Compiling & installing driver over rights newer drivers
Postby leemind » Wed Jun 06, 2012 5:02 pm
I have a fresh Ubuntu 12.04 box with 2 PCIe TV cards in - One Terrestrial; Hauppauge 2200 and one Satellite; TBS6891
This is a rebuild of my MythTV backend box, and have in the past got everything working together, albeit with a bit of fiddling.
However, I notice on the latest rebuild of the box, the SAA7164 drivers for the Hauppauge autodetected the card without any fiddling, but as soon as I make && make install the TBS drivers, it over rights the newer v4l code that comes with Ubuntu 12.04 with older drivers and then the auto-detection fails (I had a very quick look at the code for the saa7164_card and indeed it appears to be a very old version)
So is it possible, either to update the complete driver package to the latest v4l branch, or better still can you release the driver package such that it only builds the drivers for the TBS cards, not the entire stack (or explain how I could do this?)
Many thanks
David
leemind
Re: Compiling & installing driver over rights newer drivers
Postby leemind » Thu Jun 07, 2012 3:42 am
Update: Looking at a post further down, i configured the ./v4l/.myconfig to only build CX23885 modules and did a make && make install
Semi success... Now I get dmesg | grep cx2
[   13.259718] cx23885 driver version 0.0.3 loaded
[   13.260102] cx23885 0000:05:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[   13.260626] CORE cx23885[0]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=33,autodetected]
[   14.054117] cx25840 2-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[   14.720040] cx25840 2-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[   14.728294] cx23885_dvb_register() allocating 1 frontend(s)
[   14.728297] cx23885[0]: cx23885 based dvb card
[   14.728302] cx23885[0]: frontend initialization failed
[   14.728308] cx23885_dvb_register() dvb_register failed err = -22
[   14.728311] cx23885_dev_setup() Failed to register dvb adapters on VID_B
[   14.728314] cx23885_dvb_register() allocating 1 frontend(s)
[   14.728316] cx23885[0]: cx23885 based dvb card
[   14.728319] cx23885[0]: frontend initialization failed
[   14.728322] cx23885_dvb_register() dvb_register failed err = -22
[   14.728325] cx23885_dev_setup() Failed to register dvb on VID_C
[   14.728330] cx23885_dev_checkrevision() Hardware revision = 0xa5
[   14.728334] cx23885[0]/0: found at 0000:05:00.0, rev: 4, irq: 16, latency: 0, mmio: 0xfba00000
[   14.728341] cx23885 0000:05:00.0: setting latency timer to 64
[   14.769790] input: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:1c.0/0000:05:00.0/rc/rc0/input6
[   14.773404] rc0: cx23885 IR (TurboSight TBS 6981) as /devices/pci0000:00/0000:00:1c.0/0000:05:00.0/rc/rc0
[   14.773615] input: MCE IR Keyboard/Mouse (cx23885) as /devices/virtual/input/input7
[   14.774232] rc rc0: lirc_dev: driver ir-lirc-codec (cx23885) registered at minor = 0
[   43.644060] Modules linked in: vesafb tda18271 nfsd nfs lockd fscache auth_rpcgss nfs_acl sunrpc rc_tbs_nec ext2 cx25840 psmouse dm_multipath serio_raw ir_lirc_codec lirc_dev ir_mce_kbd_decoder ir_sony_decoder ir_jvc_decoder ir_rc6_decoder snd_hda_intel ir_rc5_decoder snd_hda_codec cx23885(O) ir_nec_decoder snd_hwdep snd_pcm rc_core cx2341x snd_timer videobuf_dma_sg videobuf_dvb snd videobuf_core saa7164 joydev tda10048(O) btcx_risc soundcore dvb_core snd_page_alloc i7core_edac v4l2_common ioatdma videodev edac_core dca v4l2_compat_ioctl32 tveeprom mac_hid lp parport dm_raid45 usbhid e1000e hid xor dm_mirror dm_region_hash dm_log
So it is failing to register...
Any ideas?
leemind
Postby steven » Thu Jun 07, 2012 9:40 am
Hi leemind
Would you mind send your detail information to our euro_support@tbsdtv.com,
we will reply you as soon as possible.
