PowerCAM Pro CAM supported?
Postby jcarrion » Thu Jul 14, 2011 10:23 pm
Dear all,
We have just received our first TBS 5980 CI and we are testing it with scrambled channels (FTA channels work very well). Everything seems to be correct, but we cant see any image or sound (ie, the channel is not decrypted at all).
Using the "TBSViewer" we are unable to access the CAM via the "Cam Module", but using the "DVB Dream" version downloadeable from TBS web, we can access it and interact with its menus (see attached img).
Atm we are using TbsCIapi.dll v1.0.0.3, and, if we use v1.0.0.2 everything is the same but we get a log file in c:\tbsCI.log with the following contents:
[07/14/11 16:28:56 : 1829766989]  cam not ready !
[07/14/11 16:28:56 : 1829766989] 222 send pmt table error
[07/14/11 16:29:03 : 1829773853]  resent capmt ----->>>>
[07/14/11 16:29:03 : 1829773853]  the cam not ready !
[07/14/11 16:29:03 : 1829773853]  build pmt  error
[07/14/11 16:29:03 : 1829773853]  resent capmt error!
[07/14/11 16:29:09 : 1829780031]  cam not ready !
[07/14/11 16:29:09 : 1829780031] 222 send pmt table error
Please, advice!
thx,
J. Carrion.
The CAM Menu, valid Card
jcarrion
Re: PowerCAM Pro CAM supported?
Postby jcarrion » Thu Jul 14, 2011 10:28 pm
Oh, i forgot to mention that the card works perfect with the desktop receiver and with another pc-satellite-tuner (distinct brand).
jcarrion
Postby luchy » Tue Jul 19, 2011 10:04 am
hi,
sorry for late reply.
what's your smart card and cam type? can you give us some detail info or take some photo of them ?
which satellite and transponder do you lock ?
the more information you provide, the more we can close the problem.
we update a dll the latest version v1.0.0.4,please have a try with it.
thanks.
tbs5980CIdll.rar
(215.24 KiB) Downloaded 661 times
luchy
Postby jcarrion » Tue Jul 19, 2011 3:20 pm
Hi Luchy,
Thx for your reply!
I am attaching some images of the CAM (PowerCam PRO v2.03) and the SmartCard (digital+ nagra3) used.
I also included one image of the dvbdream showing the satellite and frequency tunned (FTA channel). An example of an scrambled channel freq would be 11156MHz polarity V, 22000 datarate. Satellite Astra 19.2E. EPG information is received and showed ok, so the tunning has been performed.
By the way, I have tried the new ci dll v1.0.0.4 without success :(
3Attachments in this message, 2 in the next one!
jcarrion
Postby jcarrion » Tue Jul 19, 2011 3:24 pm
the next 2 images....
jcarrion
Postby luchy » Thu Jul 21, 2011 2:54 pm
hi,
can you help to recorder this transponder's stream for us to do more analyses?
you can recoder it with dvbdream->Modules->Stream Recorder, please do not insert cam when you recorder it, more than 300M data will be good.
maybe you can use hotfile to update a big file.
luchy
Postby jcarrion » Thu Jul 21, 2011 4:00 pm
Hi Luchy,
I have uploaded a 300mb ts file, if you need anything else, want me to test a debug dll or whatever, just ask :)
http://hotfile.com/dl/124635131/2b9d624/digiplus_test.ts.html
Thx for your time!!
J.Carrión.
jcarrion
Postby luchy » Fri Jul 22, 2011 4:15 pm
hi JCarrion,
thanks for your help, we have download TS succeed.
we make a special TbsCIapi.dll ,it just for your Digital Plus. please ignore its version.
TbsCIapi.rar
(125.68 KiB) Downloaded 582 times
luchy
Postby jcarrion » Fri Jul 22, 2011 4:50 pm
Hi again Luchy,
I have tried the new dll and is not working yet :(. I tried it with tbsviewer, dvbdream and dvbviewer.
The Log file shows the following messages:
[07/22/11 10:33:04 : 63760323]  cam not ready !
[07/22/11 10:33:04 : 63760323] 222 send pmt table error
[07/22/11 10:33:12 : 63767748]  resent capmt ----->>>>
[07/22/11 10:33:12 : 63767748]  the cam not ready ......
[07/22/11 10:33:12 : 63767748]  build pmt  error
[07/22/11 10:33:12 : 63767748]  resent capmt error!
[07/22/11 10:34:37 : 63853549]  cam not ready !
[07/22/11 10:34:37 : 63853549] 222 send pmt table error
[07/22/11 10:34:44 : 63860335]  resent capmt ----->>>>
[07/22/11 10:34:44 : 63860335]  the cam not ready ......
[07/22/11 10:34:44 : 63860335]  build pmt  error
[07/22/11 10:34:44 : 63860335]  resent capmt error!
[07/22/11 10:37:29 : 64025540]  cam not ready !
[07/22/11 10:37:29 : 64025540] 222 send pmt table error
[07/22/11 10:37:35 : 64031421]  cam not ready !
[07/22/11 10:37:35 : 64031421] 222 send pmt table error
[07/22/11 10:38:14 : 64070047]  cam not ready !
[07/22/11 10:38:14 : 64070047] 222 send pmt table error
[07/22/11 10:39:04 : 64120248]  cam not ready !
[07/22/11 10:39:04 : 64120248] 222 send pmt table error
[07/22/11 10:39:11 : 64126722]  resent capmt ----->>>>
[07/22/11 10:39:11 : 64126722]  the cam not ready ......
[07/22/11 10:39:11 : 64126722]  build pmt  error
[07/22/11 10:39:11 : 64126722]  resent capmt error!
[07/22/11 10:45:22 : 64498098]  cam not ready !
[07/22/11 10:45:22 : 64498098] 222 send pmt table error
[07/22/11 10:45:41 : 64516709]  cam not ready !
[07/22/11 10:45:41 : 64516709] 222 send pmt table error
[07/22/11 10:46:14 : 64550436]  cam not ready !
[07/22/11 10:46:14 : 64550436] 222 send pmt table error
[07/22/11 10:54:35 : 65050716]  cam not ready !
[07/22/11 10:54:35 : 65050716] 222 send pmt table error
[07/22/11 10:55:23 : 65099295]  cam not ready !
[07/22/11 10:55:23 : 65099295] 222 send pmt table error
[07/22/11 10:55:30 : 65105940]  resent capmt ----->>>>
[07/22/11 10:55:30 : 65105940]  the cam not ready ......
[07/22/11 10:55:30 : 65105940]  build pmt  error
[07/22/11 10:55:30 : 65105940]  resent capmt error!
[07/22/11 10:56:28 : 65164254]  cam not ready !
[07/22/11 10:56:28 : 65164254] 222 send pmt table error
[07/22/11 10:56:46 : 65181772]  cam not ready !
[07/22/11 10:56:46 : 65181772] 222 send pmt table error
[07/22/11 10:56:58 : 65193847]  cam not ready !
[07/22/11 10:56:58 : 65193847] 222 send pmt table error
[07/22/11 10:57:10 : 65205765]  cam not ready !
[07/22/11 10:57:10 : 65205765] 222 send pmt table error
[07/22/11 10:57:19 : 65215344]  cam not ready !
[07/22/11 10:57:19 : 65215344] 222 send pmt table error
[07/22/11 10:57:25 : 65221459]  cam not ready !
[07/22/11 10:57:25 : 65221459] 222 send pmt table error
[07/22/11 10:57:35 : 65231521]  cam not ready !
[07/22/11 10:57:35 : 65231521] 222 send pmt table error
The CAM menu is working only under DVBDream (like before).
jcarrion
Postby luchy » Mon Jul 25, 2011 3:58 pm
It's a pity it still doesn't work.
I thinks it would be more efficient if we get the same Cam and smart card with you and test it here.
can you help us to buy a smart card the same with yours?
detail this, i send a PM to you,please check it.
luchy
luchy
