Unicam 2 Deltacrypt Rev.2.0 HD+ don't work
Postby Blaster » Sat Jun 23, 2012 5:48 pm
Hi, i use the Unicam 2 Deltacrypt Rev.2.0 Modul with FW Sparta 5.34. With the DVBViewer Pro(4.9.6.20), i can see the CAM Menu and change settings but the CAM don't work with my HD+ Smartcard. Why can the Smartcard not encrypt the HD Channels? I've tried HD-P set to off but still does not work.
Blaster
Re: Unicam 2 Deltacrypt Rev.2.0 HD+ don't work
Postby steven » Mon Jun 25, 2012 9:32 am
Hi Blaster
Do you have tested our latest OEM-DVBDream,is it ok?
Postby Blaster » Sat Jul 07, 2012 5:30 am
With the FW gigasoft 3.30 my cam works!
Blaster
