TBS 6984 - 5 Cards
TBS 6984 - 5 Cards
Postby Phoenix1833 » Wed Mar 28, 2012 2:44 pm
Use the 5 cards TBS 6984 on the motherboard GA-X58A-UD3R. Processor Intel (R) Core (TM) i7 CPU 950. Debian. The kernel 2.6.32-5-686. Drivers with the latest site with an increase in buffer. For broadcast use getstream a84.
The flow is analyzed using iptv-analyzer.
problem:
When using all four output cards, the flow begins to roll periodically with errors should only use three output, the problem disappears when you try to re-engage all four output again begin to roll in error.
Phoenix1833
Re: TBS 6984 - 5 Cards
Postby steven » Wed Mar 28, 2012 4:22 pm
Hi Phoenix1833
From the information you give to us,and your motherboard's information:
http://www.gigabyte.us/products/product-page.aspx?pid=3449#ov
It have 6 PCI-E slots.
Would you mind telling us which 5 PCI-E slots you are using.
and Do you have updated your motherboard's BIOS.Can you send the error information to our euro_support@tbsdtv.com
and support@tbsdtv.com .
we will send you a reply as soon as possible.
Postby Phoenix1833 » Wed Mar 28, 2012 7:12 pm
In the continuation of a conversation on the forum. It is used here, this motherboard
http://www.gigabyte.us/products/product ... x?pid=3571
except for the top pci-e 1x use all pci-e.
Bios is not updated. Version of the bios:
description: BIOS
vendor: Award Software International, Inc.
physical id: 0
version: F2 (08/24/2010)
capacity: 1984KiB
Phoenix1833
Postby Phoenix1833 » Wed Apr 04, 2012 3:35 pm
Someone will answer me. By e-mail silence.
Phoenix1833
Postby steven » Thu Apr 05, 2012 2:14 pm
Phoenix1833 Wrote:Someone will answer me. By e-mail silence.
Hi Phoenix1833
No reply not means that we are not solving this problem, :) .
We are communicating this problem with our engineer.
and we have send you a reply,here is the detail information,Please have a check with your email.
hi Vladimir,
i believe you spoke with some of my colleagues, because i can't recall your case. i guess you're talking about some BIOS bug that affects your PCI-Express slots. so, please, either point me out to the conversation in the forum or maybe it would be better to speak with my colleagues with which you discussed before.
thank you,
constantine
Best wishes
Postby Phoenix1833 » Fri Apr 06, 2012 4:44 am
OK. Thanks. I'll wait.
Phoenix1833
