I'm currently running my 6284 from the 6 pin to 3 molex adapter that came with the card; would I be able to run the card from a 6 pin PCI-e vga cable?
Would tidy up the inside of my case no end!
Thanks in advance...
gjsearle74 Wrote:I'm currently running my 6284 from the 6 pin to 3 molex adapter that came with the card; would I be able to run the card from a 6 pin PCI-e vga cable?
steven Wrote:About the power ,it is depend on the load of your LNB using, like when you use a motor need more power
then extra power is needed.![]()
Kind regards
steven Wrote:Hi superman2012
I think that there is no need to use extra power in DVB-T2,if you have no problem when using
without extra power.![]()
Kind Regard
