function level reset (FLR) in 6981?
Postby cocoa117 » Tue May 22, 2012 12:49 am
Does 6981 PCI-E card support FLR function? FLR is the function level reset which is required when you want to do PCI-passthrough your PCI-E card to virtualisation environment in Xen.
cocoa117
Re: function level reset (FLR) in 6981?
Postby cocoa117 » Sat May 26, 2012 11:36 pm
I have found some answer about Function level rest (FLR) info on the net.
... When it comes to peripheral I/O devices, there is no "special" virtualization feature that they need in order to work with PCI passthrough. What you need is to be able to reset them by software without resetting the entire system. This can mainly be done by function level reset (FLR) by which you can reset individual hardware components (or PCI devices, onboard components such as the NIC are also PCI devices) at the function level. ...
I don't know about ATI (or AMD) but Nvidia seems to be diligent to get it supported and they apparently supply firmware patches upon request for their Geforce cards. I've also read somewhere that their lines of Quadro and Tesla cards support FLR by default and are specifically designed to work with PCI/VGA passthrough.
http://www.tomshardware.com/forum/523-71-intel-home
Can TBS develop patch for their card, so this function can be included?
cocoa117
