TBS drivers and the "other" manufacturers (solved)
Postby zibiK » Fri Mar 30, 2012 7:34 pm
Hello !
It's my first post, so welcome.
I bought TBS5922 to replace my old dvb-s card. It' works great now. But I have also dvb-t card on it9135 (dvb-usb-it9135 module). Now after build and modprobe I have this error:
dvb_usb_it9135: disagrees about version of symbol dvb_usb_device_init
dvb_usb_it9135: Unknown symbol dvb_usb_device_init (err -22)
Before installing tbs driver it was o.k.
What can I do to build it properly.
I used drivers from http://wasietsmet.nl/wp-content/uploads ... 2.30.1.zip
Regards
Zbigniew Kujawski
zibiK
Re: TBS drivers and the "other" manufacturers
Postby SergioDanielG » Sat Mar 31, 2012 12:25 am
What happend if you install tbs drivers first and install the other driver after?
Did you try it?
And wich linux distribution are you using?
Best regards
SergioDanielG
Postby zibiK » Sat Mar 31, 2012 12:58 am
Hi!
Yes, I tried both sequence:
1. it9135 drivers then tbs driver
2. tbs driver then it9135 driver
error is the same
My distro is ubuntu 11.10 and kernel 3.0.0-17-generic-pae
I think that TBS has its own dvb-usb driver, and here's the problem
I've made test on another machine with ubuntu 11.04 and kernel 2.6.38 - problem is the same.
I also tried build on headers from ubuntu and from TBS package - no effect.
I was stuck.
Please help
Best regards
Zbigniew Kujawski
zibiK
Postby zibiK » Wed Apr 04, 2012 11:42 pm
Regards
Zbigniew Kujawski
zibiK
Postby SergioDanielG » Thu Apr 05, 2012 5:24 am
Perfect! thanks for share your solution.
Best regards.
SergioDanielG
