No signal on tuner B
Postby helmut » Mon Jun 04, 2012 5:40 pm
As noted before, it appears there is no separate section for TBS 6991 which I have just bought.
For the TBS 6991: I have connected one lnb to tuner A and another lnb to tuner B. Windows Media Center says "No TV Signal Present" on Tuner B while Tuner A works fine. I have the same problem with DVB Dream and TBSViewer.
The lnb on tuner B is properly connected (I receive the satellite signal if I connect it to Tuner A).
Anything I must change to the setup - or does this indicate tuner B on the card is faulty?
Thanks.
helmut
Re: No signal on tuner B
Postby warumnix » Tue Jun 05, 2012 4:29 pm
this topic has been moved to the TBS 6991 Windows section, please discuss there, thanks
warumnix
