(Solved)TBS-6928 and Unicam module, no picture and no sound?
Postby Olli1984 » Wed Mar 07, 2012 2:55 pm
I now have a TBS-6928 with a Unicam module, rev 2.0.
I get in encrypted channels no picture and no sound.
Software I have tested DVB Dream, Watch TV EX and DVB Viewer.
In my Samsung TV, the Unicam module works fine with a "HD+" card.
Can someone help me?
Thx ;)
Olli1984
Re: TBS-6928 and Unicam module, no picture and no sound?!
Postby steven » Wed Mar 07, 2012 3:49 pm
Hi Olli1984
Can you get the MMI with DVBDream?
Postby Olli1984 » Wed Mar 07, 2012 4:11 pm
How i check this?
With TBS MCE CI Tool V1.0.0.3, I can start MMI and see the CAM Info.
Olli1984
Postby Olli1984 » Thu Mar 08, 2012 5:51 am
With TBS MCE CI Tool ich can see Unicam Information and the HD+ card information too.
So the CAM and the card works?
But only blacksrceen and no sound in encrypted channels.
Can anybody help?
Olli1984
Postby steven » Thu Mar 08, 2012 4:56 pm
Can you take a photo of your Unicam ,and would you mind having a test just the unencrypted channels.
Is it ok?
Postby Olli1984 » Thu Mar 08, 2012 11:49 pm
Thx for your answer.
Yes, its a Unicam Rev 2.0:
The software on the module is Sparta 5.32 (15/02/2012) from unicam2.to
Image Image
All unencrypted channels works fine.
Edit:
Its the same Problem like viewtopic.php?f=33&t=669
Olli1984
Postby steven » Fri Mar 09, 2012 9:13 am
Hi Olli1984
Like this:http://www.tbsdtv.com/forum/viewtopic.php?f=33&t=669
luchy Wrote:hi,
can you help to recorder this transponder's stream for us to do more analyses?
you can recoder it with dvbdream->Modules->Stream Recorder, please do not insert cam when you recorder it, more than 300M data will be good.
maybe you can use hotfile to update a big file.
We need the TS file like this,Would you help us about this.
Postby Olli1984 » Fri Mar 09, 2012 4:44 pm
Hello again,
now, it works.
There is a menu option in the Unicam module called "HD-P"
I changed it from ON to OFF and now i can view encrypted channels.
thx for your help.
Olli
Olli1984
Postby steven » Fri Mar 09, 2012 4:56 pm
Hi Olli1984
You are welcome,And thanks for sharing your solution. :)
