Unstable driver tbs 6921
Postby freestat » Mon Jun 27, 2011 7:52 pm
TBS 6921 is very unstable on windows 7 32bit pro. Legal Dvbviewer pro freez a picture when I shufle opera, aimp, aqq or when I'm run the task manager. Dvbviewer and Dvbdream often are crash on dvb-s2 hd channels. After that dvbviewer load 2 copy in task manager(one of them is possible kill but another not)Problem absolve when I'm restart system. I'm fell when I'm scan a satellite program example dvbviewer is freezeing. When remote control do not communicate with system only restart system resolve this problem.
I'm not get more than 65% on 11393 v 27500 o hotbird 13e as a technisat digit cd is 80% level and skystar 2 is 78%.On this transponder tvn is also shred. Codec:coreavc,arcsoft,eclard,microsoft,cyberlink is tahat same.
This card it not work corectly,its very unstable. Any of manufacturer read topic on this forum? Anybody do anything for correct stabillity this card? Anybody fix problem with this card or a producer ignore problem and a costumers?
My compuert is Intel Dual Core E2140 | Gigabyte GA-P35-DS3L-REV1.0 Bios 9 | 2x1Gb Patriot Extreem 800Mhz Cl5 | Gigabyte Nvidia Geforce 8800GT Zalman Edition| Samsung SSD 64GB Thin+Samsung F2EG 1TB SATAII AHCI| Genius SP-HF 2000x|Asus Xonar DS | Skystar2 rev.2.6d// TBS 6921+SkyView/DVBVIEWER 4.5 | Corsair 400W CMPSU-400CXEU-| Samsung 2233SN Wide 22FULLHD | CoolerMaster Elite 332+Fander 120|Windows 7 PRO SP1
My English is very poor but i'm hope that you understand this.
freestat
Re: Unstable driver tbs 6921
Postby steven » Tue Jun 28, 2011 9:59 am
we have received your problem ,and we will give you a reply as soon as possible.
Postby freestat » Wed Jun 29, 2011 4:12 am
I;m very angry on driver 2.0.0.7 and 2.0.0.8 in dvbviewer 4.5/4.6 and 4.8.1 when i switching channel from example servus tv hd to zdf hd or arte hd(dvb-s2 astra)program is crash ad restart. On encrypted channels orf hd the picture are crash afther that program is resrat and I heard in my speakers very noise sound. I need restart system to fix this problem. Possible is that my tbs 6921 is a crash?
freestat
Postby steven » Wed Jun 29, 2011 3:29 pm
freestat Wrote:I;m very angry on driver 2.0.0.7 and 2.0.0.8 in dvbviewer 4.5/4.6 and 4.8.1 when i switching channel from example servus tv hd to zdf hd or arte hd(dvb-s2 astra)program is crash ad restart. On encrypted channels orf hd the picture are crash afther that program is resrat and I heard in my speakers very noise sound. I need restart system to fix this problem. Possible is that my tbs 6921 is a crash?
I am so sorry for your problem ,maybe your card has broken,you can contact our support for RMA service.
Postby A1880 » Wed Jun 29, 2011 4:48 pm
My tbs 6921 crashed for certain HD channels due to a wrong DiSEqC setting.
I don't use a DiSEqC switch. Therefore, the parameter should be "none" during channel scan.
By default, the channel scan is assuming the presence of DiSEqC.
Give it a try and report your findings!
Greetings
A1880
My PC:
Intel Core i7-2600 @3.40GHz, 8 Cores, 8 GByte RAM, 64 Bit Windows 7 Home Premium SP1, Dell XPS 8300
A1880
Postby freestat » Wed Jun 29, 2011 5:11 pm
@A1880 I thing that same, then I try without diseq and the results is that same. I try another Converter and the problem is that same. Diseq is not cause this problem. Prabobly card is broken or my motherboard(or pcie) is not compatibile with this card or driver on windows 7 pro with sp1 are not compatybile, although I'm dsipute because channels sd example hb ist ok, a few hd its good too,but often are dvbviewer crash on switching beetwen hd dvb-s2 most often ffrom and too servus hd,orh hd and anixe., signal on dvbviewer 70-75%.I'm think card is crash. Sory again for my poor engilsh.
freestat
Postby freestat » Thu Jul 07, 2011 6:12 pm
I soon send this card to a maker because the problem is no resolve.,but cost delivery to Bulgaria is 25$ that 1/3 price new card. On Driver 2.0.0.9 its that same,and worst dvbviewer allways crash now. After I back to 2.0.0.7 but its nothing help.
freestat
Postby safia1230 » Sun Mar 18, 2012 3:45 pm
i have also some problems and i hope that it will solve my problems also, thanks brother, keep itup
http://www.247mobilenews.com/
safia1230
Postby plavez » Sat Jul 07, 2012 9:25 pm
Hello, I need the driver for technical reasons, the old version V2.0.1.3. . Tell me where you can download it?
plavez
Postby Nenya » Sun Jul 08, 2012 3:24 am
Nenya
