Some Special Satellite Frequency that TBS6925 can receive
Postby steven » Thu Jun 23, 2011 2:52 pm
Here are some of the ACM signals that we have tested with TBS6925 so far.Hope people who have bought our TBS6925 can help us to test more special frequency points, if you have interested in it,go to follow thread to reply for your new point.Thanks a lot. :P
Thanks dubaisatshop,The latest frequency list update as of July 14:
Re: Some Special Satellite Frequency that TBS6925 can receiv
Postby dubaisatshop » Thu Jun 23, 2011 8:01 pm
Eutelsat W6 21.6E, 11413 V 18500
Badr/Eurobird 26E, 11566 H 5625
dubaisatshop
Postby steven » Fri Jun 24, 2011 10:50 am
dubaisatshop Wrote:
Hi, dubaisatshop
Thank you very much for your support and your frequency points. Your post reply is very important for us. :P
Postby starman345 » Sat Jun 25, 2011 5:41 am
This one is from AMC 2 @ 79W.
11792V SR 1000
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby starman345 » Sun Jun 26, 2011 9:52 pm
Another ACM multiple input stream transponder, this one from Galaxy 13 @127W very low signal on this one
55.5W to 139W
Windows 8.1 64 bit
starman345
Postby steven » Mon Jun 27, 2011 9:57 am
Join this discussion, there will be pleasant surprises ;)
Postby steven » Mon Jun 27, 2011 2:28 pm
starman345 Wrote:This one is from AMC 2 @ 79W.
11792V SR 1000
hi starman345,
Thank You For Your Sharing !
Postby steven » Mon Jun 27, 2011 2:29 pm
But why very low signal from Galaxy 13 @127W? :?:
Postby starman345 » Tue Jun 28, 2011 6:08 am
Hi Steven,
The signal on Galaxy 13 was very low, it was hard to lock.
I am curious why there is no selections in the "Input stream Identify" drop down box. The TBS recorder reports the signal as Multi stream in both the examples above, but shouldn't there be information in that drop down box to identify the various streams present? I'v wondering if they really are multi stream transponders or maybe there just isn't data present from time to time?
55.5W to 139W
Windows 8.1 64 bit
starman345
Postby steven » Tue Jun 28, 2011 9:52 am
starman345 Wrote:Hi Steven,
Hi starman
Really thanks for your test.
For this problem , i think the stream Identify maybe is 0,because from the pic you give MATYPE is 42 00,another reason maybe is the signal is
very weak as you can see the quality is 0,and do you have tested another MS transponder? is it have stream Identify input?
