DVB-S2/16,32APSK ACM/VCM
Postby Vuser » Tue Jul 10, 2012 10:10 pm
DVB-S2/16,32APSK ACM/VCM signals in the 5929 is not stable
check
http://tinypic.com/player.php?v=2i7605t&s=6
http://tinypic.com/player.php?v=huof42&s=6
Vuser
Re: DVB-S2/16,32APSK ACM/VCM
Postby crazycat » Wed Jul 11, 2012 1:23 am
because this multistream and with disabled input stream filtration you can see periodical lock lost (and high ber).
Anyway this Generic continous transponder can't be received on 5925 (usb-bridge can pass only dvb transport stream). And TBS IPTool can handle only DVB IP MPE streams.
Postby Vuser » Wed Jul 11, 2012 3:13 am
Vuser
Postby Vuser » Wed Jul 11, 2012 3:53 am
The new driver is installed, but the signal is not stable
Vuser
Postby steven » Wed Jul 11, 2012 10:36 am
Hi Vuser
Would you mind using crazyscan to have a test ,maybe the signal is not very well.
Hi Skyserfer
Do you have tested the new driver, can you input the streamID now ?
Postby Vuser » Wed Jul 11, 2012 10:10 pm
steven Wrote:Hi Vuser
post 1 check by CrazyScan
http://tinypic.com/player.php?v=2i1o40l&s=6
post 2 check by CrazyScan
http://tinypic.com/player.php?v=8sgo&s=6
Show signal quality is very low in 5925,please correct the signal quality
Vuser
Postby crazycat » Thu Jul 12, 2012 5:48 am
this very old CrazyScan, not have 'update modulation info' option.
please update CrazyScan + StreamReaderEx - http://sourceforge.net/p/crazyscan/wiki/
Postby Vuser » Thu Jul 12, 2012 7:01 pm
crazycat Wrote:this very old CrazyScan, not have 'update modulation info' option.
post 1 check by CrazyScan ('update modulation info')
http://tinypic.com/player.php?v=16j58b9&s=6
post 2 check by CrazyScan ('update modulation info')
http://tinypic.com/player.php?v=sblkld&s=6
Vuser
