MythTV capture card setup
Postby graufl » Mon Jun 27, 2011 8:42 am
I installed the drivers for the TBS-6981 from your homepage under Xbuntu 11.04.
Afterwards I installed mythtv.
Setting up the card however does not work as expected.
When I press the button for setting "DiSEqC (Switch, LNB, and Rotor Configuration)
I get the message "Unconnected".
What am I missing?
graufl
Re: MythTV capture card setup
Postby stinga » Wed Jun 29, 2011 12:51 am
G'day,
What does you log say?
Are you getting anything.
If I do as root
dmesg>delme
In delme I see...
TBS 6981 Frontend 0 Attaching...
DVB: registering new adapter (cx23885[0])
DVB: registering adapter 4 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
TurboSight TBS6981 Dual DVB-S2 card port0 MAC=f6458c60
cx23885_dvb_register() allocating 1 frontend(s)
cx23885[0]: cx23885 based dvb card
TBS 6981 Frontend 1 Attaching...
DVB: registering adapter 5 frontend 0 (TurboSight TBS 6981 DVBS/S2 frontend)...
TurboSight TBS6981 Dual DVB-S2 card port1 MAC=f6458db4
cx23885_dev_checkrevision() Hardware revision = 0xa5
cx23885[0]/0: found at 0000:02:00.0, rev: 4, irq: 16, latency: 0, mmio: 0xfd800000
cx23885 0000:02:00.0: setting latency timer to 64
I am not sure if this is corect yet, but I am mangaging to record of the card., I don't seem to be able to record S2 format yet. (I.E. BBC HD)
stinga
as of 01-Oct-2016
MB: gigabyte GA-P43-ES3G
RAM: 2GB
VGA: PNY Nvidia GT240 1GB
4 x Technisat skystar 2
2 x 500g pata
3 x 1TB sata
stinga
Postby telboy » Sat Jul 02, 2011 4:16 am
I get that, but when you highlight UNCONNECTED and hit enter, you get your choice.
telboy
Postby veehexx » Sat Jul 16, 2011 3:11 pm
telboy Wrote:I get that, but when you highlight UNCONNECTED and hit enter, you get your choice.
yeah, select 'Disconnected', hit enter, and then select LNB. job done.
that one had me stumped for a while on first setup of mythtv ; i didnt realise that i needed to select it first ;)
if your hibernate/sleeping mythtv, then you will need to setup a script to kill mythbackend, modprobe -r cx23885, and then it can sleep. on wakeup, modprobe cx23885, restart mythbackend and job done.
veehexx
