SASC-NG with Ubuntu 11.10 3x Kernel
Postby dcdc123 » Thu Mar 15, 2012 10:05 pm
I'm trying to get sasc-ng workng ubuntu 11.10 (mythbuntu 11.10 more specifically). I have been following these tutorials:
http://dolot.kipdola.com/wiki/Install_S ... pendencies
http://dolot.kipdola.com/wiki/Compile_Linux
Once I get to "modprobe dvbloopback" it tells me its an 'invalid argument'. I'm pretty stuck on this can anyone offer any tips?
cheers
dcdc123
Re: SASC-NG with Ubuntu 11.10 3x Kernel
Postby SergioDanielG » Thu Mar 15, 2012 10:50 pm
If you run "modprobe dvbloopback" is because all compiled well...
Did you tray "modprobe dvbloopback num_adapters=x"? where x is number of adapters installed
Other question. Can you read italian? http://forum.ubuntu-it.org/index.php/to ... 152.0.html there is an instalation on kernel 3.0, but be carefull because it aply a patch in a file that is in tbs driver too and I don't know if it a good idea.
If you try anyway, you need aply the patch to tbs driver and not to vanilla kernel as it indicated in this page.
Best regards.
SergioDanielG
Postby dcdc123 » Fri Mar 16, 2012 1:15 am
When I try that it gives me the same "Invalid Argument" repsonse. I guess I havent compiled everything correctly.
My Italian is a bit limited but i guess i can use google translate to a certain extent. Have you been sucessful in getting sasc-ng to work n ubuntu 11.10?
Thanks v.much
dcdc123
Postby dcdc123 » Fri Mar 16, 2012 4:50 am
BTW, how do i apply the patch to the tbs driver and not to vanilla as suggested?
I am just following the instructions one by one, dont know if its going to work...
dcdc123
Postby SergioDanielG » Fri Mar 16, 2012 5:40 am
dcdc123 Wrote:BTW, how do i apply the patch to the tbs driver and not to vanilla as suggested?
Where say:
cd /usr/src/linux-[VERSIONE_SCARICATA]
wget http://www.vanbest.org/drupal6/sites/www.vanbest.org/files/linux-2.6.38-dvb-mutex.patch
patch -p1 < linux-2.6.38-dvb-mutex.patch
There is appling the patch, but you need to chage to directory where you have tbs drivers before run wget.
For exjample, I allways download tbs drivers to /usr/src/tbsdrivers and unzip there. Then:
cd /usr/src/tbsdrivers/linux-tbs-drivers
Best regards.
SergioDanielG
Postby dcdc123 » Fri Mar 16, 2012 5:55 am
Thanks!
I have followed the whole thing through and when i write 'ls /dev/dvb' it says adapter0 ( i should have at least 10 adapters )
I have just tried doing what you said and it tells me that there is no such file or directory 'skip this patch?' what can i do?
dcdc123
Postby SergioDanielG » Fri Mar 16, 2012 6:44 am
Sorry. The patch it maked to replace vanilla kernerl.
Can you edit it?
Change the first line
diff -Nur linux-2.6.38/drivers/media/dvb/dvb-core/dvbdev.c linux-2.6.38/drivers/media/dvb/dvb-core/dvbdev.c
To
diff -Nur linux/drivers/media/dvb/dvb-core/dvbdev.c linux/drivers/media/dvb/dvb-core/dvbdev.c
Best regards.
SergioDanielG
Postby dcdc123 » Fri Mar 16, 2012 7:01 am
sorry where do i enter that?
ive just tried removing and reinstalling the kernels as my tuners werent working and i couldnt re-install. Can i still edit or do i have to do the whole process again? :S
dcdc123
Postby SergioDanielG » Fri Mar 16, 2012 8:03 am
You need to modify downloaded patch file.
In a console, change to directory where you download the patch en edit it with nano
nano linux-2.6.38-dvb-mutex.patch
There replace the first line
to
<ctrl>+<o> to save
<ctrl>+<w> to exit
Be carefull, there are 2 patch to aply in tbs drivers (the second in DRIVER DVB/V4L)
Then recompile tbs drivers and continue to SASC-NG section.
Best regards.
SergioDanielG
Postby dcdc123 » Fri Mar 16, 2012 8:28 pm
Sorry not sure where you mean in regards to the 2nd patch.
Do you mean run the patch file in the following folders?:
tbsdriver/linux-tbs-drivers/ (just tried this after editing first line and i get the same result as before - 'can't find file to patch at input line 4')
and
tbsdriver/linux-tbs-drivers/v4l
dcdc123
