cx23885 driver DMA timeouts
Postby hinnack93 » Wed May 30, 2012 11:37 pm
I had this issue with the 6981 and kernel 3.2.0-2-amd64. I have compiled the driver as written in README but my vdr 1.7.27 cant tune sometimes some channels. In the syslog are many messages like this
frontend 2/0 timed out while tuning to channel 57, tp 212051
frontend 1/0 timed out while tuning to channel 11, tp 211973
and
cx23885_wakeup: 2 buffers handled (should be 1)
then i run the driver with the debug option and get my Harddisk burning, thousands of
cx23885[0]/0: queue is not empty - append to active
cx23885[0]/0: [ffff880028ef1400/25] cx23885_buf_queue - append to active
cx23885_buf_prepare: ffff880020715000
cx23885[0]/0: queue is empty - first active
cx23885[0]/0: cx23885_start_dma() w: 752, h: 32, f: 2
cx23885[0]/0: cx23885_sram_channel_setup() Configuring channel [TS1 B]
cx23885[0]/0: cx23885_start_dma() enabling TS int's and DMA
then I try with driverparameter
mpegbufs
mpeglines
mpeglinesize
vbibufs
no change was seen
At the Usenet I found this thread.
http://www.digipedia.pl/usenet/thread/1 ... /#post6029
If the vidb and vidc (ts1 / ts2) bridge streams each single channel
correctly, but not both together then this is either a sram
configuration issue (the risc engine's workspace is being corrupted by
another risc channel), or your system has a pcie compatibility issue.
Do my Motherboard GA-P43-ES3G dont work with your card?
hinnack93
Re: cx23885 driver DMA timeouts
Postby cody » Thu May 31, 2012 4:10 am
Hi, i'm not sure that the two problems are related - i mean the problem that it some times can't tune to some channels and the "2 buffers handled (should be 1)" message, i.e. the DMA issue, because we had few times such DMA issue reported and it either doesn't cause any issues in practice or disappeared by moving the board to another PCIe slot. i have no information about compatibility issues with GA-P43-ES3G motherboard, but that's an option. so, is it possible for you to try your 6981 card in another motherboard - that way we can rule out the root cause of the problem - it's not usual at all to have such problem and thus it's either your motherboard or some fault on your 6981 card, but i think based on the current information it's more likely to be issue with PCIe interface on the motherboard.
Postby hinnack93 » Thu May 31, 2012 11:22 pm
sure this problems are related. I have two more cards in this system and frontend 0 nor frontend 3 have such problems. If i watch live tv at the 6981 then the " buffers handled (should be 1)" message will reszult temporarely in loss of picture.
I dont have an another Board yet to test it. Is there a posibility to deaktivate one tuner? if not then I have waste for 104Eur. :cry:
hinnack93
Postby hinnack93 » Sat Jun 02, 2012 6:19 pm
I took a further look at this Problem. maybe the card is broken?
with femon -H -a 1
result
status SCVYL | signal 74% | snr 94% | ber 0 | unc 0 | FE_HAS_LOCK
status SCVYL | signal 74% | snr 93% | ber 0 | unc 0 | FE_HAS_LOCK
status | signal 74% | snr 92% | ber 0 | unc 0 |
status | signal 74% | snr 93% | ber 0 | unc 0 |
status SCVYL | signal 74% | snr 99% | ber 0 | unc 0 | FE_HAS_LOCK
status SCVYL | signal 74% | snr 100% | ber 0 | unc 0 | FE_HAS_LOCK
No SCVYL by 'Signal 74% and SNR 93% ????
sometimes no carrier at channels wich can be looked over my tt-1600
with scan-s2 I got sometimes the result
API major 5, minor 3
hinnack93
Postby SergioDanielG » Sun Jun 03, 2012 1:26 am
hinnack93 Wrote:WARNING: filter timeout pid 0x0011
Nothing wrong with that. This timeouts are because i's trying to find TV/Radio PID's in TP with data PID's. Maybe the TP have special signals with CCM/ACM/VCM and your card not fully support it.
Best regards.
SergioDanielG
