Some transponders good, other not
Postby bohan » Wed Jul 14, 2010 2:44 pm
I have a 2.3m dish with 2 dual output (V/H) C-band 5150LO LNBs on it, one aimed at Asiasat 3S (centre) and the other at Chinasat 6B (side). The 4 output cables are ~4m and go into a Zinwell SAM-6802 DIRECTV Approved 6x8 Flexport Multiswitch (not using the flexports).
Asiasat 3S is connected to the 0Khz inputs and Chinasat 6B to the 22Khz inputs.
receivers are connected, a Strong SRT4990 (weakest), a old Dion (also cheap nasty tuner) and a Mediastar HDX9100 (very sensitive tuner). These 3 can get just about all the c-band channels. The setup has been going strong for 6 years and was recently (~2 months) realigned to improve signal qaulity for a few weak stations (TVB8 and hnstv).
I just setup a spare Intel E8400, G41 chipset PC as a MythTV backend an ubuntu 10.04 with 1xWinfast DTV1000S (NXP/TDA chipset) and 1x TBS 8920. Initially the DTV1000s did not work due to kernel support (2.6.32) so I upgraded to a 2.6.33-realtime kernel from the ubuntu studio repo. This allowed both cards to work, with the DTV1000s working fine but the TBS 8920 only working well for the Asiasat 3S channels (0Khz). Initially I thought this was a bug in MythTV's Tone Switch, but then discovered that 2-3 transponders out of the 20+ on Chinasat 6B were okay (CCTV mainly, including 4100V CCTV-HD).
I after going back to the official kernel and upgrading to the latest v4l-dvb linuxtv repo drivers, everything was working well and I was getting all the channels. However, a week later, after powering down the machine and restarted (for installation of a graphics card that turned out to be too thick), the situation turned back to when I was on the 2.6.33-realtime, in that most transponders on the 22khz LNB do not get a signal. I have checked that all other kernels and there headers have been purged and also tried the 2.6.32 drivers dated 201006 from TBS website with the same results.
It appears to be similar to this (but different, in that the asiasat 3s = no problem):
viewtopic.php?f=11&t=36&start=10
I have tried to switch slots (only have 2 on this MSI G41M-P33) but not difference.
Is there something about the way the TBS 8920 is generating the 22Khz tone that is causing this problem. Is anyone else using a tone switch (0/22Khz) with this card? For sone reason I can only pick the CCTV (all 10+) and most asiasat 3S (except FTV, some others). IF it is a weak signal condition surely TVB8 and Sun TV would go first (they are the weakest according to the other receivers.
bohan
Re: Some transponders good, other not
Postby bohan » Wed Jul 14, 2010 9:59 pm
bh@solo:~$ dmesg | grep 24116
[ 19.008193] DVB: registering adapter 5 frontend 0 (Conexant CX24116/CX24118)...
[ 29.837909] cx24116_firmware_ondemand: Waiting for firmware upload (dvb-fe-cx24116.fw)...
[ 29.837913] cx8800 0000:04:01.0: firmware: requesting dvb-fe-cx24116.fw
[ 29.840778] cx24116_firmware_ondemand: Waiting for firmware upload(2)...
[ 34.878283] cx24116_load_firmware: FW version 1.26.90.0
[ 34.878291] cx24116_firmware_ondemand: Firmware upload complete
bh@solo:~$ dmesg | grep cx88
[ 18.372165] cx88/0: cx2388x v4l2 driver version 0.0.7 loaded
[ 18.372194] cx8800 0000:04:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 18.372324] cx88[0]: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72,autodetected], frontend(s): 1
[ 18.372326] cx88[0]: TV tuner type 4, Radio tuner type -1
[ 18.375028] cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.7 loaded
[ 18.991325] input: cx88 IR (TBS 8920 DVB-S/S2) as /devices/pci0000:00/0000:00:1e.0/0000:04:01.0/input/input7
[ 18.991378] cx88[0]/0: found at 0000:04:01.0, rev: 5, irq: 17, latency: 128, mmio: 0xfd000000
[ 18.991387] IRQ 17/cx88[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[ 18.991429] cx88[0]/0: registered device video0 [v4l2]
[ 18.991446] cx88[0]/0: registered device vbi0
[ 18.991498] cx88[0]/2: cx2388x 8802 Driver Manager
[ 18.991512] cx88-mpeg driver manager 0000:04:01.2: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 18.991519] cx88[0]/2: found at 0000:04:01.2, rev: 5, irq: 17, latency: 128, mmio: 0xfc000000
[ 18.991521] IRQ 17/cx88[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[ 19.002192] cx88/2: cx2388x dvb driver version 0.0.7 loaded
[ 19.002194] cx88/2: registering cx8802 driver, type: dvb access: shared
[ 19.002196] cx88[0]/2: subsystem: 8920:8888, board: TBS 8920 DVB-S/S2 [card=72]
[ 19.002198] cx88[0]/2: cx2388x based DVB/ATSC card
[ 19.002199] cx8802_alloc_frontends() allocating 1 frontend(s)
[ 19.008190] DVB: registering new adapter (cx88[0])
[ 7031.326584] cx88[0]: irq mpeg [0x100000] ts_err?*
[ 7031.326588] cx88[0]/2-mpeg: general errors: 0x00100000
bohan
Postby bohan » Wed Jul 14, 2010 10:01 pm
bh@solo:~$ dmesg | grep tda
[ 19.320007] tda8290: no gate control were provided!
[ 19.515469] tda18271 2-0060: creating new instance
[ 21.090186] tda10048_firmware_upload: waiting for firmware upload (dvb-fe-tda10048-1.0.fw)...
[ 21.090191] saa7134 0000:04:00.0: firmware: requesting dvb-fe-tda10048-1.0.fw
[ 21.754011] tda10048_firmware_upload: firmware read 24878 bytes.
[ 21.754013] tda10048_firmware_upload: firmware uploading
[ 27.150010] tda10048_firmware_upload: firmware uploaded
[ 40.760010] tda18271: performing RF tracking filter calibration
[ 49.480010] tda18271: RF tracking filter calibration complete
bh@solo:~$ dmesg | grep saa
[ 18.384696] saa7130/34: v4l2 driver version 0.2.15 loaded
[ 18.991620] saa7134 0000:04:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 18.991624] saa7130[0]: found at 0000:04:00.0, rev: 1, irq: 16, latency: 128, mmio: 0xfebffc00
[ 18.991629] saa7130[0]: subsystem: 107d:6655, board: Leadtek Winfast DTV1000S [card=175,autodetected]
[ 18.991640] saa7130[0]: board init: gpio is 2020000
[ 18.991682] input: saa7134 IR (Leadtek Winfast DTV as /devices/pci0000:00/0000:00:1e.0/0000:04:00.0/input/input8
[ 18.991703] IRQ 16/saa7130[0]: IRQF_DISABLED is not guaranteed on shared IRQs
[ 19.181309] saa7130[0]: i2c eeprom 00: 7d 10 55 66 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
[ 19.181317] saa7130[0]: i2c eeprom 10: 00 ff 82 0e ff 20 ff ff ff ff ff ff ff ff ff ff
[ 19.181323] saa7130[0]: i2c eeprom 20: 01 40 01 01 01 ff 01 03 08 ff 00 8a ff ff ff ff
[ 19.181329] saa7130[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181335] saa7130[0]: i2c eeprom 40: ff 35 00 c0 00 10 03 02 ff 04 ff ff ff ff ff ff
[ 19.181340] saa7130[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181346] saa7130[0]: i2c eeprom 60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181368] saa7130[0]: i2c eeprom 70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181374] saa7130[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181379] saa7130[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181385] saa7130[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181391] saa7130[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181397] saa7130[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181403] saa7130[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181409] saa7130[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.181414] saa7130[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
[ 19.230124] tuner 2-0060: chip found @ 0xc0 (saa7130[0])
[ 19.320179] saa7130[0]: registered device video1 [v4l2]
[ 19.320198] saa7130[0]: registered device vbi1
[ 19.323850] saa7134 ALSA driver for DMA sound loaded
[ 19.323852] saa7130[0]/alsa: Leadtek Winfast DTV1000S doesn't support digital audio
[ 20.270131] DVB: registering new adapter (saa7130[0])
bohan
Postby cody » Fri Jul 16, 2010 4:35 pm
i noticed that you use:
as a starting point i will try with downgrading CX24116 FW to version 1.23.86.1
Postby bohan » Sun Jul 18, 2010 8:41 pm
Where do we download the older firmware?
Is there a TBS 8920 customized firmware?
bohan
Postby cody » Tue Jul 20, 2010 10:44 pm
bohan Wrote:Where do we download the older firmware?
Linux driver package on the website contains all necessary firmwares:
https://shop.tbsdtv.com/download2/common/ ... 100718.rar
and it's regularly updated, when it's necessary.
