is way more responsive and very friendly, they didn't seem to contribute much to help the problem.
In the end, i must say, the Hardware triumphed over the software, so i'm using MediaPortal now (which works flawlessly with the TBS 9628 btw). But i am quite dissapointed by the DVBViewer developers and it's indeed sad, since it would have made the dream-team (DVBViewer + TBS).
TBS 6928 / Unicam Deltracrypt CAM / Sky Germany V13 Card
Windows 7 x64 / MediaPortal 1.2.3
herrbasan
Postby atef » Thu Jul 19, 2012 6:43 pm
it works fine with dvbviewer . but it crashes the recording service .
I can't use it now . because i always use the recording service.
is there any solution or update to fix this????!!
atef
Postby steven » Fri Jul 20, 2012 3:57 pm
Hi atef
would you mind giving us more detail information? Like When it crash ?
Postby herrbasan » Fri Jul 20, 2012 10:36 pm
I can give my account on what the problem is. I assume it is the same with atef: since the workaround (frequently unloading/reloading the tbs dll) in different circumstances this "reset" fails and causes the DVBViewer recording service to crash. A simple restart of the service fails, only a restart of the computer brings it back.
The different circumstances are difficult to pin exactly.But one i can reproduce reliably: When the RS is streaming a non encrypted channel to a client, and scheduled recording of an encrypted channel starts, the client receives the information that the RS needs to switch channels, but then the RS crashes completely.
I've given this information to the DVBViewer people, but there has not been any response. But i don't think it will help if you (steven) write them again.
But what would help is if atef writes in their forum. By my count there is inlcuding me 3 people having problem with the DVBViewer Recording Service now.
Maybe this motivates them ..
http://www.dvbviewer.tv/forum/forum/58- ... g-service/
herrbasan
Postby atef » Fri Jul 20, 2012 11:14 pm
just like what herrbasan said . RS crashes and i must restart my pc to work,
it works fine with non encrypted channels but when i start switching between encrypted channels few times it crashes the recording service and dvbV hangs or becomes very heavy and slow responsiveness.
and btw , i have another TBS card installed .tbs 6981. i used the 6928 alone same problem( but i didnt disable or remove 6928)
atef
Postby steven » Mon Jul 23, 2012 2:29 pm
Hi atef
We will send this information to DVBViewer,any progress about this problem we will
contact you as soon as possible.
