before I start here is my setting:
Zbox ID11 Atom ION2
Linux Kernel 2.6.32-32 generic ubuntu
xbmc ppa odk 40
vdr 1.7.18
vnsi server plugin
Tbs USB2 qboxs2 (qbox 2)
FW version 1.23.86.1
/etc/default/ (grub: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend=-1"') is set
/etc/pm/sleep.d (00sleep_module : SUSPEND_MODULES="$SUSPEND_MODULES xhci dvb_usb dvb_core dvb_usb_tbsqboxs2 cx24116 " is set
Problem:
Resume from suspend does work, but reinitialisation of USB QBOXS2 doesn´t work. I have to power off the qbox (unplug from power) manually to get it recognised again:
- Code: Select All Code
dmesg | grep -i dvb
[ 2442.893270] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully deinitialized and disconnected.
[ 2448.660199] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 2448.660208] usb 1-4: firmware: requesting dvb-usb-tbsqbox-id5928.fw
[ 2508.660089] dvb-usb: did not find the firmware file. (dvb-usb-tbsqbox-id5928.fw) Please see linux/Documentation/dvb/ for more details on firmware-problems. (-2)
[ 2508.660630] Modules linked in: snd_hda_codec_nvhdmi joydev hidp snd_hda_codec_realtek snd_hda_intel snd_hda_codec snd_hwdep snd_pcm_oss cx24116 snd_mixer_oss snd_pcm snd_seq_dummy snd_seq_oss snd_seq_midi binfmt_misc snd_rawmidi rfcomm snd_seq_midi_event sco bridge snd_seq stp bnep arc4 fbcon dvb_usb_tbsqboxs2 tileblit snd_timer font bitblit ppdev l2cap dvb_usb coretemp snd_seq_device ath9k mac80211 ath snd softcursor nvidia(P) usbhid hid cdc_acm vga16fb vgastate cfg80211 soundcore btusb lp dvb_core psmouse bluetooth serio_raw led_class snd_page_alloc intel_agp parport r8169 mii
stuck here and nothing else (firmware is located at /lib/firmware) .
Now I unplug the qbox from power and plug it again it
says:
[ 2671.314794] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 2671.314810] usb 1-4: firmware: requesting dvb-usb-tbsqbox-id5928.fw
[ 2671.319156] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5928.fw'
[ 2671.319176] usb 1-4: firmware: requesting dvb-usb-tbsqbox-id5928.fw
[ 2671.450045] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in warm state.
[ 2671.450168] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 2671.454228] DVB: registering new adapter (TBS QBOXS2 DVBS2 USB2.0)
[ 2671.462409] dvb-usb: MAC address reading failed.
[ 2671.516871] dvb-usb: no frontend was attached by 'TBS QBOXS2 DVBS2 USB2.0'
[ 2671.525164] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/input/input12
[ 2671.525330] dvb-usb: schedule remote query interval to 150 msecs.
[ 2671.525343] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully initialized and connected.
[ 2671.581053] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully deinitialized and disconnected.
[ 2673.283794] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in cold state, will try to load a firmware
[ 2673.283808] usb 1-4: firmware: requesting dvb-usb-tbsqbox-id5928.fw
[ 2673.287708] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5928.fw'
[ 2673.287723] usb 1-4: firmware: requesting dvb-usb-tbsqbox-id5928.fw
[ 2673.430256] dvb-usb: found a 'TBS QBOXS2 DVBS2 USB2.0' in warm state.
[ 2673.430383] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 2673.430664] DVB: registering new adapter (TBS QBOXS2 DVBS2 USB2.0)
[ 2673.597137] dvb-usb: MAC address: 00:22:ab:c0:0d:18
[ 2673.640491] DVB: registering adapter 0 frontend 0 (Conexant CX24116/CX24118)...
[ 2673.641331] input: IR-receiver inside an USB DVB receiver as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/input/input13
[ 2673.641632] dvb-usb: schedule remote query interval to 150 msecs.
[ 2673.641646] dvb-usb: TBS QBOXS2 DVBS2 USB2.0 successfully initialized and connected.
I have to reload vdr manually in this case.
If i unplug the usb-qboxs2 while the PC is in suspend, init works at resume and vdr works also without restarting.
Here are my questions: Is resume from suspend possible with this device ?
How can I (hard)reset the device before suspending to force an automatic firmware load at resume ?
Thank you for your help
Matrix321
