[ Moderator Control Panel ]
by robti » Thu Apr 05, 2012 6:06 am
Hi can you tell me what DiSEqC this card supports and if it supports usals
Robert
robti
by steven » Thu Apr 05, 2012 8:56 am
Hi robti
all the DiSEqC types are supported, so are the Unicable, but please note that it depends also on the soft you are using , the hardware is fully compatible.
by robti » Thu Apr 05, 2012 2:56 pm
Thanks for the quick answer
Robert
robti
