TBS 6920 on INTEL Z68 chipset Motherboard
Postby bloodmaster » Wed Jul 13, 2011 9:06 pm
I have a TBS 6920 card and so far it work without any promblem on my x48 chipset motherboard (x48-dq6 Gigabyte) but from last week i jump to a new Motherboard with Z68 chipset (Gigabyte GA-Z68X-UD3P-B3) and the problems start.
When i start DVB Dream i see a SD channel ok BUT when i try to change to another channel it shows NOTHING like it has no signal from the dish.
When i try to start with a HD channel it shows NOTHING.
When i put my old TechniSat Skystar hd card all works fine.
The test have done with 1048 and 1049 drivers.
Any solutions?
bloodmaster
Re: TBS 6920 on INTEL Z68 chipset Motherboard
Postby steven » Thu Jul 14, 2011 9:50 am
would you mind change it to the older Motherboard,to see the card is ok?
and are you sure that the card is int ok?and try the new Motherboard another PCI-E slot.
Postby bloodmaster » Thu Jul 14, 2011 7:41 pm
Hi steven
I have allready done both.
In other PCI-E slot same promblem and in my old motherboard works fine.
bloodmaster
Postby steven » Tue Jul 19, 2011 3:06 pm
bloodmaster Wrote:Hi steven
do you have updated new motherboard's BIOS.
Postby bloodmaster » Wed Jul 20, 2011 5:47 am
I have update it to the last F6D (18/7/2011) Beta bios from the last Official F5 20/6/2011 .
On both bios i have the same promblem
bloodmaster
