The problem with TBS 6981
Postby woj1000 » Mon Apr 30, 2012 4:01 pm
I have a problem with the TBS6981 card.
The problem consists in loss of the signal during watching on Dvbviewer when in the same time I run other program on the second head.
The problem is appearing only from DVBwiewerem.
Whether are these a fault of TBS6981 drivers, or Dvbviewer?
The problem of the video explains:
http://youtu.be/aj2Y-8XeK8c
http://rapidgator.net/file/4715407/Film.avi.html
woj1000
Re: The problem with TBS 6981
Postby steven » Tue May 01, 2012 9:24 am
Hi woj10000
Would you mind giving us your DVBViewer's Device setting's picture.
If DVBViewer use TBS6981 Tuner A ,Then you need to setting the Tuner B not use with DVBViewer.
Postby woj1000 » Tue May 01, 2012 6:51 pm
I also tried with placing:
Dvbviewer - TBS6981/A and;
Dvbdream - Prof7301 and to no effect.
Still a fading is appearing
http://youtu.be/GiG5EXX8Pw8
However when I will place Prof7301 on dvbviewer, and on dvbdream TBS6981/A
everything is ok
http://youtu.be/gv96-65NoOs
So the problem probably exists in the bad cooperation of TBS6981 drivers with Dvbviewer
Or this equipment TBS 6981 damage is ..... :(
woj1000
Postby steven » Wed May 02, 2012 10:17 am
Hi woj1000
Would you mind just opening DVBDream first use with 7301,and then use DVBViewer,is it ok?
and we will contact this with DVBViwer and DVDream.any progress ,we will let you know
as soon as possible.
Postby woj1000 » Wed May 02, 2012 5:19 pm
If I run in DVBDream Prof 7301, and then the TBS6981 DVBDream it is not blocking the signal. It is ok.
This confirms the theory that the problem is with drivers Dvbwiewer to TBS 6981.
http://youtu.be/LN2ZrS317tM
With DVBDream there are no problems with both TBS 6981 and Prof 7301 .
The problems are with the DVBViewer to TBS 6981.
Of the page: http://www.dvbviewer.com/en/index.php?page=features
says nothing about use TBS6981
I have Windows 7 64
woj1000
Postby steven » Mon May 07, 2012 4:13 pm
Hi woj1000
Would you mind use DVBDream first Before solving this problem ,We will contact this with DVBViewer
to check what the problem is.
Postby woj1000 » Mon May 07, 2012 9:27 pm
Someone had similar problems with DVBViewer, if anyone is checked, I do not know if the problem exists, or should only the configuration of my computer or damage the card TBS 6981?
Ok. I will use DVBDream, but I admit that I prefer DVBViewer.
The more that I also use DVBViewer Recording Service.
I would be very grateful if it was possible to contact the manufacturer DVBViewer to rectify the fault, although I noticed that the Pogdvb a similar problem.
You please inform me about the effects of work on this problem.
woj1000
Postby steven » Tue May 08, 2012 9:18 am
Hi woj1000
We have contacted this problem with DVBViewer,any progress will let you know as soon as possible. :)
