tbs 6980 socket b broken
Postby bbehzadd » Fri Jul 15, 2011 7:06 am
hi
i have not strength & quality on my socket b!
is this broken? :!: :?:
my driver is v-2.0.0.19
thanks
bbehzadd
Re: tbs 6980 socket b broken
Postby bbehzadd » Sat Jul 16, 2011 4:21 am
This problem occurred when the regulation LNB
When the program was open to (TBS-IPdata) and down to find the signal on Hotbird
strength that were cut once!
bbehzadd
Postby steven » Tue Jul 19, 2011 3:03 pm
Would you mind try other PCI-e slot.and rub 6980's Goldfinger.
thanks
Postby bbehzadd » Tue Jul 19, 2011 3:50 pm
sorry i cant good speach english
what is your mean Goldfinger!?
i do try any things but socket B dont work
This might happen with a bad connection between the socket and lnb's happened?
bbehzadd
Postby steven » Mon Sep 05, 2011 9:29 am
Hi bbehzadd
Is it ok now?
