tbs linux drivers v120216 - does not work
Postby mysterio » Wed Apr 04, 2012 9:15 pm
Hello!
I'm having problems with 5922 under linux :/
I'v tested 2 different drivers and Card is propely detected but it does not work (scanning from tvheadend does not work).
tested on below 2 drivers:
linux-tbs-drivers_111103.zip:
[ 109.839594] DEBUG: 5922 tune checked
tbs-linux-drivers_v120216.zip:
[ 59.962004] tbs5922fe - delivery system 0 is not supported
what should I do ? because right now i cannot use it...
System Ubuntu 11.10 - 3.0.0-17-generic-pae
best regards
Pawel
mysterio
Re: tbs linux drivers v120216 - does not work
Postby zibiK » Thu Apr 05, 2012 12:43 am
Hi!
I have exactly the same distro and kernel and everything is o.k..
Show us dmesg and lsmod output.
Check if dvbtune works.
Ver. of tvheadend .
Regards
Zbigniew Kujawski
zibiK
Postby mysterio » Thu Apr 05, 2012 1:27 am
TVHEADEND installed from hts-tvheadend_2.12_i386.deb
dmesg |grep -i tbs | more
[ 8.194941] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 8.226895] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5922.fw'
[ 8.227915] tbsqbox22: start downloading TBSQBOX firmware
[ 8.347504] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in warm state.
[ 8.351543] DVB: registering new adapter (TBS QBOX22 DVBS2 USB2.0)
[ 8.359771] tbsqbox22: read eeprom failed
[ 8.557505] tbs5922fe: module license 'TurboSight Proprietary: http://www.tbsdtv.com' taints kernel.
[ 8.859232] TurboSight TBS 5922 Frontend Attaching...
[ 8.883224] TurboSight TBS 5922 Frontend:
[ 8.883225] tbs5922fe - attach failed
[ 8.883236] dvb-usb: no frontend was attached by 'TBS QBOX22 DVBS2 USB2.0'
[ 8.883371] dvb-usb: TBS QBOX22 DVBS2 USB2.0 successfully initialized and connected.
[ 8.883397] usbcore: registered new interface driver tbsqbox22
[ 8.919405] dvb-usb: TBS QBOX22 DVBS2 USB2.0 successfully deinitialized and disconnected.
[ 10.255580] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 10.256748] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5922.fw'
[ 10.258013] tbsqbox22: start downloading TBSQBOX firmware
[ 10.378456] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in warm state.
[ 10.378604] DVB: registering new adapter (TBS QBOX22 DVBS2 USB2.0)
[ 10.778244] TurboSight TBS 5922 Frontend Attaching...
[ 10.844104] QBOX22: TBS5922FE attached.
[ 11.072863] DVB: registering adapter 0 frontend 0 (TurboSight TBS 5922 DVBS/S2 frontend)...
[ 11.073313] dvb-usb: TBS QBOX22 DVBS2 USB2.0 successfully initialized and connected.
lsmod.rar
(894 Bytes) Downloaded 308 times
mysterio
Postby mysterio » Fri Apr 06, 2012 6:34 pm
any ideas ? :(
mysterio
