Problem with TBS 6920 & TBS 6981 on same system
Postby nridgway » Thu May 31, 2012 12:15 am
I have a problem when I install these 2 cards on the same system (Windows 7 64bit with latest drivers), they both work fine if they are installed separately but if they are installed together the 1st tuner on the 6981 doesn't work - the second one and the 6920 tuner works ok.
Anyone else having this problem and have a solution to it. I'm using DVBlogic software to tune in the cards.
nridgway
Re: Problem with TBS 6920 & TBS 6981 on same system
Postby steven » Mon Jun 18, 2012 2:14 pm
Hi nridgway
Do you have updated the latest driver of both?
Postby nridgway » Thu Aug 30, 2012 1:08 am
Hi Steven,
Yes i've updated the drivers on both. I've just started a new post in the 6981 forum as I've narrowed it down to that card not working - I took the other one out and did a clean install and its still not working.
you can close this thread if you want, thanks.
nridgway
