Faulty unit
Faulty unit
Postby Donb » Mon Jun 04, 2012 12:46 pm
I have a new 5922 box which has an odd problem. It tells me there is 50 level and 55 quality regardless of any aerial being connected. It does not tune anything.
It appears stuck. Powering off the unit doesn't change anything. I purchased two of these from the USA - the other unit is fine.
I was hoping that there would be a firmware update to try.
Help please
Donb
Re: Faulty unit
Postby steven » Tue Jun 05, 2012 9:53 am
Hi Donb
Please contact our support@tbsdtv.com,we will give you a solution.
Re: Faulty unit
Postby lanzinha » Thu Aug 09, 2012 5:45 pm
I am having the same problem, the unit tells me there is 50 level and 55 quality and It does not tune anything.
My specs:
windows 7 32 bit
tvbox tbs5922
TBS5922 Windows Driver V2.0.2.8.
Universam LNB (no diseq)
Can you please help me here?
Jose Carreira
lanzinha
Re: Faulty unit
Postby lanzinha » Mon Aug 13, 2012 11:07 pm
So where is the support, are they all in vacations?
lanzinha
Re: Faulty unit
Postby steven » Tue Aug 14, 2012 11:30 am
Hi lanzinha
Sorry for the delay reply.
Is this problem happened before? before the problem is it ok?
You can direct send your problem to our support@tbsdtv.com
then you will get a quick reply.
Re: Faulty unit
Postby lanzinha » Tue Aug 14, 2012 5:23 pm
Hello Steven
It´s a brand new unit...
lanzinha
Re: Faulty unit
Postby steven » Thu Aug 16, 2012 9:49 am
Hi lanzinha
Sorry about this problem
It is like that our euro_support have replied too.
We will help you to replace a new one.
