Windows 2000
Windows 2000
Postby Mulder » Fri May 25, 2012 12:24 am
Because TBS claims that this card supports Windows 2000
Ive both it but
the the driver doesn't run under windows 2000
Device Manager respond with Error 31
I've open the driver using the dependency walker and this reveals
Function
KeFlushQueuedDPCs
in
NTOSKRNL.EXE
is not available
A good explanation ->
http://www.wd-3.com/archive/WalkPlank.htm
I know 2000 is no longer supported and all that other stuff
but im still using it.
Make other tools like DVB Dream running is possible with the Dlls Wrapper -> http://www7.atwiki.jp/win2000/pages/17.html
but the kernel is a different story
So :?
Mulder
Re: Windows 2000
Postby steven » Fri May 25, 2012 9:23 am
Hi Mulder
Do you have installed DX 9.0C,if not ,Please install this first. :)
Re: Windows 2000
Postby Mulder » Sat May 26, 2012 2:35 am
Yes i have installed directx9c
but this isnt the issue here
the driver make use of a function from the kernel
which is not available until XP sp3
Mulder
Re: Windows 2000
Postby steven » Tue May 29, 2012 9:41 am
Hi Mulder
Sorry about this ,Our older card can use in windows2000,
but our new card like TBS6922 which use new bridge and it can not support windows2000
So this is why you can not use TBS6922 in windows2000.
Please update windows2000 to a new windows version.
