Melted/burned connector
Postby ctor » Sun Mar 18, 2012 10:52 pm
I originally had the 6920 but I exchanged it for the 6981 as I had the same problem with that. I'm not sure what is causing it, as the cable work perfectly in the sky box.
After a few days the cable just melts/burns and I have refit the the f connector further down the cable.
Thanks for any help.
ctor
Re: Melted/burned connector
Postby steven » Wed Mar 21, 2012 5:33 pm
Do you have used signal splitter for Dual Tuner card.
if you have use signal splitter ,Can you have read this topic:
viewtopic.php?f=21&t=4335
Best regards
Postby ctor » Mon Mar 26, 2012 7:55 pm
No there is no signal splitter. There are two separate cables running off the lnb.
There is only one cable that melts. The other one is fine.
ctor
Postby steven » Sat Apr 28, 2012 11:36 am
Hi ctor
Is your problem has solved now?One question is that do you have used the extral power supply for TBS6981?
