No Device because no Driver
Postby Gregor » Wed Jun 08, 2011 6:57 pm
yesterday come my new card for my Linux PC and i was very happy. Now i´m very said because: The Card is 100% Linux Compatible!? What?? Im using Gentoo Linux Kernel 2.6.38. There is no Device name /dev/dvb or /dev/video the driver that i can download is up to 2.6.38 so i cant use it. I have test it but it says to me that the kernel doesnt match the driver. So i have a new card here and can´t use it. WTF? 10 hours i had test some things but allways no card or many errors.
Please Please help me that i can use this Card under my Gentoo because Gentoo is also Linux not just Ubuntu or Fedora.
Gregor
Re: No Device because no Driver
Postby Gregor » Tue Jan 31, 2012 2:14 am
i dont have any usable adapter @ /dev/
3.2) 'dmesg' log after driver installation (if applicable, please see 1. too):
# dmesg >> dmesg_log
The Driver Installation doesnt work.
3.3):
* log of 'lspci' output (only if you have PCI or PCI-Expreess card):
# lspci -vvnn
02:00.0 Multimedia video controller [0400]: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder [14f1:8852] (rev 02)
   Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
   Interrupt: pin A routed to IRQ 5
   Region 0: Memory at fe800000 (64-bit, non-prefetchable) [size=2M]
   Capabilities: [40] Express (v1) Endpoint, MSI 00
      DevCap:   MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
      DevCtl:   Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
      DevSta:   CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
      LnkCap:   Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Latency L0 <2us, L1 <4us
      LnkCtl:   ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
      LnkSta:   Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
      Flags: PMEClk- DSI+ D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold-)
   Capabilities: [90] Vital Product Data
      Unknown small resource type 01, will not decode more.
   Capabilities: [a0] MSI: Enable- Count=1/1 Maskable- 64bit+
   Capabilities: [100 v1] Advanced Error Reporting
      UESta:   DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
      UEMsk:   DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
      UESvrt:   DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
      CESta:   RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
      CEMsk:   RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
      AERCap:   First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
   Capabilities: [200 v1] Virtual Channel
      Caps:   LPEVC=0 RefClk=100ns PATEntryBits=1
      Arb:   Fixed+ WRR32+ WRR64+ WRR128-
      Ctrl:   ArbSelect=WRR64
      Status:   InProgress-
      Port Arbitration Table [240] <?>
      VC0:   Caps:   PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
         Arb:   Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
         Ctrl:   Enable+ ID=0 ArbSelect=Fixed TC/VC=01
         Status:   NegoPending- InProgress-
Linux serverchen 3.1.10-gentoo-r1 #11 SMP Mon Jan 30 19:00:21 CET 2012 x86_64 AMD A6-3650 APU with Radeon(tm) HD Graphics AuthenticAMD GNU/Linux
serverchen linux-tbs-drivers # make && make install
make -C /root/tbs/linux-tbs-drivers/v4l
make[1]: Entering directory `/root/tbs/linux-tbs-drivers/v4l'
No version yet, using 3.1.10-gentoo-r1
make[1]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.1.10
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.1.10-gentoo-r1/source ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/root/tbs/linux-tbs-drivers/v4l/firmware'
make -C firmware
  CC  ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/3.1.10-gentoo-r1/build
make -C /lib/modules/3.1.10-gentoo-r1/build SUBDIRS=/root/tbs/linux-tbs-drivers/v4l  modules
make[2]: Entering directory `/usr/src/linux-3.1.10-gentoo-r1'
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au8522_dig.o
  CC [M]  /root/tbs/linux-tbs-drivers/v4l/au8522_decoder.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/snd-bt87x.o
  Building modules, stage 2.
  MODPOST 459 modules
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5880ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5880ctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5922ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5922ctrl.o
WARNING: could not find /root/tbs/linux-tbs-drivers/v4l/.tbs5921ctrl.o.cmd for /root/tbs/linux-tbs-drivers/v4l/tbs5921ctrl.o
WARNING: "i2c_bit_add_bus" [/root/tbs/linux-tbs-drivers/v4l/saa716x_tbs-dvb.ko] undefined!
WARNING: "i2c_bit_add_bus" [/root/tbs/linux-tbs-drivers/v4l/dm1105.ko] undefined!
  CC      /root/tbs/linux-tbs-drivers/v4l/adp1653.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/adp1653.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/adv7170.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/adv7170.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/adv7175.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/adv7175.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/videobuf-vmalloc.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/videobuf-vmalloc.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/videobuf2-core.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/videobuf2-core.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/videobuf2-dma-contig.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/videobuf2-dma-contig.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/videobuf2-dma-sg.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/videobuf2-dma-sg.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/videobuf2-memops.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/videobuf2-memops.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/videobuf2-vmalloc.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/videobuf2-vmalloc.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/videodev.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/videodev.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/vivi.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/vivi.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/vp27smpx.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/vp27smpx.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/vpx3220.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/vpx3220.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/wm8739.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/wm8739.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/wm8775.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/wm8775.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/xc4000.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/xc4000.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/xc5000.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/xc5000.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/zl10036.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/zl10036.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/zl10039.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/zl10039.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/zl10353.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/zl10353.ko
  CC      /root/tbs/linux-tbs-drivers/v4l/zr364xx.mod.o
  LD [M]  /root/tbs/linux-tbs-drivers/v4l/zr364xx.ko
make[2]: Leaving directory `/usr/src/linux-3.1.10-gentoo-r1'
./scripts/rmmod.pl check
found 459 modules
make -C /root/tbs/linux-tbs-drivers/v4l install
\nRemoving obsolete files from /lib/modules/3.1.10-gentoo-r1/kernel/drivers/media/IR/keymaps:
\nRemoving obsolete files from /lib/modules/3.1.10-gentoo-r1/kernel/drivers/media/video:
\nRemoving obsolete files from /lib/modules/3.1.10-gentoo-r1/kernel/drivers/media/dvb/cinergyT2:
\nRemoving obsolete files from /lib/modules/3.1.10-gentoo-r1/kernel/drivers/media/common:
\nRemoving obsolete files from /lib/modules/3.1.10-gentoo-r1/kernel/drivers/media/dvb/frontends:
\nRemoving obsolete files from /lib/modules/3.1.10-gentoo-r1/kernel/drivers/media/IR:
Installing kernel modules under /lib/modules/3.1.10-gentoo-r1/kernel/drivers/media/:
   video/gspca/m5602/: gspca_m5602.ko
   video/cpia2/: cpia2.ko
   dvb/b2c2/: b2c2-flexcop-pci.ko b2c2-flexcop.ko b2c2-flexcop-usb.ko
   video/hdpvr/: hdpvr.ko
   video/sn9c102/: sn9c102.ko
   dvb/dvb-core/: dvb-core.ko
   video/: adp1653.ko videobuf-dma-contig.ko vpx3220.ko
      videobuf-dma-sg.ko bt856.ko v4l2-mem2mem.ko
      ov5642.ko upd64083.ko v4l2-compat-ioctl32.ko
      videobuf-core.ko noon010pc30.ko ths7303.ko
      videobuf2-memops.ko tda9840.ko saa7191.ko
      cx2341x.ko wm8775.ko adv7180.ko
      rj54n1cb0c.ko saa7185.ko tuner.ko
      mt9t031.ko zr364xx.ko ov2640.ko
      ks0127.ko videobuf-dvb.ko tvaudio.ko
      tea6420.ko bt866.ko mt9v011.ko
      imx074.ko msp3400.ko tvp514x.ko
      mem2mem_testdev.ko tcm825x.ko soc_camera.ko
      wm8739.ko stkwebcam.ko soc_mediabus.ko
      sr030pc30.ko tda7432.ko ir-kbd-i2c.ko
      mt9m001.ko upd64031a.ko tea6415c.ko
      videobuf2-dma-contig.ko bt819.ko ov6650.ko
      videodev.ko ov9740.ko mxb.ko
      adv7175.ko vivi.ko soc_camera_platform.ko
      adv7343.ko cs53l32a.ko s2255drv.ko
      btcx-risc.ko saa7110.ko saa7115.ko
      saa6588.ko ak881x.ko tvp7002.ko
      v4l2-common.ko hexium_gemini.ko hexium_orion.ko
      tw9910.ko tvp5150.ko mt9m111.ko
      vp27smpx.ko adv7170.ko ov772x.ko
      ov7670.ko saa7127.ko m52790.ko
      ov9640.ko mt9v022.ko videobuf-vmalloc.ko
      videobuf2-core.ko v4l2-int-device.ko tveeprom.ko
      mt9v032.ko cs5345.ko saa717x.ko
      videobuf2-dma-sg.ko videobuf2-vmalloc.ko tlv320aic23b.ko
      mt9t112.ko
   dvb/siano/: smsdvb.ko smsusb.ko smsmdtv.ko
   video/cx231xx/: cx231xx.ko cx231xx-dvb.ko cx231xx-alsa.ko
   video/saa7134/: saa6752hs.ko saa7134-empress.ko saa7134-alsa.ko
      saa7134-dvb.ko saa7134.ko
   dvb/ttpci/: dvb-ttpci.ko budget-patch.ko ttpci-eeprom.ko
      budget-av.ko budget.ko budget-core.ko
      budget-ci.ko
   radio/si470x/: radio-usb-si470x.ko
   dvb/frontends/: nxt6000.ko dib7000m.ko dib0090.ko
      tbsfe.ko s5h1411.ko drxd.ko
      dib9000.ko tda665x.ko dib8000.ko
      nxt200x.ko stv0367.ko s921.ko
      s5h1409.ko tbs6921fe.ko atbm8830.ko
      cxd2820r.ko dib3000mb.ko ec100.ko
      lgs8gl5.ko dib3000mc.ko stv0900.ko
      sp8870.ko tbs6980fe.ko tda8083.ko
      stv0297.ko tda10086.ko zl10353.ko
      mb86a16.ko lgs8gxx.ko tbs6992.ko
      stv0299.ko dvb-pll.ko cx22702.ko
      tda8261.ko tua6100.ko tbs62x0fe.ko
      bcm3510.ko or51211.ko stb0899.ko
      tbs5880fe.ko tbs8922fe.ko cx24113.ko
      tda826x.ko mb86a20s.ko af9013.ko
      tbs6925ctrl.ko drxk.ko ix2505v.ko
      tbs6922fe.ko si21xx.ko au8522.ko
      s5h1420.ko stv090x.ko stv0288.ko
      mt352.ko zl10039.ko isl6405.ko
      tbs8921fe.ko sp887x.ko dibx000_common.ko
      isl6421.ko mt312.ko or51132.ko
      tbs5922fe.ko tda1004x.ko tda18271c2dd.ko
      tbs6984fe.ko stv6110.ko itd1000.ko
      stv6110x.ko zl10036.ko lgdt3305.ko
      dib7000p.ko l64781.ko ves1x93.ko
      stb6100.ko ves1820.ko dib0070.ko
      tbs5921fe.ko cx22700.ko cx24110.ko
      tbs6928fe.ko dvb_dummy_fe.ko lgdt330x.ko
      cx24123.ko lnbp21.ko stb6000.ko
      isl6423.ko tda10023.ko cx24116.ko
      tbs6981fe.ko tda10021.ko tda10048.ko
      ds3000.ko s5h1432.ko
   video/gspca/: gspca_xirlink_cit.ko gspca_stk014.ko gspca_spca501.ko
      gspca_spca500.ko gspca_mars.ko gspca_spca1528.ko
      gspca_stv0680.ko gspca_sunplus.ko gspca_vc032x.ko
      gspca_benq.ko gspca_spca505.ko gspca_sn9c20x.ko
      gspca_zc3xx.ko gspca_vicam.ko gspca_sq930x.ko
      gspca_sq905c.ko gspca_sonixb.ko gspca_etoms.ko
      gspca_pac7302.ko gspca_pac207.ko gspca_konica.ko
      gspca_ov534_9.ko gspca_spca508.ko gspca_nw80x.ko
      gspca_sq905.ko gspca_t613.ko gspca_sn9c2028.ko
      gspca_spca561.ko gspca_ov534.ko gspca_tv8532.ko
      gspca_jeilinj.ko gspca_spca506.ko gspca_se401.ko
      gspca_sonixj.ko gspca_main.ko gspca_cpia1.ko
      gspca_conex.ko gspca_mr97310a.ko gspca_kinect.ko
      gspca_pac7311.ko gspca_ov519.ko gspca_finepix.ko
   rc/: lirc_dev.ko redrat3.ko ir-sony-decoder.ko
      ene_ir.ko mceusb.ko rc-core.ko
      streamzap.ko ir-nec-decoder.ko ir-rc5-decoder.ko
      fintek-cir.ko ir-rc6-decoder.ko rc-loopback.ko
      ir-jvc-decoder.ko nuvoton-cir.ko ir-rc5-sz-decoder.ko
      ir-mce_kbd-decoder.ko ir-lirc-codec.ko imon.ko
      ite-cir.ko
   video/m5mols/: m5mols.ko
   common/: saa7146_vv.ko saa7146.ko
   radio/: dsbr100.ko si4713-i2c.ko tef6862.ko
      radio-maxiradio.ko saa7706h.ko radio-tea5764.ko
      radio-si4713.ko radio-mr800.ko
   video/pvrusb2/: pvrusb2.ko
   dvb/pt1/: earth-pt1.ko
   rc/keymaps/: rc-tevii-nec.ko rc-terratec-slim.ko rc-adstech-dvb-t-pci.ko
      rc-pctv-sedna.ko rc-proteus-2309.ko rc-msi-tvanywhere.ko
      rc-avermedia-dvbt.ko rc-pixelview.ko rc-avermedia-rm-ks.ko
      rc-dm1105-nec.ko rc-encore-enltv-fm53.ko rc-digittrade.ko
      rc-imon-mce.ko rc-evga-indtube.ko rc-em-terratec.ko
      rc-hauppauge.ko rc-gadmei-rm008z.ko rc-avermedia-m733a-rm-k6.ko
      rc-alink-dtu-m.ko rc-dntv-live-dvb-t.ko rc-anysee.ko
      rc-kworld-plus-tv-analog.ko rc-behold.ko rc-norwood.ko
      rc-pinnacle-color.ko rc-cinergy-1400.ko rc-leadtek-y04g0051.ko
      rc-avertv-303.ko rc-msi-digivox-ii.ko rc-total-media-in-hand.ko
      rc-trekstor.ko rc-cinergy.ko rc-tivo.ko
      rc-manli.ko rc-eztv.ko rc-lme2510.ko
      rc-kworld-315u.ko rc-twinhan1027.ko rc-avermedia-a16d.ko
      rc-tt-1500.ko rc-videomate-tv-pvr.ko rc-apac-viewcomp.ko
      rc-terratec-cinergy-xs.ko rc-nebula.ko rc-msi-tvanywhere-plus.ko
      rc-msi-digivox-iii.ko rc-npgtech.ko rc-ati-tv-wonder-hd-600.ko
      rc-videomate-m1f.ko rc-pinnacle-pctv-hd.ko rc-iodata-bctv7e.ko
      rc-budget-ci-old.ko rc-avermedia.ko rc-pixelview-002t.ko
      rc-imon-pad.ko rc-digitalnow-tinytwin.ko rc-nec-terratec-cinergy-xs.ko
      rc-winfast-usbii-deluxe.ko rc-flydvb.ko rc-videomate-s350.ko
      rc-pv951.ko rc-pixelview-mk12.ko rc-winfast.ko
      rc-lirc.ko rc-encore-enltv2.ko rc-pixelview-new.ko
      rc-purpletv.ko rc-fusionhdtv-mce.ko rc-technisat-usb2.ko
      rc-dib0700-rc5.ko rc-gotview7135.ko rc-kaiomy.ko
      rc-pinnacle-grey.ko rc-powercolor-real-angel.ko rc-terratec-slim-2.ko
      rc-avermedia-m135a.ko rc-azurewave-ad-tu700.ko rc-encore-enltv.ko
      rc-flyvideo.ko rc-tbs-nec.ko rc-dib0700-nec.ko
      rc-behold-columbus.ko rc-streamzap.ko rc-avermedia-cardbus.ko
      rc-real-audio-220-32-keys.ko rc-genius-tvgo-a11mce.ko rc-rc6-mce.ko
      rc-dntv-live-dvbt-pro.ko rc-asus-pc39.ko
   dvb/ttusb-budget/: dvb-ttusb-budget.ko
   common/saa716x/: saa716x_tbs-dvb.ko saa716x_core.ko
   dvb/dvb-usb/: dvb-usb-tbsqboxs2.ko dvb-usb-opera.ko dvb-usb-vp7045.ko
      dvb-usb-technisat-usb2.ko dvb-usb-ttusb2.ko dvb-usb-tbsqbox.ko
      dvb-usb-af9015.ko dvb-usb-tbsqbox22.ko dvb-usb-az6027.ko
      dvb-usb-tbsqbox2ci.ko dvb-usb-gp8psk.ko dvb-usb-af9005.ko
      dvb-usb-nova-t-usb2.ko dvb-usb-tbsqbox2.ko dvb-usb-cinergyT2.ko
      dvb-usb-umt-010.ko dvb-usb-anysee.ko dvb-usb-gl861.ko
      dvb-usb-ec168.ko dvb-usb-dtv5100.ko dvb-usb-cxusb.ko
      dvb-usb-af9005-remote.ko dvb-usb-dib0700.ko dvb-usb-a800.ko
      dvb-usb-lmedm04.ko dvb-usb-tbs5880.ko dvb-usb-dibusb-common.ko
      dvb-usb-au6610.ko dvb-usb-dibusb-mc.ko dvb-usb.ko
      dvb-usb-digitv.ko dvb-usb-tbsqboxs3.ko dvb-usb-friio.ko
      dvb-usb-ce6230.ko dvb-usb-dtt200u.ko dvb-usb-vp702x.ko
      dvb-usb-dibusb-mb.ko dvb-usb-dw2102.ko dvb-usb-m920x.ko
   dvb/ddbridge/: ddbridge.ko
   video/marvell-ccic/: cafe_ccic.ko
   dvb/mantis/: mantis_core.ko mantis.ko hopper.ko
   common/tuners/: xc4000.ko tuner-xc2028.ko tda18218.ko
      mt2060.ko tda9887.ko mt2131.ko
      mc44s803.ko qt1010.ko max2165.ko
      mt20xx.ko tda827x.ko tda18271.ko
      tda18212.ko xc5000.ko mxl5007t.ko
      tea5761.ko tuner-types.ko tda8290.ko
      tuner-simple.ko mt2266.ko tea5767.ko
      mxl5005s.ko
   video/cx25840/: cx25840.ko
   dvb/ttusb-dec/: ttusbdecfe.ko ttusb_dec.ko
   dvb/ngene/: ngene.ko
   dvb/dm1105/: dm1105.ko
   ../linux/drivers/media/: media.ko
   video/gspca/gl860/: gspca_gl860.ko
   video/et61x251/: et61x251.ko
   video/usbvision/: usbvision.ko
   video/gspca/stv06xx/: gspca_stv06xx.ko
   video/em28xx/: em28xx-dvb.ko em28xx-alsa.ko em28xx.ko
   video/tlg2300/: poseidon.ko
   video/uvc/: uvcvideo.ko
   video/pwc/: pwc.ko
/sbin/depmod -a 3.1.10-gentoo-r1
make -C firmware install
Installing firmwares at /lib/firmware: vicam/firmware.fw dabusb/firmware.fw dabusb/bitstream.bin ttusb-budget/dspbootcode.bin cpia2/stv0672_vp4.bin av7110/bootcode.bin
Gregor
Postby cody » Tue Jan 31, 2012 3:57 am
without 'dmesg' log no matter if 'The Driver Installation doesnt work.' or it works i can't help you - i mean on the 'dmesg' log there is information if the driver fails to load for some reason.
Postby Gregor » Tue Jan 31, 2012 4:54 am
The Driver install seems to work but it has same warnings.
dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.1.10-gentoo-r1 (root@serverchen) (gcc version 4.5.3 (Gentoo 4.5.3-r1 p1.0, pie-0.4.5) ) #11 SMP Mon Jan 30 19:00:21 CET 2012
[    0.000000] Command line: root=/dev/sda3 video=uvesafb:1280x1024-32,mttr:3,ywrap quiet
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009d800 (usable)
[    0.000000]  BIOS-e820: 000000000009d800 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 00000000df7c9000 (usable)
[    0.000000]  BIOS-e820: 00000000df7c9000 - 00000000df92e000 (reserved)
[    0.000000]  BIOS-e820: 00000000df92e000 - 00000000dfb31000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dfb31000 - 00000000dfd12000 (usable)
[    0.000000]  BIOS-e820: 00000000dfd12000 - 00000000dfd60000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dfd60000 - 00000000dfd69000 (ACPI data)
[    0.000000]  BIOS-e820: 00000000dfd69000 - 00000000dfd6c000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dfd6c000 - 00000000dfd6d000 (usable)
[    0.000000]  BIOS-e820: 00000000dfd6d000 - 00000000dfea6000 (reserved)
[    0.000000]  BIOS-e820: 00000000dfea6000 - 00000000dfeb7000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dfeb7000 - 00000000dfec8000 (reserved)
[    0.000000]  BIOS-e820: 00000000dfec8000 - 00000000dfec9000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dfec9000 - 00000000dfed9000 (reserved)
[    0.000000]  BIOS-e820: 00000000dfed9000 - 00000000dfeda000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dfeda000 - 00000000dfedb000 (reserved)
[    0.000000]  BIOS-e820: 00000000dfedb000 - 00000000dfee1000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000dfee1000 - 00000000dfef4000 (reserved)
[    0.000000]  BIOS-e820: 00000000dfef4000 - 00000000dff00000 (usable)
[    0.000000]  BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec10000 - 00000000fec11000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed00000 - 00000000fed01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed61000 - 00000000fed71000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed80000 - 00000000fed90000 (reserved)
[    0.000000]  BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[    0.000000]  BIOS-e820: 0000000100001000 - 0000000217000000 (usable)
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] DMI 2.6 present.
[    0.000000] DMI: System manufacturer System Product Name/F1A75-M LE, BIOS 1302 12/09/2011
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] No AGP bridge found
[    0.000000] last_pfn = 0x217000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF write-through
[    0.000000]   C0000-CEFFF write-protect
[    0.000000]   CF000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 0000000000 mask FF80000000 write-back
[    0.000000]   1 base 0080000000 mask FFC0000000 write-back
[    0.000000]   2 base 00C0000000 mask FFE0000000 write-back
[    0.000000]   3 base 00DFF00000 mask FFFFF00000 uncachable
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] TOM2: 000000021f000000 aka 8688M
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820 update range: 00000000dff00000 - 0000000100000000 (usable) ==> (reserved)
[    0.000000] last_pfn = 0xdff00 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [ffff8800000fcdf0] fcdf0
[    0.000000] initial memory mapped : 0 - 20000000
[    0.000000] Base memory trampoline at [ffff880000098000] 98000 size 20480
[    0.000000] Using GB pages for direct mapping
[    0.000000] init_memory_mapping: 0000000000000000-00000000dff00000
[    0.000000]  0000000000 - 00c0000000 page 1G
[    0.000000]  00c0000000 - 00dfe00000 page 2M
[    0.000000]  00dfe00000 - 00dff00000 page 4k
[    0.000000] kernel direct mapping tables up to dff00000 @ 1fffd000-20000000
[    0.000000] init_memory_mapping: 0000000100000000-0000000217000000
[    0.000000]  0100000000 - 0200000000 page 1G
[    0.000000]  0200000000 - 0217000000 page 2M
[    0.000000] kernel direct mapping tables up to 217000000 @ dfefe000-dff00000
[    0.000000] ACPI: RSDP 00000000000f0450 00024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 00000000dfd60068 00054 (v01 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: FACP 00000000dfd66f08 000F4 (v04 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI Warning: Optional field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20110623/tbfadt-560)
[    0.000000] ACPI: DSDT 00000000dfd60150 06DB5 (v02 ALASKA    A M I 00000000 INTL 20051117)
[    0.000000] ACPI: FACS 00000000dfedbf80 00040
[    0.000000] ACPI: APIC 00000000dfd67000 00072 (v03 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 00000000dfd67078 0003C (v01 A M I  GMCH945. 01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 00000000dfd670b8 00038 (v01 ALASKA    A M I 01072009 AMI  00000004)
[    0.000000] ACPI: SSDT 00000000dfd670f0 00FD8 (v01 AMD    POWERNOW 00000001 AMD  00000001)
[    0.000000] ACPI: SSDT 00000000dfd680c8 00695 (v02    AMD     ALIB 00000001 MSFT 04000000)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at 0000000000000000-0000000217000000
[    0.000000] Initmem setup node 0 0000000000000000-0000000217000000
[    0.000000]   NODE_DATA [0000000216ffb000 - 0000000216ffffff]
[    0.000000]  [ffffea0000000000-ffffea00085fffff] PMD -> [ffff88020e800000-ffff8802165fffff] on node 0
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   DMA32    0x00001000 -> 0x00100000
[    0.000000]   Normal   0x00100000 -> 0x00217000
[    0.000000] Movable zone start PFN for each node
[    0.000000] early_node_map[6] active PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009d
[    0.000000]     0: 0x00000100 -> 0x000df7c9
[    0.000000]     0: 0x000dfb31 -> 0x000dfd12
[    0.000000]     0: 0x000dfd6c -> 0x000dfd6d
[    0.000000]     0: 0x000dfef4 -> 0x000dff00
[    0.000000]     0: 0x00100001 -> 0x00217000
[    0.000000] On node 0 totalpages: 2058563
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 5 pages reserved
[    0.000000]   DMA zone: 3912 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 16320 pages used for memmap
[    0.000000]   DMA32 zone: 895479 pages, LIFO batch:31
[    0.000000]   Normal zone: 17856 pages used for memmap
[    0.000000]   Normal zone: 1124927 pages, LIFO batch:31
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x05] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 5, version 33, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0xffffffff base: 0xfed00000
[    0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000
[    0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[    0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[    0.000000] PM: Registered nosave memory: 00000000df7c9000 - 00000000df92e000
[    0.000000] PM: Registered nosave memory: 00000000df92e000 - 00000000dfb31000
[    0.000000] PM: Registered nosave memory: 00000000dfd12000 - 00000000dfd60000
[    0.000000] PM: Registered nosave memory: 00000000dfd60000 - 00000000dfd69000
[    0.000000] PM: Registered nosave memory: 00000000dfd69000 - 00000000dfd6c000
[    0.000000] PM: Registered nosave memory: 00000000dfd6d000 - 00000000dfea6000
[    0.000000] PM: Registered nosave memory: 00000000dfea6000 - 00000000dfeb7000
[    0.000000] PM: Registered nosave memory: 00000000dfeb7000 - 00000000dfec8000
[    0.000000] PM: Registered nosave memory: 00000000dfec8000 - 00000000dfec9000
[    0.000000] PM: Registered nosave memory: 00000000dfec9000 - 00000000dfed9000
[    0.000000] PM: Registered nosave memory: 00000000dfed9000 - 00000000dfeda000
[    0.000000] PM: Registered nosave memory: 00000000dfeda000 - 00000000dfedb000
[    0.000000] PM: Registered nosave memory: 00000000dfedb000 - 00000000dfee1000
[    0.000000] PM: Registered nosave memory: 00000000dfee1000 - 00000000dfef4000
[    0.000000] PM: Registered nosave memory: 00000000dff00000 - 00000000e0000000
[    0.000000] PM: Registered nosave memory: 00000000e0000000 - 00000000f0000000
[    0.000000] PM: Registered nosave memory: 00000000f0000000 - 00000000fec00000
[    0.000000] PM: Registered nosave memory: 00000000fec00000 - 00000000fec01000
[    0.000000] PM: Registered nosave memory: 00000000fec01000 - 00000000fec10000
[    0.000000] PM: Registered nosave memory: 00000000fec10000 - 00000000fec11000
[    0.000000] PM: Registered nosave memory: 00000000fec11000 - 00000000fed00000
[    0.000000] PM: Registered nosave memory: 00000000fed00000 - 00000000fed01000
[    0.000000] PM: Registered nosave memory: 00000000fed01000 - 00000000fed61000
[    0.000000] PM: Registered nosave memory: 00000000fed61000 - 00000000fed71000
[    0.000000] PM: Registered nosave memory: 00000000fed71000 - 00000000fed80000
[    0.000000] PM: Registered nosave memory: 00000000fed80000 - 00000000fed90000
[    0.000000] PM: Registered nosave memory: 00000000fed90000 - 00000000ff000000
[    0.000000] PM: Registered nosave memory: 00000000ff000000 - 0000000100000000
[    0.000000] PM: Registered nosave memory: 0000000100000000 - 0000000100001000
[    0.000000] Allocating PCI resources starting at f0000000 (gap: f0000000:ec00000)
[    0.000000] setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 26 pages/cpu @ffff880216c00000 s74880 r8192 d23424 u524288
[    0.000000] pcpu-alloc: s74880 r8192 d23424 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 2024318
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: root=/dev/sda3 video=uvesafb:1280x1024-32,mttr:3,ywrap quiet
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Checking aperture...
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 8023816k/8765440k available (7125k kernel code, 531188k absent, 210436k reserved, 5773k data, 748k init)
[    0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:4352 nr_irqs:712 16
[    0.000000] Extended CMOS year: 2000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration failed
[    0.000000] TSC: PIT calibration matches HPET. 1 loops
[    0.000000] Detected 2599.937 MHz processor.
[    0.002002] Calibrating delay loop (skipped), value calculated using timer frequency.. 5199.87 BogoMIPS (lpj=2599937)
[    0.002006] pid_max: default: 32768 minimum: 301
[    0.002026] Security Framework initialized
[    0.002028] SELinux:  Initializing.
[    0.002035] SELinux:  Starting in permissive mode
[    0.003420] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[    0.005597] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.006516] Mount-cache hash table entries: 256
[    0.006628] Initializing cgroup subsys cpuacct
[    0.006632] Initializing cgroup subsys freezer
[    0.006653] tseg: 00dff00000
[    0.006655] CPU: CPU feature monitor disabled, no CPUID level 0x5
[    0.006657] CPU: Physical Processor ID: 0
[    0.006658] CPU: Processor Core ID: 0
[    0.006659] mce: CPU supports 6 MCE banks
[    0.006743] ACPI: Core revision 20110623
[    0.010307] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.020861] CPU0: AMD A6-3650 APU with Radeon(tm) HD Graphics stepping 00
[    0.020998] Performance Events: AMD PMU driver.
[    0.020998] ... version:                0
[    0.020998] ... bit width:              48
[    0.020998] ... generic registers:      4
[    0.020998] ... value mask:             0000ffffffffffff
[    0.020998] ... max period:             00007fffffffffff
[    0.020998] ... fixed-purpose events:   0
[    0.020998] ... event mask:             000000000000000f
[    0.020998] MCE: In-kernel MCE decoding enabled.
[    0.020998] Booting Node   0, Processors  #1
[    0.020998] smpboot cpu 1: start_ip = 98000
[    0.002999] CPU: CPU feature monitor disabled, no CPUID level 0x5
[    0.092042]  #2
[    0.092043] smpboot cpu 2: start_ip = 98000
[    0.164032]  #3 Ok.
[    0.164034] smpboot cpu 3: start_ip = 98000
[    0.235977] Brought up 4 CPUs
[    0.235979] Total of 4 processors activated (20798.34 BogoMIPS).
[    0.236463] PM: Registering ACPI NVS region at df92e000 (2109440 bytes)
[    0.236463] PM: Registering ACPI NVS region at dfd12000 (319488 bytes)
[    0.236463] PM: Registering ACPI NVS region at dfd69000 (12288 bytes)
[    0.236463] PM: Registering ACPI NVS region at dfea6000 (69632 bytes)
[    0.236463] PM: Registering ACPI NVS region at dfec8000 (4096 bytes)
[    0.236463] PM: Registering ACPI NVS region at dfed9000 (4096 bytes)
[    0.236463] PM: Registering ACPI NVS region at dfedb000 (24576 bytes)
[    0.236463] xor: automatically using best checksumming function: generic_sse
[    0.240974]    generic_sse:  9684.000 MB/sec
[    0.240976] xor: using function: generic_sse (9684.000 MB/sec)
[    0.240993] RTC time: 19:48:13, date: 01/30/12
[    0.241023] NET: Registered protocol family 16
[    0.241038] kworker/u:0 used greatest stack depth: 5496 bytes left
[    0.241060] Extended Config Space enabled on 0 nodes
[    0.241082] ACPI: bus type pci registered
[    0.241089] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.241089] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.276960] PCI: Using configuration type 1 for base access
[    0.285113] bio: create slab <bio-0> at 0
[    0.301896] raid6: int64x1   1628 MB/s
[    0.318878] raid6: int64x2   2558 MB/s
[    0.335861] raid6: int64x4   2230 MB/s
[    0.352882] raid6: int64x8   2097 MB/s
[    0.369859] raid6: sse2x1    4023 MB/s
[    0.386862] raid6: sse2x2    6074 MB/s
[    0.403853] raid6: sse2x4    7500 MB/s
[    0.403854] raid6: using algorithm sse2x4 (7500 MB/s)
[    0.403983] ACPI: Added _OSI(Module Device)
[    0.403983] ACPI: Added _OSI(Processor Device)
[    0.403983] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.403983] ACPI: Added _OSI(Processor Aggregator Device)
[    0.404688] ACPI: EC: Look up EC in DSDT
[    0.405568] ACPI: Executed 1 blocks of module-level executable AML code
[    0.407545] ACPI Error: [RAMB] Namespace lookup failure, AE_NOT_FOUND (20110623/psargs-359)
[    0.407551] ACPI Exception: AE_NOT_FOUND, Could not execute arguments for [RAMW] (Region) (20110623/nsinit-349)
[    0.407859] ACPI: Interpreter enabled
[    0.407862] ACPI: (supports S0 S3 S4 S5)
[    0.407877] ACPI: Using IOAPIC for interrupt routing
[    0.414998] ACPI: No dock devices found.
[    0.415002] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.415253] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.415277] pci_root PNP0A03:00: host bridge window [io  0x0000-0x03af]
[    0.415277] pci_root PNP0A03:00: host bridge window [io  0x03e0-0x0cf7]
[    0.415277] pci_root PNP0A03:00: host bridge window [io  0x03b0-0x03df]
[    0.415277] pci_root PNP0A03:00: host bridge window [io  0x1778-0xffff]
[    0.415277] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[    0.415277] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff]
[    0.415277] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xffffffff]
[    0.415277] pci 0000:00:00.0: [1022:1705] type 0 class 0x000600
[    0.415277] pci 0000:00:01.0: [1002:964a] type 0 class 0x000300
[    0.415277] pci 0000:00:01.0: reg 10: [mem 0xf0000000-0xf7ffffff pref]
[    0.415277] pci 0000:00:01.0: reg 14: [io  0xf000-0xf0ff]
[    0.415277] pci 0000:00:01.0: reg 18: [mem 0xfeb00000-0xfeb3ffff]
[    0.415277] pci 0000:00:01.0: supports D1 D2
[    0.415278] pci 0000:00:10.0: [1022:7812] type 0 class 0x000c03
[    0.415299] pci 0000:00:10.0: reg 10: [mem 0xfeb46000-0xfeb47fff 64bit]
[    0.415402] pci 0000:00:10.0: PME# supported from D0 D3hot D3cold
[    0.415407] pci 0000:00:10.0: PME# disabled
[    0.415445] pci 0000:00:10.1: [1022:7812] type 0 class 0x000c03
[    0.415465] pci 0000:00:10.1: reg 10: [mem 0xfeb44000-0xfeb45fff 64bit]
[    0.415567] pci 0000:00:10.1: PME# supported from D0 D3hot D3cold
[    0.415571] pci 0000:00:10.1: PME# disabled
[    0.415963] pci 0000:00:11.0: [1022:7801] type 0 class 0x000106
[    0.415982] pci 0000:00:11.0: reg 10: [io  0xf140-0xf147]
[    0.415991] pci 0000:00:11.0: reg 14: [io  0xf130-0xf133]
[    0.416000] pci 0000:00:11.0: reg 18: [io  0xf120-0xf127]
[    0.416010] pci 0000:00:11.0: reg 1c: [io  0xf110-0xf113]
[    0.416019] pci 0000:00:11.0: reg 20: [io  0xf100-0xf10f]
[    0.416028] pci 0000:00:11.0: reg 24: [mem 0xfeb4d000-0xfeb4d7ff]
[    0.416088] pci 0000:00:12.0: [1022:7807] type 0 class 0x000c03
[    0.416101] pci 0000:00:12.0: reg 10: [mem 0xfeb4c000-0xfeb4cfff]
[    0.416171] pci 0000:00:12.2: [1022:7808] type 0 class 0x000c03
[    0.416189] pci 0000:00:12.2: reg 10: [mem 0xfeb4b000-0xfeb4b0ff]
[    0.416268] pci 0000:00:12.2: supports D1 D2
[    0.416270] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[    0.416274] pci 0000:00:12.2: PME# disabled
[    0.416294] pci 0000:00:13.0: [1022:7807] type 0 class 0x000c03
[    0.416307] pci 0000:00:13.0: reg 10: [mem 0xfeb4a000-0xfeb4afff]
[    0.416376] pci 0000:00:13.2: [1022:7808] type 0 class 0x000c03
[    0.416395] pci 0000:00:13.2: reg 10: [mem 0xfeb49000-0xfeb490ff]
[    0.416474] pci 0000:00:13.2: supports D1 D2
[    0.416476] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[    0.416479] pci 0000:00:13.2: PME# disabled
[    0.416499] pci 0000:00:14.0: [1022:780b] type 0 class 0x000c05
[    0.416574] pci 0000:00:14.2: [1022:780d] type 0 class 0x000403
[    0.416594] pci 0000:00:14.2: reg 10: [mem 0xfeb40000-0xfeb43fff 64bit]
[    0.416658] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
[    0.416662] pci 0000:00:14.2: PME# disabled
[    0.416675] pci 0000:00:14.3: [1022:780e] type 0 class 0x000601
[    0.416749] pci 0000:00:14.4: [1022:780f] type 1 class 0x000604
[    0.416790] pci 0000:00:14.5: [1022:7809] type 0 class 0x000c03
[    0.416803] pci 0000:00:14.5: reg 10: [mem 0xfeb48000-0xfeb48fff]
[    0.416873] pci 0000:00:15.0: [1022:43a0] type 1 class 0x000604
[    0.416951] pci 0000:00:15.0: supports D1 D2
[    0.416977] pci 0000:00:15.1: [1022:43a1] type 1 class 0x000604
[    0.417050] pci 0000:00:15.1: supports D1 D2
[    0.417079] pci 0000:00:18.0: [1022:1700] type 0 class 0x000600
[    0.417111] pci 0000:00:18.1: [1022:1701] type 0 class 0x000600
[    0.417140] pci 0000:00:18.2: [1022:1702] type 0 class 0x000600
[    0.417171] pci 0000:00:18.3: [1022:1703] type 0 class 0x000600
[    0.417210] pci 0000:00:18.4: [1022:1704] type 0 class 0x000600
[    0.417240] pci 0000:00:18.5: [1022:1718] type 0 class 0x000600
[    0.417269] pci 0000:00:18.6: [1022:1716] type 0 class 0x000600
[    0.417298] pci 0000:00:18.7: [1022:1719] type 0 class 0x000600
[    0.417362] pci 0000:01:05.0: [1095:3114] type 0 class 0x000104
[    0.417382] pci 0000:01:05.0: reg 10: [io  0xe040-0xe047]
[    0.417394] pci 0000:01:05.0: reg 14: [io  0xe030-0xe033]
[    0.417405] pci 0000:01:05.0: reg 18: [io  0xe020-0xe027]
[    0.417417] pci 0000:01:05.0: reg 1c: [io  0xe010-0xe013]
[    0.417429] pci 0000:01:05.0: reg 20: [io  0xe000-0xe00f]
[    0.417440] pci 0000:01:05.0: reg 24: [mem 0xfea80000-0xfea803ff]
[    0.417452] pci 0000:01:05.0: reg 30: [mem 0xfea00000-0xfea7ffff pref]
[    0.417485] pci 0000:01:05.0: supports D1 D2
[    0.417531] pci 0000:00:14.4: PCI bridge to [bus 01-01] (subtractive decode)
[    0.417535] pci 0000:00:14.4:   bridge window [io  0xe000-0xefff]
[    0.417539] pci 0000:00:14.4:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.417543] pci 0000:00:14.4:   bridge window [io  0x0000-0x03af] (subtractive decode)
[    0.417545] pci 0000:00:14.4:   bridge window [io  0x03e0-0x0cf7] (subtractive decode)
[    0.417547] pci 0000:00:14.4:   bridge window [io  0x03b0-0x03df] (subtractive decode)
[    0.417549] pci 0000:00:14.4:   bridge window [io  0x1778-0xffff] (subtractive decode)
[    0.417551] pci 0000:00:14.4:   bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[    0.417553] pci 0000:00:14.4:   bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
[    0.417555] pci 0000:00:14.4:   bridge window [mem 0xf0000000-0xffffffff] (subtractive decode)
[    0.417620] pci 0000:02:00.0: [14f1:8852] type 0 class 0x000400
[    0.417649] pci 0000:02:00.0: reg 10: [mem 0xfe800000-0xfe9fffff 64bit]
[    0.417803] pci 0000:02:00.0: supports D1 D2
[    0.417804] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot
[    0.417810] pci 0000:02:00.0: PME# disabled
[    0.417834] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device.  You can enable it with 'pcie_aspm=force'
[    0.417845] pci 0000:00:15.0: PCI bridge to [bus 02-02]
[    0.417853] pci 0000:00:15.0:   bridge window [mem 0xfe800000-0xfe9fffff]
[    0.417925] pci 0000:03:00.0: [10ec:8168] type 0 class 0x000200
[    0.417947] pci 0000:03:00.0: reg 10: [io  0xd000-0xd0ff]
[    0.417977] pci 0000:03:00.0: reg 18: [mem 0xf8004000-0xf8004fff 64bit pref]
[    0.417997] pci 0000:03:00.0: reg 20: [mem 0xf8000000-0xf8003fff 64bit pref]
[    0.418077] pci 0000:03:00.0: supports D1 D2
[    0.418079] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.418084] pci 0000:03:00.0: PME# disabled
[    0.419969] pci 0000:00:15.1: PCI bridge to [bus 03-03]
[    0.419980] pci 0000:00:15.1:   bridge window [io  0xd000-0xdfff]
[    0.419994] pci 0000:00:15.1:   bridge window [mem 0xf8000000-0xf80fffff 64bit pref]
[    0.420023] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.420273] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE20._PRT]
[    0.420295] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PE21._PRT]
[    0.420327] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0PC._PRT]
[    0.420442]  pci0000:00: Requesting ACPI _OSC control (0x1d)
[    0.420584]  pci0000:00: ACPI _OSC control (0x1d) granted
[    0.424999] ACPI: PCI Interrupt Link [LN24] (IRQs *24)
[    0.425025] ACPI: PCI Interrupt Link [LN25] (IRQs *25)
[    0.425046] ACPI: PCI Interrupt Link [LN26] (IRQs *26)
[    0.425070] ACPI: PCI Interrupt Link [LN27] (IRQs *27)
[    0.425092] ACPI: PCI Interrupt Link [LN28] (IRQs *28)
[    0.425113] ACPI: PCI Interrupt Link [LN29] (IRQs *29)
[    0.425135] ACPI: PCI Interrupt Link [LN30] (IRQs *30)
[    0.425157] ACPI: PCI Interrupt Link [LN31] (IRQs *31)
[    0.425179] ACPI: PCI Interrupt Link [LN32] (IRQs *32)
[    0.425201] ACPI: PCI Interrupt Link [LN33] (IRQs *33)
[    0.425223] ACPI: PCI Interrupt Link [LN34] (IRQs *34)
[    0.425245] ACPI: PCI Interrupt Link [LN35] (IRQs *35)
[    0.425266] ACPI: PCI Interrupt Link [LN36] (IRQs *36)
[    0.425287] ACPI: PCI Interrupt Link [LN37] (IRQs *37)
[    0.425309] ACPI: PCI Interrupt Link [LN38] (IRQs *38)
[    0.425331] ACPI: PCI Interrupt Link [LN39] (IRQs *39)
[    0.425353] ACPI: PCI Interrupt Link [LN40] (IRQs *40)
[    0.425375] ACPI: PCI Interrupt Link [LN41] (IRQs *41)
[    0.425397] ACPI: PCI Interrupt Link [LN42] (IRQs *42)
[    0.425418] ACPI: PCI Interrupt Link [LN43] (IRQs *43)
[    0.425440] ACPI: PCI Interrupt Link [LN44] (IRQs *44)
[    0.425461] ACPI: PCI Interrupt Link [LN45] (IRQs *45)
[    0.425486] ACPI: PCI Interrupt Link [LN46] (IRQs *46)
[    0.425508] ACPI: PCI Interrupt Link [LN47] (IRQs *47)
[    0.425530] ACPI: PCI Interrupt Link [LN48] (IRQs *48)
[    0.425551] ACPI: PCI Interrupt Link [LN49] (IRQs *49)
[    0.425573] ACPI: PCI Interrupt Link [LN50] (IRQs *50)
[    0.425594] ACPI: PCI Interrupt Link [LN51] (IRQs *51)
[    0.425617] ACPI: PCI Interrupt Link [LN52] (IRQs *52)
[    0.425955] ACPI: PCI Interrupt Link [LN53] (IRQs *53)
[    0.425978] ACPI: PCI Interrupt Link [LN54] (IRQs *54)
[    0.426000] ACPI: PCI Interrupt Link [LN55] (IRQs *55)
[    0.426027] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 10 11 14 15) *0
[    0.426074] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 5 10 11 14 15) *0
[    0.426122] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 5 10 11 14 15) *0
[    0.426170] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 10 11 14 15) *0
[    0.426206] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 10 11 14 15) *0
[    0.426233] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 10 11 14 15) *0
[    0.426262] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 10 11 14 15) *0
[    0.426290] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 10 11 14 15) *0
[    0.426308] vgaarb: device added: PCI:0000:00:01.0,decodes=io+mem,owns=io+mem,locks=none
[    0.426308] vgaarb: loaded
[    0.426308] vgaarb: bridge control possible 0000:00:01.0
[    0.426975] SCSI subsystem initialized
[    0.426992] libata version 3.00 loaded.
[    0.426992] usbcore: registered new interface driver usbfs
[    0.426992] usbcore: registered new interface driver hub
[    0.426992] usbcore: registered new device driver usb
[    0.426992] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.426992] PCI: Using ACPI for IRQ routing
[    0.436083] PCI: pci_cache_line_size set to 64 bytes
[    0.436172] reserve RAM buffer: 000000000009d800 - 000000000009ffff
[    0.436174] reserve RAM buffer: 00000000df7c9000 - 00000000dfffffff
[    0.436177] reserve RAM buffer: 00000000dfd12000 - 00000000dfffffff
[    0.436180] reserve RAM buffer: 00000000dfd6d000 - 00000000dfffffff
[    0.436183] reserve RAM buffer: 00000000dff00000 - 00000000dfffffff
[    0.436185] reserve RAM buffer: 0000000217000000 - 0000000217ffffff
[    0.436198] cfg80211: Calling CRDA to update world regulatory domain
[    0.436198] NetLabel: Initializing
[    0.436198] NetLabel:  domain hash size = 128
[    0.436198] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.436198] NetLabel:  unlabeled traffic allowed by default
[    0.436198] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.436198] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.438960] Switching to clocksource hpet
[    0.438980] Switched to NOHz mode on CPU #1
[    0.439003] Switched to NOHz mode on CPU #2
[    0.439039] Switched to NOHz mode on CPU #3
[    0.439907] Switched to NOHz mode on CPU #0
[    0.440668] FS-Cache: Loaded
[    0.440833] CacheFiles: Loaded
[    0.445371] pnp: PnP ACPI init
[    0.445378] ACPI: bus type pnp registered
[    0.445511] pnp 00:00: [bus 00-ff]
[    0.445513] pnp 00:00: [io  0x0cf8-0x0cff]
[    0.445515] pnp 00:00: [io  0x0000-0x03af window]
[    0.445517] pnp 00:00: [io  0x03e0-0x0cf7 window]
[    0.445519] pnp 00:00: [io  0x03b0-0x03df window]
[    0.445520] pnp 00:00: [io  0x1778-0xffff window]
[    0.445522] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    0.445524] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[    0.445526] pnp 00:00: [mem 0xf0000000-0xffffffff window]
[    0.445528] pnp 00:00: [mem 0x00000000 window]
[    0.445611] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[    0.445637] pnp 00:01: [mem 0xe0000000-0xefffffff]
[    0.445711] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved
[    0.445714] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.445976] pnp 00:02: [io  0x0010-0x001f]
[    0.445978] pnp 00:02: [io  0x0022-0x003f]
[    0.445980] pnp 00:02: [io  0x0063]
[    0.445981] pnp 00:02: [io  0x0065]
[    0.445983] pnp 00:02: [io  0x0067-0x006f]
[    0.445985] pnp 00:02: [io  0x0072-0x007f]
[    0.445987] pnp 00:02: [io  0x0080]
[    0.445988] pnp 00:02: [io  0x0084-0x0086]
[    0.445990] pnp 00:02: [io  0x0088]
[    0.445991] pnp 00:02: [io  0x008c-0x008e]
[    0.445992] pnp 00:02: [io  0x0090-0x009f]
[    0.445994] pnp 00:02: [io  0x00a2-0x00bf]
[    0.445995] pnp 00:02: [io  0x00b1]
[    0.445997] pnp 00:02: [io  0x00e0-0x00ef]
[    0.445998] pnp 00:02: [io  0x04d0-0x04d1]
[    0.446014] pnp 00:02: [io  0x040b]
[    0.446016] pnp 00:02: [io  0x04d6]
[    0.446017] pnp 00:02: [io  0x0c00-0x0c01]
[    0.446018] pnp 00:02: [io  0x0c14]
[    0.446020] pnp 00:02: [io  0x0c50-0x0c51]
[    0.446021] pnp 00:02: [io  0x0c52]
[    0.446022] pnp 00:02: [io  0x0c6c]
[    0.446024] pnp 00:02: [io  0x0c6f]
[    0.446025] pnp 00:02: [io  0x0cd0-0x0cd1]
[    0.446027] pnp 00:02: [io  0x0cd2-0x0cd3]
[    0.446028] pnp 00:02: [io  0x0cd4-0x0cd5]
[    0.446029] pnp 00:02: [io  0x0cd6-0x0cd7]
[    0.446031] pnp 00:02: [io  0x0cd8-0x0cdf]
[    0.446032] pnp 00:02: [io  0x0800-0x089f]
[    0.446034] pnp 00:02: [io  0x0000-0xffffffffffffffff disabled]
[    0.446036] pnp 00:02: [io  0x0000-0x000f]
[    0.446037] pnp 00:02: [io  0x0b20-0x0b3f]
[    0.446039] pnp 00:02: [io  0x0900-0x090f]
[    0.446040] pnp 00:02: [io  0x0910-0x091f]
[    0.446041] pnp 00:02: [io  0xfe00-0xfefe]
[    0.446043] pnp 00:02: [io  0x0060-0x005f disabled]
[    0.446045] pnp 00:02: [io  0x0064-0x0063 disabled]
[    0.446046] pnp 00:02: [mem 0xfec00000-0xfec00fff]
[    0.446048] pnp 00:02: [mem 0xfee00000-0xfee00fff]
[    0.446050] pnp 00:02: [mem 0xfed80000-0xfed8ffff]
[    0.446051] pnp 00:02: [mem 0xfed61000-0xfed70fff]
[    0.446053] pnp 00:02: [mem 0xfec10000-0xfec10fff]
[    0.446054] pnp 00:02: [mem 0xfed00000-0xfed00fff]
[    0.446056] pnp 00:02: [mem 0xff000000-0xffffffff]
[    0.446163] system 00:02: [io  0x04d0-0x04d1] has been reserved
[    0.446165] system 00:02: [io  0x040b] has been reserved
[    0.446167] system 00:02: [io  0x04d6] has been reserved
[    0.446169] system 00:02: [io  0x0c00-0x0c01] has been reserved
[    0.446173] system 00:02: [io  0x0c14] has been reserved
[    0.446175] system 00:02: [io  0x0c50-0x0c51] has been reserved
[    0.446177] system 00:02: [io  0x0c52] has been reserved
[    0.446179] system 00:02: [io  0x0c6c] has been reserved
[    0.446181] system 00:02: [io  0x0c6f] has been reserved
[    0.446183] system 00:02: [io  0x0cd0-0x0cd1] has been reserved
[    0.446185] system 00:02: [io  0x0cd2-0x0cd3] has been reserved
[    0.446187] system 00:02: [io  0x0cd4-0x0cd5] has been reserved
[    0.446189] system 00:02: [io  0x0cd6-0x0cd7] has been reserved
[    0.446191] system 00:02: [io  0x0cd8-0x0cdf] has been reserved
[    0.446193] system 00:02: [io  0x0800-0x089f] has been reserved
[    0.446195] system 00:02: [io  0x0b20-0x0b3f] has been reserved
[    0.446197] system 00:02: [io  0x0900-0x090f] has been reserved
[    0.446199] system 00:02: [io  0x0910-0x091f] has been reserved
[    0.446201] system 00:02: [io  0xfe00-0xfefe] has been reserved
[    0.446205] system 00:02: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.446207] system 00:02: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.446209] system 00:02: [mem 0xfed80000-0xfed8ffff] has been reserved
[    0.446212] system 00:02: [mem 0xfed61000-0xfed70fff] has been reserved
[    0.446214] system 00:02: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.446216] system 00:02: [mem 0xfed00000-0xfed00fff] has been reserved
[    0.446219] system 00:02: [mem 0xff000000-0xffffffff] has been reserved
[    0.446221] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.446303] pnp 00:03: [io  0x0000-0xffffffffffffffff disabled]
[    0.446305] pnp 00:03: [io  0x0300-0x031f]
[    0.446308] pnp 00:03: [io  0x0290-0x029f]
[    0.446309] pnp 00:03: [io  0x0000-0xffffffffffffffff disabled]
[    0.446375] system 00:03: [io  0x0300-0x031f] has been reserved
[    0.446377] system 00:03: [io  0x0290-0x029f] has been reserved
[    0.446379] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.446486] pnp 00:04: [dma 4]
[    0.446488] pnp 00:04: [io  0x0000-0x000f]
[    0.446489] pnp 00:04: [io  0x0081-0x0083]
[    0.446491] pnp 00:04: [io  0x0087]
[    0.446492] pnp 00:04: [io  0x0089-0x008b]
[    0.446494] pnp 00:04: [io  0x008f]
[    0.446495] pnp 00:04: [io  0x00c0-0x00df]
[    0.446546] pnp 00:04: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.446553] pnp 00:05: [io  0x0070-0x0071]
[    0.446562] pnp 00:05: [irq 8]
[    0.446612] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.446618] pnp 00:06: [io  0x0061]
[    0.446669] pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
[    0.446687] pnp 00:07: [io  0x0010-0x001f]
[    0.446688] pnp 00:07: [io  0x0022-0x003f]
[    0.446690] pnp 00:07: [io  0x0044-0x005f]
[    0.446691] pnp 00:07: [io  0x0072-0x007f]
[    0.446693] pnp 00:07: [io  0x0080]
[    0.446694] pnp 00:07: [io  0x0084-0x0086]
[    0.446695] pnp 00:07: [io  0x0088]
[    0.446697] pnp 00:07: [io  0x008c-0x008e]
[    0.446698] pnp 00:07: [io  0x0090-0x009f]
[    0.446700] pnp 00:07: [io  0x00a2-0x00bf]
[    0.446701] pnp 00:07: [io  0x00e0-0x00ef]
[    0.446702] pnp 00:07: [io  0x04d0-0x04d1]
[    0.446776] system 00:07: [io  0x04d0-0x04d1] has been reserved
[    0.446778] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.446785] pnp 00:08: [io  0x00f0-0x00ff]
[    0.446788] pnp 00:08: [irq 13]
[    0.446840] pnp 00:08: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.446868] pnp 00:09: [io  0x1770-0x1777]
[    0.446933] system 00:09: [io  0x1770-0x1777] has been reserved
[    0.446935] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.447122] pnp 00:0a: [io  0x03f8-0x03ff]
[    0.447126] pnp 00:0a: [irq 4]
[    0.447128] pnp 00:0a: [dma 0 disabled]
[    0.447227] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.447490] pnp 00:0b: [mem 0xfed00000-0xfed003ff]
[    0.447570] pnp 00:0b: Plug and Play ACPI device, IDs PNP0103 (active)
[    0.447575] pnp: PnP ACPI: found 12 devices
[    0.447576] ACPI: ACPI bus type pnp unregistered
[    0.451970] PCI: max bus depth: 1 pci_try_num: 2
[    0.451994] pci 0000:00:14.4: PCI bridge to [bus 01-01]
[    0.451997] pci 0000:00:14.4:   bridge window [io  0xe000-0xefff]
[    0.452013] pci 0000:00:14.4:   bridge window [mem 0xfea00000-0xfeafffff]
[    0.452023] pci 0000:00:15.0: PCI bridge to [bus 02-02]
[    0.452027] pci 0000:00:15.0:   bridge window [mem 0xfe800000-0xfe9fffff]
[    0.452034] pci 0000:00:15.1: PCI bridge to [bus 03-03]
[    0.452036] pci 0000:00:15.1:   bridge window [io  0xd000-0xdfff]
[    0.452043] pci 0000:00:15.1:   bridge window [mem 0xf8000000-0xf80fffff 64bit pref]
[    0.452068] pci 0000:00:15.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.452072] pci 0000:00:15.0: setting latency timer to 64
[    0.452077] pci 0000:00:15.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    0.452081] pci 0000:00:15.1: setting latency timer to 64
[    0.452084] pci_bus 0000:00: resource 4 [io  0x0000-0x03af]
[    0.452086] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7]
[    0.452087] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df]
[    0.452089] pci_bus 0000:00: resource 7 [io  0x1778-0xffff]
[    0.452091] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff]
[    0.452093] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff]
[    0.452094] pci_bus 0000:00: resource 10 [mem 0xf0000000-0xffffffff]
[    0.452096] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.452098] pci_bus 0000:01: resource 1 [mem 0xfea00000-0xfeafffff]
[    0.452100] pci_bus 0000:01: resource 4 [io  0x0000-0x03af]
[    0.452101] pci_bus 0000:01: resource 5 [io  0x03e0-0x0cf7]
[    0.452103] pci_bus 0000:01: resource 6 [io  0x03b0-0x03df]
[    0.452105] pci_bus 0000:01: resource 7 [io  0x1778-0xffff]
[    0.452106] pci_bus 0000:01: resource 8 [mem 0x000a0000-0x000bffff]
[    0.452108] pci_bus 0000:01: resource 9 [mem 0x000c0000-0x000dffff]
[    0.452110] pci_bus 0000:01: resource 10 [mem 0xf0000000-0xffffffff]
[    0.452112] pci_bus 0000:02: resource 1 [mem 0xfe800000-0xfe9fffff]
[    0.452114] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[    0.452116] pci_bus 0000:03: resource 2 [mem 0xf8000000-0xf80fffff 64bit pref]
[    0.452148] NET: Registered protocol family 2
[    0.452356] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.453573] TCP established hash table entries: 524288 (order: 11, 8388608 bytes)
[    0.455861] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.456162] TCP: Hash tables configured (established 524288 bind 65536)
[    0.456164] TCP reno registered
[    0.456181] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[    0.456239] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[    0.456351] NET: Registered protocol family 1
[    0.456451] RPC: Registered named UNIX socket transport module.
[    0.456453] RPC: Registered udp transport module.
[    0.456454] RPC: Registered tcp transport module.
[    0.456455] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.456469] pci 0000:00:01.0: Boot video device
[    1.198402] PCI: CLS 64 bytes, default 64
[    1.198616] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.198619] Placing 64MB software IO TLB between ffff8800db7c9000 - ffff8800df7c9000
[    1.198621] software IO TLB at phys 0xdb7c9000 - 0xdf7c9000
[    1.201093] microcode: CPU0: patch_level=0x03000027
[    1.201144] microcode: CPU1: patch_level=0x03000027
[    1.201160] microcode: CPU2: patch_level=0x03000027
[    1.201171] microcode: CPU3: patch_level=0x03000027
[    1.201222] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.201499] audit: initializing netlink socket (disabled)
[    1.201510] type=2000 audit(1327952893.200:1): initialized
[    1.232767] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.237426] VFS: Disk quotas dquot_6.5.2
[    1.237506] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.238560] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.239018] NTFS driver 2.1.30 [Flags: R/W].
[    1.239408] fuse init (API version 7.17)
[    1.239628] msgmni has been set to 15671
[    1.239730] SELinux:  Registering netfilter hooks
[    1.240696] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    1.240699] io scheduler noop registered
[    1.240701] io scheduler deadline registered
[    1.240767] io scheduler cfq registered (default)
[    1.240868] pcieport 0000:00:15.0: setting latency timer to 64
[    1.240920] pcieport 0000:00:15.0: irq 40 for MSI/MSI-X
[    1.241027] pcieport 0000:00:15.1: setting latency timer to 64
[    1.241072] pcieport 0000:00:15.1: irq 41 for MSI/MSI-X
[    1.241272] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.241343] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.505243] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.583000] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    1.600952] Non-volatile memory driver v1.3
[    1.600954] Linux agpgart interface v0.103
[    1.601132] uvesafb: unrecognized option mttr:3
[    1.601583] v86d used greatest stack depth: 5432 bytes left
[    1.601850] uvesafb: (C) 1988-2010, AMD Technologies Inc. , SUMO, 01.00, OEM: AMD ATOMBIOS, VBE v3.0
[    1.624539] uvesafb: VBIOS/hardware supports DDC2 transfers
[    1.820023] uvesafb: monitor limits: vf = 75 Hz, hf = 84 kHz, clk = 140 MHz
[    1.820111] uvesafb: scrolling: redraw
[    1.825820] uvesafb: mode switch failed (eax=0x34f, err=0). Trying again with default timings.
[    2.200016] Refined TSC clocksource calibration: 2599.879 MHz.
[    2.200021] Switching to clocksource tsc
[    2.548148] uvesafb: mode switch failed (eax=0x34f, err=0). Trying again with default timings.
[    3.277081] uvesafb: mode switch failed (eax=0x34f, err=0). Trying again with default timings.
[    3.992786] Console: switching to colour frame buffer device 160x64
[    3.992930] uvesafb: mode switch failed (eax=0x34f, err=0). Trying again with default timings.
[    4.731548] uvesafb: framebuffer at 0xf0000000, mapped to 0xffffc90011800000, using 16384k, total 16384k
[    4.731551] fb0: VESA VGA frame buffer device
[    4.732539] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
[    4.732544] ACPI: Power Button [PWRB]
[    4.732598] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    4.732601] ACPI: Power Button [PWRF]
[    4.732670] ACPI: acpi_idle registered with cpuidle
[    4.806816] brd: module loaded
[    4.807694] loop: module loaded
[    4.807911] ahci 0000:00:11.0: version 3.0
[    4.807928] ahci 0000:00:11.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    4.807994] ahci 0000:00:11.0: irq 42 for MSI/MSI-X
[    4.808082] ahci 0000:00:11.0: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[    4.808086] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio
[    4.809093] scsi0 : ahci
[    4.809317] scsi1 : ahci
[    4.809509] scsi2 : ahci
[    4.809705] scsi3 : ahci
[    4.809817] scsi4 : ahci
[    4.809905] scsi5 : ahci
[    4.810206] ata1: SATA max UDMA/133 abar m2048@0xfeb4d000 port 0xfeb4d100 irq 42
[    4.810209] ata2: SATA max UDMA/133 abar m2048@0xfeb4d000 port 0xfeb4d180 irq 42
[    4.810212] ata3: SATA max UDMA/133 abar m2048@0xfeb4d000 port 0xfeb4d200 irq 42
[    4.810215] ata4: SATA max UDMA/133 abar m2048@0xfeb4d000 port 0xfeb4d280 irq 42
[    4.810218] ata5: SATA max UDMA/133 abar m2048@0xfeb4d000 port 0xfeb4d300 irq 42
[    4.810221] ata6: SATA max UDMA/133 abar m2048@0xfeb4d000 port 0xfeb4d380 irq 42
[    4.810498] sata_sil 0000:01:05.0: version 2.4
[    4.810539] sata_sil 0000:01:05.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[    4.810568] sata_sil 0000:01:05.0: Applying R_ERR on DMA activate FIS errata fix
[    4.811310] scsi6 : sata_sil
[    4.811400] scsi7 : sata_sil
[    4.811485] scsi8 : sata_sil
[    4.811567] scsi9 : sata_sil
[    4.811638] ata7: SATA max UDMA/100 mmio m1024@0xfea80000 tf 0xfea80080 irq 20
[    4.811642] ata8: SATA max UDMA/100 mmio m1024@0xfea80000 tf 0xfea800c0 irq 20
[    4.811645] ata9: SATA max UDMA/100 mmio m1024@0xfea80000 tf 0xfea80280 irq 20
[    4.811648] ata10: SATA max UDMA/100 mmio m1024@0xfea80000 tf 0xfea802c0 irq 20
[    4.811843] tun: Universal TUN/TAP device driver, 1.6
[    4.811844] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.811896] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    4.811923] r8169 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[    4.811961] r8169 0000:03:00.0: setting latency timer to 64
[    4.812038] r8169 0000:03:00.0: irq 43 for MSI/MSI-X
[    4.812280] r8169 0000:03:00.0: eth0: RTL8168evl/8111evl at 0xffffc90000c78000, 14:da:e9:71:a0:a2, XID 0c900800 IRQ 43
[    4.812444] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.812447] ehci_hcd: block sizes: qh 112 qtd 96 itd 192 sitd 96
[    4.812460] ehci_hcd 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    4.812469] ehci_hcd 0000:00:12.2: EHCI Host Controller
[    4.812485] drivers/usb/core/inode.c: creating file 'devices'
[    4.812491] drivers/usb/core/inode.c: creating file '001'
[    4.812533] ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
[    4.812540] ehci_hcd 0000:00:12.2: reset hcs_params 0x101505 dbg=1 cc=1 pcc=5 ordered !ppc ports=5
[    4.812544] ehci_hcd 0000:00:12.2: reset hcc_params a076 thresh 7 uframes 256/512/1024 park
[    4.812548] ehci_hcd 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    4.812558] ehci_hcd 0000:00:12.2: park 0
[    4.812567] QUIRK: Enable AMD PLL fix
[    4.812577] ehci_hcd 0000:00:12.2: debug port 1
[    4.812581] ehci_hcd 0000:00:12.2: reset command 0080b02  park=3 ithresh=8 period=1024 Reset HALT
[    4.812588] ehci_hcd 0000:00:12.2: MWI active
[    4.812590] ehci_hcd 0000:00:12.2: supports USB remote wakeup
[    4.812603] ehci_hcd 0000:00:12.2: irq 17, io mem 0xfeb4b000
[    4.812606] ehci_hcd 0000:00:12.2: reset command 0080b02  park=3 ithresh=8 period=1024 Reset HALT
[    4.812612] ehci_hcd 0000:00:12.2: init command 0010005 (park)=0 ithresh=1 period=512 RUN
[    4.818014] ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
[    4.818070] usb usb1: default language 0x0409
[    4.818084] usb usb1: udev 1, busnum 1, minor = 0
[    4.818089] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.818095] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.818101] usb usb1: Product: EHCI Host Controller
[    4.818106] usb usb1: Manufacturer: Linux 3.1.10-gentoo-r1 ehci_hcd
[    4.818112] usb usb1: SerialNumber: 0000:00:12.2
[    4.818299] usb usb1: usb_probe_device
[    4.818301] usb usb1: configuration #1 chosen from 1 choice
[    4.818307] usb usb1: adding 1-0:1.0 (config #1, interface 0)
[    4.818469] hub 1-0:1.0: usb_probe_interface
[    4.818471] hub 1-0:1.0: usb_probe_interface - got id
[    4.818473] hub 1-0:1.0: USB hub found
[    4.818476] hub 1-0:1.0: 5 ports detected
[    4.818478] hub 1-0:1.0: standalone hub
[    4.818479] hub 1-0:1.0: no power switching (usb 1.0)
[    4.818481] hub 1-0:1.0: individual port over-current protection
[    4.818483] hub 1-0:1.0: power on to power good time: 20ms
[    4.818486] hub 1-0:1.0: local power source is good
[    4.818487] hub 1-0:1.0: trying to enable port power on non-switchable hub
[    4.818507] drivers/usb/core/inode.c: creating file '001'
[    4.818534] ehci_hcd 0000:00:13.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[    4.818544] ehci_hcd 0000:00:13.2: EHCI Host Controller
[    4.818548] drivers/usb/core/inode.c: creating file '002'
[    4.818697] ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 2
[    4.818703] ehci_hcd 0000:00:13.2: reset hcs_params 0x101505 dbg=1 cc=1 pcc=5 ordered !ppc ports=5
[    4.818706] ehci_hcd 0000:00:13.2: reset hcc_params a076 thresh 7 uframes 256/512/1024 park
[    4.818709] ehci_hcd 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
[    4.818717] ehci_hcd 0000:00:13.2: park 0
[    4.818726] ehci_hcd 0000:00:13.2: debug port 1
[    4.818730] ehci_hcd 0000:00:13.2: reset command 0080b02  park=3 ithresh=8 period=1024 Reset HALT
[    4.818737] ehci_hcd 0000:00:13.2: MWI active
[    4.818738] ehci_hcd 0000:00:13.2: supports USB remote wakeup
[    4.818742] ehci_hcd 0000:00:13.2: irq 17, io mem 0xfeb49000
[    4.818746] ehci_hcd 0000:00:13.2: reset command 0080b02  park=3 ithresh=8 period=1024 Reset HALT
[    4.818752] ehci_hcd 0000:00:13.2: init command 0010005 (park)=0 ithresh=1 period=512 RUN
[    4.824015] ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
[    4.824047] usb usb2: default language 0x0409
[    4.824061] usb usb2: udev 1, busnum 2, minor = 128
[    4.824067] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.824073] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.824079] usb usb2: Product: EHCI Host Controller
[    4.824083] usb usb2: Manufacturer: Linux 3.1.10-gentoo-r1 ehci_hcd
[    4.824089] usb usb2: SerialNumber: 0000:00:13.2
[    4.824282] usb usb2: usb_probe_device
[    4.824284] usb usb2: configuration #1 chosen from 1 choice
[    4.824288] usb usb2: adding 2-0:1.0 (config #1, interface 0)
[    4.824434] hub 2-0:1.0: usb_probe_interface
[    4.824435] hub 2-0:1.0: usb_probe_interface - got id
[    4.824437] hub 2-0:1.0: USB hub found
[    4.824439] hub 2-0:1.0: 5 ports detected
[    4.824441] hub 2-0:1.0: standalone hub
[    4.824442] hub 2-0:1.0: no power switching (usb 1.0)
[    4.824443] hub 2-0:1.0: individual port over-current protection
[    4.824445] hub 2-0:1.0: power on to power good time: 20ms
[    4.824447] hub 2-0:1.0: local power source is good
[    4.824449] hub 2-0:1.0: trying to enable port power on non-switchable hub
[    4.824467] drivers/usb/core/inode.c: creating file '001'
[    4.824625] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.824627] ohci_hcd: block sizes: ed 80 td 96
[    4.824643] ohci_hcd 0000:00:12.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    4.824652] ohci_hcd 0000:00:12.0: OHCI Host Controller
[    4.824655] drivers/usb/core/inode.c: creating file '003'
[    4.824717] ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 3
[    4.824730] ohci_hcd 0000:00:12.0: created debug files
[    4.824732] ohci_hcd 0000:00:12.0: supports USB remote wakeup
[    4.824741] ohci_hcd 0000:00:12.0: irq 18, io mem 0xfeb4c000
[    4.879040] ohci_hcd 0000:00:12.0: OHCI controller state
[    4.879043] ohci_hcd 0000:00:12.0: OHCI 1.0, NO legacy support registers
[    4.879046] ohci_hcd 0000:00:12.0: control 0x283 RWC HCFS=operational CBSR=3
[    4.879049] ohci_hcd 0000:00:12.0: cmdstatus 0x00000 SOC=0
[    4.879053] ohci_hcd 0000:00:12.0: intrstatus 0x00000004 SF
[    4.879056] ohci_hcd 0000:00:12.0: intrenable 0x8000005a MIE RHSC UE RD WDH
[    4.879064] ohci_hcd 0000:00:12.0: hcca frame #0005
[    4.879068] ohci_hcd 0000:00:12.0: roothub.a 02001205 POTPGT=2 NOCP NPS NDP=5(5)
[    4.879071] ohci_hcd 0000:00:12.0: roothub.b 00000000 PPCM=0000 DR=0000
[    4.879074] ohci_hcd 0000:00:12.0: roothub.status 00008000 DRWE
[    4.879078] ohci_hcd 0000:00:12.0: roothub.portstatus [0] 0x00000100 PPS
[    4.879081] ohci_hcd 0000:00:12.0: roothub.portstatus [1] 0x00000100 PPS
[    4.879084] ohci_hcd 0000:00:12.0: roothub.portstatus [2] 0x00000100 PPS
[    4.879088] ohci_hcd 0000:00:12.0: roothub.portstatus [3] 0x00000100 PPS
[    4.879091] ohci_hcd 0000:00:12.0: roothub.portstatus [4] 0x00000100 PPS
[    4.879098] usb usb3: default language 0x0409
[    4.879103] usb usb3: udev 1, busnum 3, minor = 256
[    4.879104] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    4.879106] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.879108] usb usb3: Product: OHCI Host Controller
[    4.879110] usb usb3: Manufacturer: Linux 3.1.10-gentoo-r1 ohci_hcd
[    4.879111] usb usb3: SerialNumber: 0000:00:12.0
[    4.879271] usb usb3: usb_probe_device
[    4.879277] usb usb3: configuration #1 chosen from 1 choice
[    4.879290] usb usb3: adding 3-0:1.0 (config #1, interface 0)
[    4.879563] hub 3-0:1.0: usb_probe_interface
[    4.879567] hub 3-0:1.0: usb_probe_interface - got id
[    4.879570] hub 3-0:1.0: USB hub found
[    4.879581] hub 3-0:1.0: 5 ports detected
[    4.879583] hub 3-0:1.0: standalone hub
[    4.879584] hub 3-0:1.0: no power switching (usb 1.0)
[    4.879585] hub 3-0:1.0: no over-current protection
[    4.879587] hub 3-0:1.0: power on to power good time: 4ms
[    4.879591] hub 3-0:1.0: local power source is good
[    4.879593] hub 3-0:1.0: trying to enable port power on non-switchable hub
[    4.879613] drivers/usb/core/inode.c: creating file '001'
[    4.879654] ehci_hcd 0000:00:12.2: HS companion for 0000:00:12.0
[    4.879678] ohci_hcd 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    4.879703] ohci_hcd 0000:00:13.0: OHCI Host Controller
[    4.879708] drivers/usb/core/inode.c: creating file '004'
[    4.879968] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 4
[    4.880019] ohci_hcd 0000:00:13.0: created debug files
[    4.880020] ohci_hcd 0000:00:13.0: supports USB remote wakeup
[    4.880029] ohci_hcd 0000:00:13.0: irq 18, io mem 0xfeb4a000
[    4.918113] ehci_hcd 0000:00:12.2: GetStatus port:1 status 001403 0  ACK POWER sig=k CSC CONNECT
[    4.918128] hub 1-0:1.0: port 1: status 0501 change 0001
[    4.918144] ehci_hcd 0000:00:12.2: GetStatus port:2 status 001403 0  ACK POWER sig=k CSC CONNECT
[    4.918151] hub 1-0:1.0: port 2: status 0501 change 0001
[    4.918167] ehci_hcd 0000:00:12.2: GetStatus port:4 status 001803 0  ACK POWER sig=j CSC CONNECT
[    4.918174] hub 1-0:1.0: port 4: status 0501 change 0001
[    4.924138] hub 2-0:1.0: state 7 ports 5 chg 0000 evt 0000
[    4.935096] ohci_hcd 0000:00:13.0: OHCI controller state
[    4.935102] ohci_hcd 0000:00:13.0: OHCI 1.0, NO legacy support registers
[    4.935106] ohci_hcd 0000:00:13.0: control 0x283 RWC HCFS=operational CBSR=3
[    4.935109] ohci_hcd 0000:00:13.0: cmdstatus 0x00000 SOC=0
[    4.935112] ohci_hcd 0000:00:13.0: intrstatus 0x00000004 SF
[    4.935115] ohci_hcd 0000:00:13.0: intrenable 0x8000005a MIE RHSC UE RD WDH
Gregor
Re: No Device because no Driver
Postby Gregor » Tue Jan 31, 2012 4:56 am
[    4.935123] ohci_hcd 0000:00:13.0: hcca frame #0004
[    4.935127] ohci_hcd 0000:00:13.0: roothub.a 02001205 POTPGT=2 NOCP NPS NDP=5(5)
[    4.935130] ohci_hcd 0000:00:13.0: roothub.b 00000000 PPCM=0000 DR=0000
[    4.935132] ohci_hcd 0000:00:13.0: roothub.status 00008000 DRWE
[    4.935136] ohci_hcd 0000:00:13.0: roothub.portstatus [0] 0x00000100 PPS
[    4.935139] ohci_hcd 0000:00:13.0: roothub.portstatus [1] 0x00000100 PPS
[    4.935142] ohci_hcd 0000:00:13.0: roothub.portstatus [2] 0x00000100 PPS
[    4.935145] ohci_hcd 0000:00:13.0: roothub.portstatus [3] 0x00000100 PPS
[    4.935148] ohci_hcd 0000:00:13.0: roothub.portstatus [4] 0x00000100 PPS
[    4.935162] usb usb4: default language 0x0409
[    4.935167] usb usb4: udev 1, busnum 4, minor = 384
[    4.935169] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    4.935171] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.935172] usb usb4: Product: OHCI Host Controller
[    4.935174] usb usb4: Manufacturer: Linux 3.1.10-gentoo-r1 ohci_hcd
[    4.935175] usb usb4: SerialNumber: 0000:00:13.0
[    4.935474] usb usb4: usb_probe_device
[    4.935480] usb usb4: configuration #1 chosen from 1 choice
[    4.935492] usb usb4: adding 4-0:1.0 (config #1, interface 0)
[    4.935766] hub 4-0:1.0: usb_probe_interface
[    4.935770] hub 4-0:1.0: usb_probe_interface - got id
[    4.935772] hub 4-0:1.0: USB hub found
[    4.935783] hub 4-0:1.0: 5 ports detected
[    4.935785] hub 4-0:1.0: standalone hub
[    4.935786] hub 4-0:1.0: no power switching (usb 1.0)
[    4.935787] hub 4-0:1.0: no over-current protection
[    4.935789] hub 4-0:1.0: power on to power good time: 4ms
[    4.935793] hub 4-0:1.0: local power source is good
[    4.935795] hub 4-0:1.0: trying to enable port power on non-switchable hub
[    4.935814] drivers/usb/core/inode.c: creating file '001'
[    4.935850] ehci_hcd 0000:00:13.2: HS companion for 0000:00:13.0
[    4.935872] ohci_hcd 0000:00:14.5: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    4.935897] ohci_hcd 0000:00:14.5: OHCI Host Controller
[    4.935901] drivers/usb/core/inode.c: creating file '005'
[    4.936171] ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 5
[    4.936207] ohci_hcd 0000:00:14.5: created debug files
[    4.936209] ohci_hcd 0000:00:14.5: supports USB remote wakeup
[    4.936218] ohci_hcd 0000:00:14.5: irq 18, io mem 0xfeb48000
[    4.979142] hub 3-0:1.0: state 7 ports 5 chg 0000 evt 0000
[    4.991099] ohci_hcd 0000:00:14.5: OHCI controller state
[    4.991104] ohci_hcd 0000:00:14.5: OHCI 1.0, NO legacy support registers
[    4.991108] ohci_hcd 0000:00:14.5: control 0x283 RWC HCFS=operational CBSR=3
[    4.991112] ohci_hcd 0000:00:14.5: cmdstatus 0x00000 SOC=0
[    4.991115] ohci_hcd 0000:00:14.5: intrstatus 0x00000004 SF
[    4.991118] ohci_hcd 0000:00:14.5: intrenable 0x8000005a MIE RHSC UE RD WDH
[    4.991126] ohci_hcd 0000:00:14.5: hcca frame #0004
[    4.991129] ohci_hcd 0000:00:14.5: roothub.a 02001202 POTPGT=2 NOCP NPS NDP=2(2)
[    4.991132] ohci_hcd 0000:00:14.5: roothub.b 00000000 PPCM=0000 DR=0000
[    4.991135] ohci_hcd 0000:00:14.5: roothub.status 00008000 DRWE
[    4.991138] ohci_hcd 0000:00:14.5: roothub.portstatus [0] 0x00000100 PPS
[    4.991141] ohci_hcd 0000:00:14.5: roothub.portstatus [1] 0x00000100 PPS
[    4.991156] usb usb5: default language 0x0409
[    4.991161] usb usb5: udev 1, busnum 5, minor = 512
[    4.991163] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    4.991165] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.991166] usb usb5: Product: OHCI Host Controller
[    4.991168] usb usb5: Manufacturer: Linux 3.1.10-gentoo-r1 ohci_hcd
[    4.991169] usb usb5: SerialNumber: 0000:00:14.5
[    4.991468] usb usb5: usb_probe_device
[    4.991473] usb usb5: configuration #1 chosen from 1 choice
[    4.991485] usb usb5: adding 5-0:1.0 (config #1, interface 0)
[    4.991753] hub 5-0:1.0: usb_probe_interface
[    4.991758] hub 5-0:1.0: usb_probe_interface - got id
[    4.991760] hub 5-0:1.0: USB hub found
[    4.991771] hub 5-0:1.0: 2 ports detected
[    4.991772] hub 5-0:1.0: standalone hub
[    4.991774] hub 5-0:1.0: no power switching (usb 1.0)
[    4.991775] hub 5-0:1.0: no over-current protection
[    4.991777] hub 5-0:1.0: power on to power good time: 4ms
[    4.991781] hub 5-0:1.0: local power source is good
[    4.991782] hub 5-0:1.0: trying to enable port power on non-switchable hub
[    4.991800] drivers/usb/core/inode.c: creating file '001'
[    4.992105] uhci_hcd: USB Universal Host Controller Interface driver
[    4.992511] usbcore: registered new interface driver cdc_acm
[    4.992515] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.992638] usbcore: registered new interface driver uas
[    4.992640] Initializing USB Mass Storage driver...
[    4.992718] usbcore: registered new interface driver usb-storage
[    4.992719] USB Mass Storage support registered.
[    4.992785] usbcore: registered new interface driver libusual
[    4.992898] usbcore: registered new interface driver usbserial
[    4.992900] usbserial: USB Serial Driver core
[    4.993133] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    4.993672] serio: i8042 KBD port at 0x60,0x64 irq 1
[    4.993682] serio: i8042 AUX port at 0x60,0x64 irq 12
[    4.993917] mousedev: PS/2 mouse device common for all mice
[    4.994286] I2O subsystem v1.325
[    4.994294] i2o: max drivers = 8
[    4.994610] rtc_cmos 00:05: RTC can wake from S4
[    4.994734] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[    4.994758] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    4.994889] md: raid6 personality registered for level 6
[    4.994891] md: raid5 personality registered for level 5
[    4.994892] md: raid4 personality registered for level 4
[    4.995035] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
[    4.995095] Modular ISDN core version 1.1.21
[    4.995166] NET: Registered protocol family 34
[    4.995511] cpuidle: using governor ladder
[    4.996284] cpuidle: using governor menu
[    4.996287] EFI Variables Facility v0.08 2004-May-17
[    4.997382] usbcore: registered new interface driver usbhid
[    4.997385] usbhid: USB HID core driver
[    4.997767] snd_hda_intel 0000:00:14.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[    5.010472] hda_codec: ALC887-VD: BIOS auto-probing.
[    5.017998] ALSA device list:
[    5.017999]   #0: HD-Audio Generic at 0xfeb40000 irq 16
[    5.018056] hub 1-0:1.0: state 7 ports 5 chg 0016 evt 0000
[    5.018067] hub 1-0:1.0: port 1, status 0501, change 0000, 480 Mb/s
[    5.018076] ehci_hcd 0000:00:12.2: port 1 low speed --> companion
[    5.018151] Netfilter messages via NETLINK v0.30.
[    5.018167] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    5.018356] ctnetlink v0.93: registering with nfnetlink.
[    5.018658] ip_tables: (C) 2000-2006 Netfilter Core Team
[    5.018687] TCP cubic registered
[    5.018688] Initializing XFRM netlink socket
[    5.018934] NET: Registered protocol family 10
[    5.019454] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    5.019494] IPv6 over IPv4 tunneling driver
[    5.020007] NET: Registered protocol family 17
[    5.020016] Registering the dns_resolver key type
[    5.020177] PM: Hibernation image not present or could not be loaded.
[    5.020187] registered taskstats version 1
[    5.020476]   Magic number: 12:28:851
[    5.020531] console [netcon0] enabled
[    5.020532] netconsole: network logging started
[    5.020555] powernow-k8: Found 1 AMD A6-3650 APU with Radeon(tm) HD Graphics (4 cpu cores) (version 2.20.00)
[    5.020607] powernow-k8:    0 : pstate 0 (2600 MHz)
[    5.020609] powernow-k8:    1 : pstate 1 (2300 MHz)
[    5.020610] powernow-k8:    2 : pstate 2 (2000 MHz)
[    5.020611] powernow-k8:    3 : pstate 3 (1800 MHz)
[    5.020613] powernow-k8:    4 : pstate 4 (1600 MHz)
[    5.020614] powernow-k8:    5 : pstate 5 (1300 MHz)
[    5.020616] powernow-k8:    6 : pstate 6 (1000 MHz)
[    5.020617] powernow-k8:    7 : pstate 7 (800 MHz)
[    5.069101] ehci_hcd 0000:00:12.2: GetStatus port:1 status 003002 0  ACK POWER OWNER sig=se0 CSC
[    5.069141] hub 1-0:1.0: port 2, status 0501, change 0000, 480 Mb/s
[    5.069157] ehci_hcd 0000:00:12.2: port 2 low speed --> companion
[    5.116348] ata7: SATA link down (SStatus 0 SControl 310)
[    5.120040] ehci_hcd 0000:00:12.2: GetStatus port:2 status 003002 0  ACK POWER OWNER sig=se0 CSC
[    5.120080] hub 1-0:1.0: port 4, status 0501, change 0000, 480 Mb/s
[    5.171044] ehci_hcd 0000:00:12.2: port 4 full speed --> companion
[    5.171055] ehci_hcd 0000:00:12.2: GetStatus port:4 status 003801 0  ACK POWER OWNER sig=j CONNECT
[    5.171063] hub 1-0:1.0: port 4 not reset yet, waiting 50ms
[    5.222365] ehci_hcd 0000:00:12.2: GetStatus port:4 status 003002 0  ACK POWER OWNER sig=se0 CSC
[    5.222402] hub 3-0:1.0: state 7 ports 5 chg 0000 evt 0016
[    5.222414] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [0] = 0x00010301 CSC LSDA PPS CCS
[    5.222424] hub 3-0:1.0: port 1, status 0301, change 0001, 1.5 Mb/s
[    5.270361] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    5.270405] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    5.270438] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    5.270460] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    5.270482] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    5.270505] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    5.273124] ata6.00: ATA-8: WDC WD10EARS-00Y5B1, 80.00A80, max UDMA/133
[    5.273134] ata6.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.273906] ata4.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[    5.273916] ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.273961] ata2.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[    5.273968] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.274234] ata3.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[    5.274241] ata3.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.274457] ata6.00: configured for UDMA/133
[    5.276643] ata5.00: ATA-8: WDC WD20EARX-00PASB0, 51.0AB51, max UDMA/133
[    5.276649] ata5.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.277555] ata4.00: configured for UDMA/133
[    5.277649] ata2.00: configured for UDMA/133
[    5.278247] ata3.00: configured for UDMA/133
[    5.282168] ata1.00: ATA-8: Corsair Force 3 SSD, 1.3.3, max UDMA/133
[    5.282178] ata1.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[    5.283677] ata5.00: configured for UDMA/133
[    5.292360] ata1.00: configured for UDMA/133
[    5.292826] scsi 0:0:0:0: Direct-Access     ATA      Corsair Force 3  1.3. PQ: 0 ANSI: 5
[    5.293923] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[    5.294279] sd 0:0:0:0: [sda] Write Protect is off
[    5.294289] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    5.294363] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.294480] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    5.294932] scsi 1:0:0:0: Direct-Access     ATA      WDC WD20EARS-00M 51.0 PQ: 0 ANSI: 5
[    5.295577] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    5.295762]  sda: sda1 sda2 sda3
[    5.295835] sd 1:0:0:0: [sdb] Write Protect is off
[    5.295842] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    5.295894] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    5.295937] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.296250] scsi 2:0:0:0: Direct-Access     ATA      WDC WD20EARS-00M 51.0 PQ: 0 ANSI: 5
[    5.296722] sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    5.297078] sd 2:0:0:0: [sdc] Write Protect is off
[    5.297087] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    5.297108] sd 2:0:0:0: Attached scsi generic sg2 type 0
[    5.297186] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.297198] sd 0:0:0:0: [sda] Attached SCSI disk
[    5.297483] scsi 3:0:0:0: Direct-Access     ATA      WDC WD20EARS-00M 51.0 PQ: 0 ANSI: 5
[    5.297932] sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    5.298122] sd 3:0:0:0: [sdd] Write Protect is off
[    5.298131] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    5.298183] sd 3:0:0:0: Attached scsi generic sg3 type 0
[    5.298198] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.298569] scsi 4:0:0:0: Direct-Access     ATA      WDC WD20EARX-00P 51.0 PQ: 0 ANSI: 5
[    5.299016] sd 4:0:0:0: [sde] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    5.299024] sd 4:0:0:0: [sde] 4096-byte physical blocks
[    5.299177] sd 4:0:0:0: Attached scsi generic sg4 type 0
[    5.299200] sd 4:0:0:0: [sde] Write Protect is off
[    5.299208] sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
[    5.299368] sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.299673] scsi 5:0:0:0: Direct-Access     ATA      WDC WD10EARS-00Y 80.0 PQ: 0 ANSI: 5
[    5.300212] sd 5:0:0:0: [sdf] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
[    5.300348] sd 5:0:0:0: Attached scsi generic sg5 type 0
[    5.300371] sd 5:0:0:0: [sdf] Write Protect is off
[    5.300378] sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[    5.300470] sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.326028] hub 3-0:1.0: debounce: port 1: total 100ms stable 100ms status 0x301
[    5.388126] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [0] = 0x00100303 PRSC LSDA PPS PES CCS
[    5.439109] usb 3-1: new low speed USB device number 2 using ohci_hcd
[    5.502125] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [0] = 0x00100303 PRSC LSDA PPS PES CCS
[    5.572141] usb 3-1: skipped 1 descriptor after interface
[    5.572151] usb 3-1: skipped 1 descriptor after interface
[    5.574137] usb 3-1: default language 0x0409
[    5.576139] usb 3-1: udev 2, busnum 3, minor = 257
[    5.576149] usb 3-1: New USB device found, idVendor=13ba, idProduct=0017
[    5.576155] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    5.576161] usb 3-1: Product: Generic USB K/B
[    5.576533] usb 3-1: usb_probe_device
[    5.576544] usb 3-1: configuration #1 chosen from 1 choice
[    5.578118] usb 3-1: adding 3-1:1.0 (config #1, interface 0)
[    5.578486] usbhid 3-1:1.0: usb_probe_interface
[    5.578494] usbhid 3-1:1.0: usb_probe_interface - got id
[    5.583835] input: Generic USB K/B as /devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.0/input/input2
[    5.584383] generic-usb 0003:13BA:0017.0001: input,hidraw0: USB HID v1.10 Keyboard [Generic USB K/B] on usb-0000:00:12.0-1/input0
[    5.584429] usb 3-1: adding 3-1:1.1 (config #1, interface 1)
[    5.584590] usbhid 3-1:1.1: usb_probe_interface
[    5.584597] usbhid 3-1:1.1: usb_probe_interface - got id
[    5.589756] input: Generic USB K/B as /devices/pci0000:00/0000:00:12.0/usb3/3-1/3-1:1.1/input/input3
[    5.590483] generic-usb 0003:13BA:0017.0002: input,hidraw1: USB HID v1.10 Mouse [Generic USB K/B] on usb-0000:00:12.0-1/input1
[    5.590516] drivers/usb/core/inode.c: creating file '002'
[    5.590563] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [1] = 0x00010301 CSC LSDA PPS CCS
[    5.590577] hub 3-0:1.0: port 2, status 0301, change 0001, 1.5 Mb/s
[    5.605135] ata8: SATA link down (SStatus 0 SControl 310)
[    5.694364] hub 3-0:1.0: debounce: port 2: total 100ms stable 100ms status 0x301
[    5.706786]  sdf: sdf1
[    5.708262] sd 5:0:0:0: [sdf] Attached SCSI disk
[    5.714446]  sdb: sdb1
[    5.715467] sd 1:0:0:0: [sdb] Attached SCSI disk
[    5.718465]  sdd: sdd1
[    5.719388] sd 3:0:0:0: [sdd] Attached SCSI disk
[    5.725659]  sde: unknown partition table
[    5.726704] sd 4:0:0:0: [sde] Attached SCSI disk
[    5.726819]  sdc: sdc1
[    5.727561] sd 2:0:0:0: [sdc] Attached SCSI disk
[    5.756125] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [1] = 0x00100303 PRSC LSDA PPS PES CCS
[    5.807137] usb 3-2: new low speed USB device number 3 using ohci_hcd
[    5.870366] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [1] = 0x00100303 PRSC LSDA PPS PES CCS
[    5.910352] ata9: SATA link down (SStatus 0 SControl 310)
[    5.941064] usb 3-2: skipped 1 descriptor after interface
[    5.943055] usb 3-2: default language 0x0409
[    5.949373] usb 3-2: udev 3, busnum 3, minor = 258
[    5.949383] usb 3-2: New USB device found, idVendor=046d, idProduct=c050
[    5.949389] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.949395] usb 3-2: Product: USB-PS/2 Optical Mouse
[    5.949399] usb 3-2: Manufacturer: Logitech
[    5.949803] usb 3-2: usb_probe_device
[    5.949811] usb 3-2: configuration #1 chosen from 1 choice
[    5.951075] usb 3-2: adding 3-2:1.0 (config #1, interface 0)
[    5.951407] usbhid 3-2:1.0: usb_probe_interface
[    5.951413] usbhid 3-2:1.0: usb_probe_interface - got id
[    5.954334] ohci_hcd 0000:00:13.0: auto-stop root hub
[    5.958829] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:12.0/usb3/3-2/3-2:1.0/input/input4
[    5.959630] generic-usb 0003:046D:C050.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:12.0-2/input0
[    5.959675] drivers/usb/core/inode.c: creating file '003'
[    5.959723] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [3] = 0x00010101 CSC PPS CCS
[    5.959738] hub 3-0:1.0: port 4, status 0101, change 0001, 12 Mb/s
[    6.063130] hub 3-0:1.0: debounce: port 4: total 100ms stable 100ms status 0x101
[    6.125135] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [3] = 0x00100103 PRSC PPS PES CCS
[    6.176134] usb 3-4: new full speed USB device number 4 using ohci_hcd
[    6.204067] ohci_hcd 0000:00:14.5: auto-stop root hub
[    6.215368] ata10: SATA link down (SStatus 0 SControl 310)
[    6.215551] md: Waiting for all devices to be available before autodetect
[    6.215560] md: If you don't use raid, use raid=noautodetect
[    6.216271] md: Autodetecting RAID arrays.
[    6.238683] md: invalid raid superblock magic on sdb1
[    6.238783] md: sdb1 does not have a valid v0.90 superblock, not importing!
[    6.239093] ohci_hcd 0000:00:12.0: GetStatus roothub.portstatus [3] = 0x00100103 PRSC PPS PES CCS
[    6.263124] md: invalid raid superblock magic on sdd1
[    6.263223] md: sdd1 does not have a valid v0.90 superblock, not importing!
[    6.292475] md: invalid raid superblock magic on sdc1
[    6.292574] md: sdc1 does not have a valid v0.90 superblock, not importing!
[    6.292599] md: Scanned 3 and added 0 devices.
[    6.292603] md: autorun ...
[    6.292605] md: ... autorun DONE.
[    6.294954] EXT3-fs (sda3): error: couldn't mount because of unsupported optional features (240)
[    6.303033] usb 3-4: ep0 maxpacket = 8
[    6.307249] EXT4-fs (sda3): couldn't mount as ext2 due to feature incompatibilities
[    6.310062] usb 3-4: default language 0x0409
[    6.314076] usb 3-4: udev 4, busnum 3, minor = 259
[    6.314086] usb 3-4: New USB device found, idVendor=04d8, idProduct=fa0d
[    6.314092] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    6.314098] usb 3-4: Product: PrimuX USB II
[    6.314103] usb 3-4: Manufacturer: Gerdes Aktiengesellschaft
[    6.314513] usb 3-4: usb_probe_device
[    6.314521] usb 3-4: configuration #1 chosen from 1 choice
[    6.316112] usb 3-4: adding 3-4:1.0 (config #1, interface 0)
[    6.316384] drivers/usb/core/inode.c: creating file '004'
[    6.316442] hub 1-0:1.0: state 7 ports 5 chg 0000 evt 0010
[    6.316457] hub 4-0:1.0: state 7 ports 5 chg 0000 evt 0000
[    6.316465] hub 5-0:1.0: state 7 ports 2 chg 0000 evt 0000
[    6.316471] hub 3-0:1.0: state 7 ports 5 chg 0000 evt 0010
[    6.331064] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[    6.331093] VFS: Mounted root (ext4 filesystem) readonly on device 8:3.
[    6.334492] Freeing unused kernel memory: 748k freed
[    6.334823] Write protecting the kernel read-only data: 12288k
[    6.338206] Freeing unused kernel memory: 1048k freed
[    6.342859] Freeing unused kernel memory: 1588k freed
[    6.407685] cat used greatest stack depth: 4952 bytes left
[    6.419315] uvesafb: mode switch failed (eax=0x34f, err=0). Trying again with default timings.
[    7.175507] setfont used greatest stack depth: 4720 bytes left
[    7.197707] init-early.sh used greatest stack depth: 4648 bytes left
[    7.609347] udevadm used greatest stack depth: 4112 bytes left
[    7.657789] udevd[1239]: starting version 171
[    7.819851] md: bind<sdc1>
[    7.822369] md: bind<sdd1>
[    7.825431] md: bind<sdb1>
[    7.829513] bio: create slab <bio-1> at 1
[    7.829534] md/raid:md0: device sdb1 operational as raid disk 1
[    7.829536] md/raid:md0: device sdd1 operational as raid disk 2
[    7.829538] md/raid:md0: device sdc1 operational as raid disk 0
[    7.829974] md/raid:md0: allocated 3220kB
[    7.830069] md/raid:md0: raid level 5 active with 3 out of 3 devices, algorithm 2
[    7.830071] RAID conf printout:
[    7.830072]  --- level:5 rd:3 wd:3
[    7.830074]  disk 0, o:1, dev:sdc1
[    7.830076]  disk 1, o:1, dev:sdb1
[    7.830078]  disk 2, o:1, dev:sdd1
[    7.830103] md0: detected capacity change from 0 to 4000794542080
[    7.831720]  md0: unknown partition table
[    9.645469] EXT4-fs (sda3): re-mounted. Opts: (null)
[    9.759533] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[   10.054710] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
[   10.136678] EXT4-fs (sdf1): mounted filesystem with ordered data mode. Opts: (null)
[   10.530711] uvesafb: mode switch failed (eax=0x34f, err=0). Trying again with default timings.
[   12.126968] r8169 0000:03:00.0: eth0: link down
[   12.126988] r8169 0000:03:00.0: eth0: link down
[   12.129492] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   12.847194] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
[   12.847531] NFSD: starting 90-second grace period
[   15.121542] r8169 0000:03:00.0: eth0: link up
[   15.123998] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   15.875066] Adding 8008396k swap on /dev/sda2.  Priority:-1 extents:1 across:8008396k SS
[   25.282298] eth0: no IPv6 routers present
Gregor
Postby Gregor » Tue Jan 31, 2012 5:23 am
i had forgott.
The Problem exsist since i have a Asus Board with uefi bios. It is call: F1A75-M LE
Gregor
Postby cody » Thu Feb 02, 2012 10:40 pm
Gregor Wrote:The Driver install seems to work but it has same warnings.
i don't see CX23885 driver loaded at all on your 'dmesg' output (at least on the one you posted), which means that you didn't install it in the same kernel you're running or you didn't install it with becoming 'root' user before follow the installation steps. also, the warnings you're talking about are supposed to happen and don't indicate any errors. so, what about re-installing the driver with doing:
$ sudo su
(or "su" depending on your distribution to become 'root') then:
# tar xjvf linux-tbs-drivers.tar.bz2
# cd linux-tbs-drivers
# ./v4l/tbs-x86_64.sh
# make
# make install
# shutdown -r now
and then check:
# dmesg | grep 23885
to see if CX23885 driver is loaded.
Postby Gregor » Mon Feb 13, 2012 11:39 pm
So now i had new kernel & new driver.
Kernel: 3.2.1-gentoo-r2 #2 SMP Fri Jan 27 09:47:29 CET 2012 x86_64 AMD A6-3650 APU with Radeon(tm) HD Graphics AuthenticAMD GNU/Linux
lspci: 02:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 02)
i had do the following:
Download new driver from the Website:
unp all
./v4l/tbs-x86_64.sh
make -j5 && make install
shutdown -r now
Now i had type: dmesg | grep cx23885
and i see NOTHING !!!
So my Question again IS THERE any Problem with the UEFI Bios or my Board?
Gregor
Postby SergioDanielG » Tue Feb 14, 2012 2:50 am
I havn't got a TBS6921, I have a TBS6920 and a TBS6925
I update kernel today and I install tbs driver 20120212 in debian sid, without problems.
uname -a
Linux hogar 3.2.0-1-amd64 #1 SMP Sun Feb 5 15:17:15 UTC 2012 x86_64 GNU/Linux
lshw
    description: Desktop Computer
    product: GA-890FXA-UD5 ()
    vendor: Gigabyte Technology Co., Ltd.
    width: 64 bits
    capabilities: smbios-2.4 dmi-2.4 vsyscall32
    configuration: boot=normal chassis=desktop uuid=*********************
  *-core
       description: Motherboard
       physical id: 0
       version: x.x
     *-firmware
          description: BIOS
          vendor: Award Software International, Inc.
lspci
03:00.0 Multimedia video controller: Conexant Systems, Inc. CX23885 PCI Video and Audio Decoder (rev 02)
cx23885 driver version 0.0.3 loaded
cx23885 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
CORE cx23885[0]: subsystem: 6920:8888, board: TurboSight TBS 6920 [card=14,autodetected]
cx25840 4-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
cx25840 4-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
cx23885_dvb_register() allocating 1 frontend(s)
cx23885[0]: cx23885 based dvb card
DVB: registering new adapter (cx23885[0])
cx23885_dev_checkrevision() Hardware revision = 0xb0
cx23885[0]/0: found at 0000:03:00.0, rev: 2, irq: 18, latency: 0, mmio: 0xfce00000
cx23885 0000:03:00.0: setting latency timer to 64
input: cx23885 IR (TurboSight TBS 6920) as /devices/pci0000:00/0000:00:06.0/0000:03:00.0/rc/rc1/input9
rc1: cx23885 IR (TurboSight TBS 6920) as /devices/pci0000:00/0000:00:06.0/0000:03:00.0/rc/rc1
input: MCE IR Keyboard/Mouse (cx23885) as /devices/virtual/input/input10
rc rc1: lirc_dev: driver ir-lirc-codec (cx23885) registered at minor = 1
Best restards
SergioDanielG
Postby Gregor » Wed Feb 15, 2012 3:36 am
see next post
Gregor
