DiSEqC not working TBS5922
Postby kazimali25 » Wed May 16, 2012 10:23 pm
hello sir i have a problem in my TBS5922 DiSEqC not working.some time port 1 working some time not working,others ports also not working,but my other receiver working normal with same DiSEqC switch.
kazimali25
Re: DiSEqC not working TBS5922
Postby steven » Fri May 18, 2012 9:10 am
Hi kazimali25
Would you mind telling us that which player you used to test the DiSEqC?and what the driver version you are using?
Postby smile » Fri May 18, 2012 10:29 am
Hi kazimali25
We just have a test with the TBS5922,its DiSEqC can work fine.We tested it with the latest driver.(V 2.0.2.7) .please try it with the latest driver.
smile
Postby kazimali25 » Fri May 18, 2012 12:12 pm
I am using latest driver v2.0.2.7 in DVBdream,progdvb,SmartDVB but the same result.my windows is win 7 64bit i am also check this in win 7 32 bit.but same problem,now i install TBSviewer.so TBSviewer working normal but all other software not work.
kazimali25
Postby steven » Fri May 18, 2012 2:45 pm
Hi kazimali25
You mean that with TBSViewer TBS5922 is ok with DiSEqC ??
Postby steven » Thu May 24, 2012 2:43 pm
Hi kazimali25
Is your Diseqc ok now?
