How to Lock TBS6925 at 16/32 APSK Modulation
Postby missingplugin » Thu May 24, 2012 7:31 pm
Currently i am able to lock the card at the modulation of BPSK,QPSK,8PSK using Szap-s2 which came on the Drivers CD along with TBS6925 Card, However there is not any option for 16/32 APSK which is supported by card. In order to do that what should i do?
missingplugin
Re: How to Lock TBS6925 at 16/32 APSK Modulation
Postby SergioDanielG » Thu May 24, 2012 8:51 pm
It's true, no option to specify 12/30 APSL modulation in szap-s2, but, did you try lock it anyway? Because blindscan hardware in TBS6925 don't need this parameters to lock signals. First you need to do some modification before compile drivers, see this post: viewtopic.php?p=4995#p4995
Best regards.
SergioDanielG
Postby missingplugin » Fri May 25, 2012 1:07 pm
Thanks for your reply..
Currently blindscan(software) is installed and its scanning the frequencies well, is there any blindscan hardware in the the card, which is used by Szap to lock the signals? little confused here..
missingplugin
