" failed to lock signal" please help
Postby mehdimas20 » Tue Jun 19, 2012 4:56 am
pleeeease help me
when i connect whit tsreader to any frequency my signal and quality be 0(zero) and i receive a error
please please help mE?
what is the problem?
my card is tbs 5922 :| :| :| :|
mehdimas20
Re: " failed to lock signal" please help
Postby SergioDanielG » Wed Jun 20, 2012 5:03 am
"failed to lock signal", generally, is when there aren't a singnal in the frequency, polarity and symbol rate indicated.
But, if parameters are correct and you know there are a singnal in this transponders, the problem is other...
Best regards.
SergioDanielG
Postby auxius » Mon Feb 23, 2015 12:47 pm
I have 5922SE i have this problem too, i can't LOCK on every satellite at all. Some port does but other don't and sometimes it works well.
Im hoping that this is not hardware defect and can be fix on driver update.
Tested on windows7 64bit and 32bit issue still there.
Cheers
auxius
